Meerder user en passwords
Arduino specifieke Software
Geregistreerd: 26 Okt 2015, 16:07
Berichtdoor Atwist » 01 Dec 2017, 17:48
Hoe kan ik in dit script een 2e en 3e user en password.
Heb geprobeerd met de volgende regel
if (server.arg("USERNAME") == "user1" &&  server.arg("PASSWORD") == "pass1" )
maar dat werkt niet
void handleLogin(){
  String msg;
  if (server.hasHeader("Cookie")){
    Serial.print("Found cookie: ");
    String cookie = server.header("Cookie");
    Serial.println(cookie);
  if (server.hasArg("DISCONNECT")){
    Serial.println("Disconnection");
    server.sendHeader("Location","/login");
    server.sendHeader("Cache-Control","no-cache");
    server.sendHeader("Set-Cookie","ESPSESSIONID=0");
    server.send(301);
    return;
  if (server.hasArg("USERNAME") && server.hasArg("PASSWORD")){
    if (server.arg("USERNAME") == "admin" &&  server.arg("PASSWORD") == "admin" ){
      server.sendHeader("Location","/");
      server.sendHeader("Set-Cookie","ESPSESSIONID=1");
      server.send(301);
      Serial.println("Log in Successful");
      return;
  msg = "Wrong username/password! try again.";
  Serial.println("Log in Failed");
  String content = "<html><body><form action='/login' method='POST'>To log in, please use : admin/admin<br>";
  content += "User:<input type='text' name='USERNAME' placeholder='user name'><br>";
  content += "Password:<input type='password' name='PASSWORD' placeholder='password'><br>";
  content += "<input type='submit' name='SUBMIT' value='Submit'></form>" + msg + "<br>";
  content += "You also can go <a href='/inline'>here</a></body></html>";
  server.send(200, "text/html", content);
Andreas
Re: Meerder user en passwords
Berichtdoor shooter » 01 Dec 2017, 18:31
(user1==server.arg("USERNAME")&& pass1==server.arg("PASSWORD")) || (user2==server...... && pass2 == server.arg....)||(user3 ==..... && pass3 == .....)
op de puntjes komt dus telkens hetzelfde.
Een andere manier is met een 2 arrays waar de namen instaan.
dan wordt het dus
vlag = false
for (teller......)
IF user[teller] && pass[teller]){zet vlag op toegang}
Berichtdoor Atwist » 01 Dec 2017, 19:37
Dank je wel Paul,
Ga hier eens mee spelen, laat het nog even weten.
Andreas
Berichtdoor Atwist » 01 Dec 2017, 20:28
Met array loop IK vast, de logica van de array snap ik wel, maar deze in een zinnige regel te zetten, gaat boven mijn pet.
const int Array[][2] = {{user1,pass1},{user2,pass2},{user3,pass3}};
Dit klopt in ieder geval al niet maar wat er fout is zie ik niet, volgen mij moet 1e = naam array, 2e= bij behoorden gegeven zijn
Andreas
Berichtdoor nicoverduin » 01 Dec 2017, 20:47
Het zijn toch geen integers ...... zucht....
Berichtdoor Atwist » 02 Dec 2017, 10:12
Zucht.......
Ik heb veel uitleg op het web gelezen en kom daar telkens "int " of "const int" tegen
zoals deze "int myArray[10]={9,3,2,4,3,2,7,8,9,11};"
Komt van de Arduino site https://www.arduino.cc/reference/en/language/variables/data-types/array/
Dus nu snap ik het niet meer
ZUCHT.........
Andreas
Berichtdoor nicoverduin » 02 Dec 2017, 10:39
Dus jouw user id en password zijn getallen?
Berichtdoor shooter » 03 Dec 2017, 19:22
nee het zijn teksten zoals admin zie listing, ik heb maar even een snel voorbeeldje geschreven, heb meer te doen.
Berichtdoor nicoverduin » 03 Dec 2017, 20:06
Het ging mij niet om jouw voorbeeld maar die van de TS die even de basis overslaat....
Terug naar Arduino software
