Rfid probleempje
2 berichten
- Herman@vanderhaak.nl
- Geregistreerd: 08 Jun 2019, 09:16
Rfid probleempje
Dag,
Ik heb een sketch waarbij ik drie rfid chips wil uitlezen. Echter, elke chip mag maar door 1 specifieke reader worden geaccepteerd. Pas als alle drie de chips geplaatst zijn op de juiste reader mag het relais uit.
In onderstaand script werkt dat niet. Wie kan helpen?
#include <SPI.h>
#include <MFRC522.h>
// PIN Numbers : RESET + SDAs
#define RST_PIN 9
#define SS_1_PIN 10
#define SS_2_PIN 6
#define SS_3_PIN 7
// Buzzer en relais
#define buzzer 4
#define relayIN 5
// List of Tags UIDs that are allowed to open the puzzle
byte tagarray[][7] = {
{0x04, 0x48, 0xC4, 0x3A, 0xDA, 0x61, 0x80},
{0x04, 0x44, 0xC4, 0x3A, 0xDA, 0x61, 0x80},
{0x04, 0x40, 0xC4, 0x3A, 0xDA, 0x61, 0x80},
// {0xE6, 0xDF, 0xBB, 0x79},
// Inlocking status :
int tagcount = 0;
bool access = false;
#define NR_OF_READERS 3
byte ssPins[] = {SS_1_PIN, SS_2_PIN, SS_3_PIN};
MFRC522 mfrc522[NR_OF_READERS];
while (!Serial); )
SPI.begin();
pinMode(relayIN, OUTPUT);
digitalWrite(relayIN, HIGH);
pinMode(buzzer, OUTPUT);
digitalWrite(buzzer, LOW);
for (uint8_t reader = 0; reader < NR_OF_READERS; reader++) {
mfrc522[reader].PCD_Init(ssPins[reader], RST_PIN);
Serial.print(F("Reader "));
Serial.print(reader);
Serial.print(F(": "));
mfrc522[reader].PCD_DumpVersionToSerial();
if (mfrc522[reader].PICC_IsNewCardPresent() && mfrc522[reader].PICC_ReadCardSerial()) {
Serial.print(F(": Card UID:"));
dump_byte_array(mfrc522[reader].uid.uidByte, mfrc522[reader].uid.size);
Serial.println();
for (int x = 0; x < sizeof(tagarray); x++) // tagarray's row
for (int i = 0; i < mfrc522[reader].uid.size; i++)
if ( mfrc522[reader].uid.uidByte != tagarray
DenyingTag();
if (i == mfrc522[reader].uid.size - 1)
AllowTag();
continue;
if (access) break;
if (access)
if (tagcount == NR_OF_READERS)
OpenDoor();
MoreTagsNeeded();
UnknownTag();
mfrc522[reader].PICC_HaltA();
mfrc522[reader].PCD_StopCrypto1();
void dump_byte_array(byte * buffer, byte bufferSize) {
for (byte i = 0; i < bufferSize; i++) {
Serial.print(buffer < 0x10 ? " 0" : " ");
Serial.print(buffer, HEX);
void printTagcount() {
Serial.print("Tag n°");
Serial.println(tagcount);
void DenyingTag()
tagcount = tagcount;
access = false;
void AllowTag()
tagcount = tagcount + 1;
access = true;
void Initialize()
tagcount = 0;
access = false;
void OpenDoor()
Serial.println("Welcome! the door is now open");
Initialize();
digitalWrite(relayIN, LOW);
digitalWrite(buzzer, HIGH);
delay(100);
delay(100);
void MoreTagsNeeded()
printTagcount();
Serial.println("System needs more cards");
delay(100);
delay(100);
access = false;
void UnknownTag()
Serial.println("This Tag isn't allowed!");
printTagcount();
for (int flash = 0; flash < 5; flash++)
delay(100);
#include <SPI.h>
#define RST_PIN 9
#define SS_1_PIN 10
#define SS_2_PIN 6
#define SS_3_PIN 7
// Buzzer en relais
#define buzzer 4
#define relayIN 5
int tagcount = 0;
while (!Serial); )
SPI.begin();
Serial.println();
DenyingTag();
AllowTag();
continue;
if (access) break;
if (access)
OpenDoor();
MoreTagsNeeded();
UnknownTag();
void DenyingTag()
access = false;
void AllowTag()
access = true;
void Initialize()
tagcount = 0;
access = false;
void OpenDoor()
Initialize();
delay(100);
delay(100);
printTagcount();
delay(100);
delay(100);
access = false;
void UnknownTag()
printTagcount();
delay(100);
Re: Rfid probleempje
schrijf er eens kommentaar bij en teken een flowschema van het programma.
doe eens CTRL T en zet de code in code tags dan kunne wij het sneller lezen.
2 berichten
Gebruikers in dit forum: Google Adsense [Bot] en 78 gasten
