Hobbyist EN programmeur gezocht voor superleuk Project. $of€
Geregistreerd: 06 Okt 2019, 20:06
Berichtdoor romalomey » 06 Okt 2019, 20:25
Goedemiddag Arduino specialisten+hobbyisten !
What do we look for:
Looking for Experienced hobbyists or professionals.
We do have an internal programmer but he is simply too busy now.
So we are looking for a cost effective alternative.
It is urgent, prefer to start today/tomorrow.
Due to time difference we prefer you living in the time zone Europe or USA.
If you live in the east of Holland(region Doetinchem) this would be a plus, but not needed.
If you live in Colombia region Caldas/Manizales this would also be a plus, but not needed.
Purpose:
We performance test multiple dev-boards and mcu's and therefore need simple test programs.
If you results are good, you get the order to make bigger programs.
Projects:
1. OBD2 project now based on the arduino teensy 3.6.
-->Our basic program already works perfectly<--
It is a CAN-bus to USB-serial converter.
It reads massive amounts of messages from CAN-bus, and converts these to serial format, and sends out these bytes to USB.
"Add-on" project nr1:
We need a build-in virtual delay, which holds the massive amount of can-messages for 100msec, (in example a FIFO buffer) before sending out to USB-serial.
(update: FINISHED)
"Add-on" project nr2:
Filter the messages on the can-bus. If one of the messages contains the value "xxx" then send can-message "ABCD"
(update: SEMI-FINISHED)
"Add-on" project nr3:
Expansion of project nr2:
2. OBD2 project based on the ESP32(which has CAN/BLE/WiFi
We have received a CAN library and simple CAN-to-wifi program that works
Need help producing an adequate test program to see the limits of this MCU.
The functionality should be identical to project 1 which already works and is fully tested.
We want to send 3 CAN messages per millisecond from CAN-bus ---> Wifi ---> Android phone --->4g t---> online server.
It would help if you can make the app for android too.
It would help if you have experience with BLE, so we can test WiFi+BLE.
Please Arduino enthusiasts, send PM a.s.a.p if you think you can be of any value to this awesome projects!
_____________________________________________________________________
3. This is for the C++ specialist. Maybe wrong forum, but we can try.
We have a fully functional IP-tunnel which send messages from A to B.
The IP tunnel needs a nice GUI, some extra features as "reconnect" when connection is lost.
If this works out the program must be professionalized with i.e multi user connect, payment features etc etc
