uploaden werkt niet
uploaden werkt niet
ik heb een arduino gekregen maar het werkt niet en heeft ook nooit gewerkt
dit is de error
Arduino:1.8.9 (Mac OS X), Board:"Arduino/Genuino Uno"
De schets gebruikt 444 bytes (1%) programma-opslagruimte. Maximum is 32256 bytes.
Globale variabelen gebruiken 9 bytes (0%) van het dynamisch geheugen. Resteren 2039 bytes voor lokale variabelen. Maximum is 2048 bytes.
/Users/Patrick/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14/bin/avrdude -C/Users/Patrick/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.Bluetooth-Incoming-Port -b115200 -D -Uflash:w:/var/folders/9w/pcpw13651517xk7n8h5b6k5h0000gn/T/arduino_build_360414/sketch_jul01c.ino.hex:i
java.io.IOException: Cannot run program "/Users/Patrick/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14/bin/avrdude": error=2, No such file or directory
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1048)
at java.lang.Runtime.exec(Runtime.java:620)
at java.lang.Runtime.exec(Runtime.java:485)
at processing.app.helpers.ProcessUtils.exec(ProcessUtils.java:11)
at cc.arduino.packages.Uploader.executeUploadCommand(Uploader.java:129)
at cc.arduino.packages.uploaders.SerialUploader.runCommand(SerialUploader.java:383)
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:197)
at cc.arduino.UploaderUtils.upload(UploaderUtils.java:77)
at processing.app.SketchController.upload(SketchController.java:732)
at processing.app.SketchController.exportApplet(SketchController.java:703)
at processing.app.Editor$UploadHandler.run(Editor.java:2070)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.io.IOException: error=2, No such file or directory
at java.lang.UNIXProcess.forkAndExec(Native Method)
at java.lang.UNIXProcess.<init>(UNIXProcess.java:247)
at java.lang.ProcessImpl.start(ProcessImpl.java:134)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1029)
... 11 more
Er trad een error op gedurende laden van de schets
Dit rapport zou meer informatie bevatten met
"Uitgebreide uitvoer weergeven tijden compilatie"
optie aan in Bestand -> Voorkeuren.
ik ben al bijna een week bezig aan het zoeken of ik deze error kan oplossen maar niks werkt ik heb ook al een nieuwe arduino gekregen maar dat werkt ook niet ik weet niet waar de error aan licht als iemand het weet reageer dan met de oplossing
alvast bedankt
sorry als er spellings fouten in zitten (heb dislexie)
groeten : lars
dit is de error
... 11 more
alvast bedankt
groeten : lars
Re: uploaden werkt niet
Ik weet niet precies hoe hij de IDE hebt geinstalleerd, maar ik kan niet begrijpen hoe je op een Mac uberhaupt een pad als de "-C/Users/Patrick/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14/etc/avrdude.conf " kan krijgen. Ik vermoed dat je iets verkl..t hebt bij het installeren op de Mac. Nu lijkt het een memgelmoes van Mac en Windows door elkaar. Dus ik snap dat de IDE eruit klapt. Overigens heeft dit niets met de UNO zelf te maken.
Ook lijkt het erop dat je probeert om via de Bluetooth poort een Seriele verbinding te maken. Of jij moet een hele speciale UNO hebben want anders gaat het zeker niet lukken.
Heb jij dit allemaal gevolgd?:https://www.arduino.cc/en/Guide/MacOSX
het kan inderdaad kloppen dat het een samenvoeging is van mac een windos want ik heb het ook op een laptop van windos geprobeerd maar daar werkte het ook niet en over het bleutooth ik gebruik dezez poort : /dec/cu.Bleutooth-Incoming-Port en ik kan ook /dev/cu.LARS12-SerialPort geruiken maar die werkt ook niet en ik heb de stappen gevolgd die u had gestuurd maar daarna werkte het nog steeds niet en gaf weer dezelfde error miss moet ik op windos werken
alvast bedankt
lars
alvast bedankt
lars
Ik weet niet wat je allemaal gedaan hebt maar bij mij draait het gewoon op beide platformen
