wifi relais
wifi relais
enige hulp gevraagd om deze sketch
het lukt mij niet om het relais te schakelen met commando ipadres/on to turn on
Wemos maakt verbinding en handmatig schakelen lukt ook.
alleen niet via een browser.
ik heb vanalles geprobeerd maar niks lukt.
graag hulp
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
#define STASSID "yourwifiname"
#define STAPSK "welcome123!"
#define LED D4
int rstatus =0;
const char* ssid = STASSID;
const char* password = STAPSK;
IPAddress ip(q); // IP address of the server
IPAddress gateway(192,168,1,1); // gateway of your network
IPAddress subnet(255,255,255,0); // subnet mask of your network
ESP8266WebServer server(80);
void setup(void) {
pinMode(D2,OUTPUT); // relay
pinMode(D1,OUTPUT); // buzzer
pinMode(D3,INPUT_PULLUP); // switch
pinMode(LED,OUTPUT); // Internal LED
digitalWrite(LED,LOW); // Led on (low = on)
WiFi.mode(WIFI_STA);
WiFi.config(ip, gateway, subnet); // forces to use the fix IP
WiFi.begin(ssid, password);
// Wait for connection
delay(500);
server.onNotFound(handleNotFound);
server.on("/", handleRoot);
server.on("/on", webRelayOn);
server.on("/off", webRelayOff);
server.begin();
// Beep beep beep
for (int x=0; x<3;x++){
digitalWrite(D1,HIGH);delay(50);
digitalWrite(D1,LOW);delay(100);
} // ### END OF SETUP ###
void handleNotFound() {
server.send(404, "text/plain", "Page not found.");
void handleRoot() {
if (rstatus==1) server.send(200, "text/plain", "Relay is ON\r\nUse http://<ip address>/off to turn off");
if (rstatus==0) server.send(200, "text/plain", "Relay is OFF\r\nUse http://<ip address>/on to turn on");
void webRelayOn(){
rstatus=1;
void webRelayOff(){
rstatus=0;
void loop(void) {
server.handleClient();
// handle the manual button
if (digitalRead(D3)==LOW) {
if (rstatus==0)
rstatus=1;
rstatus=0;
delay(500);
digitalWrite(D2,rstatus);
// Set the internal Led
digitalWrite(LED,!rstatus);
graag hulp
#define LED D4
int rstatus =0;
void setup(void) {
delay(500);
server.begin();
// Beep beep beep
void handleRoot() {
void webRelayOn(){
rstatus=1;
void webRelayOff(){
rstatus=0;
void loop(void) {
if (rstatus==0)
rstatus=1;
rstatus=0;
delay(500);
Re: wifi relais
Wat gebeurt er als je het stukje:
even helemaal op commentaar zet, dus weg haalt?
mvg Nico
if (rstatus==0)
rstatus=1;
rstatus=0;
delay(500);
mvg Nico
Gebruikers in dit forum: ucamovmof en 6 gasten
