Code upload error
Code upload error
Ik ben nieuw op dit forum en nieuw met Arduino
heb een probleem met het uploaden compilen van de code krijg een foutmelding en ik heb geen benul waar ik het moet zoeken (code komt van internet)
bij voorbaat bedankt
foutmelding als volgt
Arduino: 1.6.9 (Windows XP), Board:"Arduino Uno"
C:\Program Files\Arduino\arduino-builder -dump-prefs -logger=machine -hardware "C:\Program Files\Arduino\hardware" -hardware "C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages" -tools "C:\Program Files\Arduino\tools-builder" -tools "C:\Program Files\Arduino\hardware\tools\avr" -tools "C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages" -built-in-libraries "C:\Program Files\Arduino\libraries" -libraries "C:\Documents and Settings\Administrator\Mijn documenten\Arduino\libraries" -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10609 -build-path "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build1335645b87bd7ca6708d95394b122a8b.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "M:\ZONNEPANEEL TRACKER SCHEMA\ADRINO CODE SOLARTRACKER REV 2\SolarTracker_Rev_2\SolarTracker_Rev_2.ino"
C:\Program Files\Arduino\arduino-builder -compile -logger=machine -hardware "C:\Program Files\Arduino\hardware" -hardware "C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages" -tools "C:\Program Files\Arduino\tools-builder" -tools "C:\Program Files\Arduino\hardware\tools\avr" -tools "C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages" -built-in-libraries "C:\Program Files\Arduino\libraries" -libraries "C:\Documents and Settings\Administrator\Mijn documenten\Arduino\libraries" -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10609 -build-path "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build1335645b87bd7ca6708d95394b122a8b.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "M:\ZONNEPANEEL TRACKER SCHEMA\ADRINO CODE SOLARTRACKER REV 2\SolarTracker_Rev_2\SolarTracker_Rev_2.ino"
Warning: Board Intel:i586:izmir_fd doesn't define a 'build.board' preference. Auto-set to: I586_IZMIR_FD
Warning: Board Intel:i586:izmir_fg doesn't define a 'build.board' preference. Auto-set to: I586_IZMIR_FG
Warning: Board Intel:i686:izmir_ec doesn't define a 'build.board' preference. Auto-set to: I686_IZMIR_EC
WAARSCHUWING: Foutieve map .github in bibliotheek 'Adafruit Motor Shield V2 Library'
WAARSCHUWING: Categorie '' in bibliotheek EEPROM is niet geldig. Wordt gewijzigd naar 'Uncategorized'
WAARSCHUWING: Categorie '' in bibliotheek SPI is niet geldig. Wordt gewijzigd naar 'Uncategorized'
WAARSCHUWING: Categorie '' in bibliotheek SoftwareSerial is niet geldig. Wordt gewijzigd naar 'Uncategorized'
WAARSCHUWING: Categorie '' in bibliotheek Wire is niet geldig. Wordt gewijzigd naar 'Uncategorized'
Warning: platform.txt from core 'Arduino AVR Boards' contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{build.path}/{archive_file}" "{object_file}", automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}". Consider upgrading this core.
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10609 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\arduino\hardware\avr\1.6.7\cores\arduino" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\arduino\hardware\avr\1.6.7\variants\standard" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build1335645b87bd7ca6708d95394b122a8b.tmp\sketch\SolarTracker_Rev_2.ino.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10609 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\arduino\hardware\avr\1.6.7\cores\arduino" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\arduino\hardware\avr\1.6.7\variants\standard" "-IC:\Program Files\Arduino\libraries\Servo\src" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build1335645b87bd7ca6708d95394b122a8b.tmp\sketch\SolarTracker_Rev_2.ino.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10609 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\arduino\hardware\avr\1.6.7\cores\arduino" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\arduino\hardware\avr\1.6.7\variants\standard" "-IC:\Program Files\Arduino\libraries\Servo\src" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\arduino\hardware\avr\1.6.7\libraries\Wire" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build1335645b87bd7ca6708d95394b122a8b.tmp\sketch\SolarTracker_Rev_2.ino.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10609 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\arduino\hardware\avr\1.6.7\cores\arduino" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\arduino\hardware\avr\1.6.7\variants\standard" "-IC:\Program Files\Arduino\libraries\Servo\src" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\arduino\hardware\avr\1.6.7\libraries\Wire" "-IC:\Program Files\Arduino\libraries\Adafruit_Motor_Shield_V2_Library_master" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build1335645b87bd7ca6708d95394b122a8b.tmp\sketch\SolarTracker_Rev_2.ino.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10609 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\arduino\hardware\avr\1.6.7\cores\arduino" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\arduino\hardware\avr\1.6.7\variants\standard" "-IC:\Program Files\Arduino\libraries\Servo\src" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\arduino\hardware\avr\1.6.7\libraries\Wire" "-IC:\Program Files\Arduino\libraries\Adafruit_Motor_Shield_V2_Library_master" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build1335645b87bd7ca6708d95394b122a8b.tmp\sketch\SolarTracker_Rev_2.ino.cpp" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build1335645b87bd7ca6708d95394b122a8b.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
M:\ZONNEPANEEL TRACKER SCHEMA\ADRINO CODE SOLARTRACKER REV 2\SolarTracker_Rev_2\SolarTracker_Rev_2.ino:32:45: fatal error: utility/Adafruit_PWMServoDriver.h: No such file or directory
#include "utility/Adafruit_PWMServoDriver.h"
compilation terminated.
Bibliotheek Servo op versie 1.1.2 in map: C:\Program Files\Arduino\libraries\Servo wordt gebruikt
Bibliotheek Wire op versie 1.0 in map: C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\arduino\hardware\avr\1.6.7\libraries\Wire wordt gebruikt
Bibliotheek Adafruit_Motor_Shield_V2_Library_master op versie 1.0.4 in map: C:\Program Files\Arduino\libraries\Adafruit_Motor_Shield_V2_Library_master wordt gebruikt
exit status 1
Fout bij het compileren van board Arduino Uno
exit status 1
Re: Code upload error
Hij kan deze file niet vinden"
Verder kan jij wel denken dat je met 1.6.9 werkt, maar je compileert met 1.6.7. Dus het lijkt erop dat je je 7-mijls laarzen hebt aangetrokken en daarmee gelijk de basis (de tutorials) hebt overgeslagen en nu door de bomen het bos niet meer ziet.
