Source code not visible in editor
IDE gerelateerde berichten
Geregistreerd: 05 Aug 2022, 17:10
Woonplaats: Waalwijk
Berichtdoor addek » 05 Aug 2022, 17:30
I am using the Arduino IDE for many years without any problems and made 3 IOTs for garding my heatpomp.
Yesterday all worked OK, this morning the source files did not show in the editor window of the IDE.
Removed the Arduino15 map in the AppData, reïnstalled JAVA and reïnstalled the IDE.
after starting the IDE the editor does not show the new file lines setup() and loop().
Loading a project via the Files Menu changes the caption of the IDE to the requested ino file.
The black toolbar with the compile and uplaod icons does not show.
The green source tab remains empty ( should 2 tabs the ino file and one .h).
The source is not loaded in the editor window because the editor bottom line count remains 1.
I have copied the same source directory to my laptop and that works as expected.
I hope someone has a solution for this problem!
This is how the IDE looks like now:
I can not add an image....
[img]
[/img]
Re: Source code not visible in editor
Berichtdoor shooter » 06 Aug 2022, 07:10
as it is in english please use dutch for default,
what is problem ? is it the IDE or the program not loading correct?
Berichtdoor addek » 06 Aug 2022, 08:38
It is the IDE, a SAVE AS saves new project with correct source files. All menus in the top menu bar are OK.
Berichtdoor Frits1956 » 06 Aug 2022, 15:12
your sketchbook location is probably not set to the directory where you save your files.
In the IDE press [CTRL]+COMMA there you can set your file location.
Berichtdoor addek » 07 Aug 2022, 16:03
I enlarged the window and got the standard IDE layout.
The source files are loaded, compiler OK, and an eventual error will be indicated.
The compiler output window is empty after compilation.
Cursor down will change the bottom line count to the next line.
The editor window displays all lines which have red colored words with the correct font.
The editor line size is the size between the 2 visible words 'IPAddress' (the size of about 30 lines).
All text displayed by the IDE in black is not visible.
I can use an external editor and use the IDE as compiler, but I am used to Arduino IDE.
I hope some has a solution.
Berichtdoor shooter » 08 Aug 2022, 14:35
onder instellingen kun je de grootte van de letters aanpassen, kijk eens om deze op 14 te zetten of je dan wel iets kunt zien.
Berichtdoor addek » 08 Aug 2022, 15:15
Al geprobeerd, maakt geen verschil,
overigens de rode testen in de editor hebben de goede grootte
op een veel te grote regelhoogte
Berichtdoor shooter » 09 Aug 2022, 19:11
en heb je het al voor elkaar, want anders kun je email naar mij gebruiken of een filmpje.
Berichtdoor addek » 10 Aug 2022, 13:36
shooter schreef:en heb je het al voor elkaar, want anders kun je email naar mij gebruiken of een filmpje.
Was dat maar waar.
Ik heb wel een site gevonden met hetzelfde probleem:
https://forum.arduino.cc/t/my-arduino-e ... ing/628940
Berichtdoor addek » 10 Aug 2022, 13:44
Bij deze link hebben ze geen oplossing vermeld....
Terug naar Arduino IDE
