We zijn er bijna.....
8 berichten
ik ben met de controller bezig met volgende functies: zon-op en zon-ondergang, thermostaat + doseerpomp voor sporenelementen. Alles werkt behalve de doseerpomp, de uitgang op pin 52 wordt aangestuurd maar blijft aangestuurd in de functie "doseerpomp" terwijl deze maar 15 seconden zou moeten aangestuurd worden welke in de interval wordt bepaald.
de Code:
#include "RTClib.h"
#include "ChannelManager.h"
#include "Nextion.h"
#include <OneWire.h>
#define ONE_WIRE_BUS 22
const int MaxChannels = 1; // Max number of channels, change if more or less are required
const int MaxPoints = 10; // Max number of light intensity points, change if more or less are required
RTC_DS1307 RTC;
DateTime CurrentTime;
char buffer[10] = {0};
uint32_t number = 0;
int thermostaat = 37;
int pomp = 52;
int State = LOW;
const long interval = 15000;
NexProgressBar j0 = NexProgressBar(0, 3, "j0");
NexText percentage = NexText(0, 4, "t1");
NexText temperature = NexText(0, 5, "t0");
NexText uur = NexText(0, 1, "t5");
NexText minuten = NexText(0, 2, "t7");
char buffer_hour[10] = {0};
char buffer_minute[10] = {0};
Channel Channels[MaxChannels];
Point Points[MaxChannels][MaxPoints];
void InitializeChannels(int channels) {
// Channel 0:
int channelNo = 0; // Currently editing channel 0
int pin = 3; // Channel 0 uses pin 10
Channels[channelNo] = Channel(pin, MaxPoints, fademode_linear, Points[channelNo]); // Initialize channel and choose FadeMode
Channels[channelNo].AddPoint(6, 0, 0); // Add Point (can also use decimal values ranging from 0 to 1 if you prefer)
Channels[channelNo].AddPoint(10, 0, 255);
Channels[channelNo].AddPoint(10, 30, 190);
Channels[channelNo].AddPoint(21, 30, 190);
Channels[channelNo].AddPoint(22, 0, 255);
Channels[channelNo].AddPoint(23, 59, 0);
long lastUpdateTime = 0;
void UpdateLights(DateTime currentTime)
long now = Seconds(currentTime.hour(), currentTime.minute(), currentTime.second());
if(now != lastUpdateTime)
for(int channel = 0; channel < MaxChannels; channel++)
analogWrite(Channels[channel].GetPin(), Channels[channel].GetLightIntensityInt(now));
float intensityNow=Channels[channel].GetLightIntensityInt(now);
float maxIntensity=255;
float a=intensityNow/maxIntensity;
float currentPercent=a*100;
j0.setValue(currentPercent);
dtostrf(currentPercent, 3,1, buffer);
percentage.setText(buffer);
Serial.println(currentPercent);
lastUpdateTime = now;
long Seconds(int hours, int minutes, int seconds) {
return ((long)hours * 60 * 60) + (minutes * 60) + seconds ;
// ----------------------- Setup -----------------------
sensors.begin();
InitializeChannels(MaxChannels);
pinMode(thermostaat, OUTPUT);
pinMode(52, OUTPUT);
Wire.begin();
RTC.begin();
nexInit();
CurrentTime = RTC.now();
UpdateLights(CurrentTime);
tijd();
temperatuur();
doseerpomp();
void temperatuur (){
float temperatuur = sensors.getTempCByIndex(0);
if (temperatuur < 25){
digitalWrite(thermostaat, HIGH);
digitalWrite(thermostaat, LOW);
memset(buffer, 0,sizeof(buffer));
dtostrf(temperatuur, 3, 1, buffer);
temperature.setText(buffer);
Serial.println(sensors.getTempCByIndex(0));
void tijd () {
number = CurrentTime.hour();
memset(buffer, 0, sizeof(buffer));
itoa(number, buffer, 10);
uur.setText(buffer);
number = CurrentTime.minute();
minuten.setText(buffer);
void doseerpomp () {
if (CurrentTime.hour() == 12 && CurrentTime.minute() == 00 && CurrentTime.second() == 00){
// save the last time you blinked the LED
if (State == LOW) {
State = HIGH;
State = LOW;
}// if the LED is off turn it on and vice-versa:
// set the LED with the ledState of the variable:
digitalWrite(pomp, State);
de Code:
#include "RTClib.h"
RTC_DS1307 RTC;
int pomp = 52;
int State = LOW;
// Channel 0:
sensors.begin();
Wire.begin();
RTC.begin();
nexInit();
tijd();
temperatuur();
doseerpomp();
void tijd () {
if (State == LOW) {
State = HIGH;
State = LOW;
Re: We zijn er bijna.....
zoals je het zelf hebt staan gebeurt het alleen maar als het op het moment dat je secondes op 00 staan
if (CurrentTime.hour() == 12 && CurrentTime.minute() == 00 && CurrentTime.second() <= 15){// doorloop dit stuk de eerste 15 secondes..
if (State == LOW) {
State = HIGH;
State = LOW;
Met vriendelijke groet Arjan
Hoi Arjan, bedankt voor je reactie, je oplossing werkt niet bij mij, ik probeer te begrijpen wat die sketch "blink without delay" eigenljk doet. zoals ik het zie in dit programma gaat de Arduino eigenlijk terug tellen, of ben ik mis? Kort door de bocht komt het er eigenlijk op neer dat de Arduino elke dag een puls moet geven van 15 seconden zonder gebruik te maken van een delay functie om het gekende euvel van de delay te omzeilen.
ik ben nu testen aan het doen en het vreemde is dat soms wel werkt en soms niet ![Confused :?](./images/smilies/icon_e_confused.gif)
het is wel handig om dit stukje er tussen uit te halen
Dries schreef:Hoi Arjan, bedankt voor je reactie, je oplossing werkt niet bij mij, ik probeer te begrijpen wat die sketch "blink without delay" eigenljk doet. zoals ik het zie in dit programma gaat de Arduino eigenlijk terug tellen, of ben ik mis? Kort door de bocht komt het er eigenlijk op neer dat de Arduino elke dag een puls moet geven van 15 seconden zonder gebruik te maken van een delay functie om het gekende euvel van de delay te omzeilen.
in dit stukje
geef je aan dat de tijd aan een aantal voorwaarden moet voldoen
dit stukje
daarmee wordt getest of second.. aan de waarde voldoet
met het < kleiner dan teken geven we aan dat alles kleiner dan de waarde 15 ook prima is, verder telt die niet af
simpeler houden, je if die baco aanhaalt is prima, als deze waar is dan pomp aan, else pomp uit.
de led is een ander, dus beter is if state en pomp dan led aan
bedankt Paul & Arjan, het werkt, inderdaad simpeler houden, soms ga ik het veel te ver zoeken ![Mr. Green :mrgreen:](./images/smilies/icon_mrgreen.gif)
8 berichten
