zomer en winterstand
beste allemaal .
ben al een tijdje aan het proberen , de zomer en winter stand voor elkaar te krijgen
helaas doe ik iets niet goed en/of ik snap hem niet !
de instructies heb ik van https://www.instructables.com/The-Ardui ... me-Europe/
heb de tekst zorgvuldig doorgenomen , maar loop vast
kan iemand mij helpen ?
#include <DHT.h>
#include <DS3231.h>
#include <Timezone.h>
DS3231 rtc(SDA, SCL);
Time t;
LiquidCrystal_I2C lcd(0x27,20,4); // set the LCD address to 0x27 for a 16 chars and 2 line display
//Constants
#define DHTPIN 7 // what pin we're connected to
#define DHTTYPE DHT22 // DHT 22 (AM2302)
DHT dht(DHTPIN, DHTTYPE); //// Initialize DHT sensor for normal 16mhz Arduino
int FanRelay = 38;
int Relay = 36;
const int OnHour = 22; //SET TIME TO ON RELAY (24 HOUR FORMAT)
const int OnMin = 55;
const int OffHour = 22; //SET TIME TO OFF RELAY
const int OffMin = 56;
unsigned long previousMillis = 0; // will store last time LED was updated
// constants won't change:
unsigned long interval = 2000; // interval at which to blink (milliseconds)
//Variables
//int chk;
float hum; //Stores humidity value
float temp; //Stores temperature value
rtc.begin();
// The following lines can be uncommented to set the date and time
//rtc.setDOW(SATURDAY); // Set Day-of-Week to SUNDAY
//rtc.setTime(21,33, 0); // Set the time to 12:00:00 (24hr format)
//rtc.setDate(8, 8, 2020); // Set the date to January 1st, 2014
pinMode(FanRelay, OUTPUT);
pinMode(Relay, OUTPUT);
digitalWrite(Relay, LOW);
Serial.println("ppdo's Temp and Humidity Sensor Test");
dht.begin();
lcd.init(); //initialize the lcd
lcd.backlight(); //open the backlight
rtc.begin(); // Initialize the rtc object
lcd.begin(16,4); // Initializes the interface to the LCD screen, and specifies the dimensions (width and height) of the display }
//Read data and store it to variables hum and temp
// Reading temperature or humidity takes about 250 milliseconds!
// save the last time you blinked the LED
hum = dht.readHumidity();
temp= dht.readTemperature();
//Print temp and humidity values to serial monitor
Serial.print("Humidity: ");
Serial.print(hum);
Serial.print(" %, Temp: ");
Serial.print(temp);
Serial.println(" Celsius");
// set the cursor to (0,0):
lcd.setCursor(0, 3);
// print from 0 to 9:
lcd.print("Temp: ");
lcd.print(temp);
lcd.print(" C");
lcd.setCursor(0, 2);
lcd.print("Humidity: ");
lcd.print(hum);
lcd.print(" %");
if(( float) temp >50 ){
digitalWrite(FanRelay, HIGH);
}else{
digitalWrite (FanRelay, LOW);
t = rtc.getTime();
lcd.setCursor(0,1);
lcd.print("Time: ");
lcd.print(rtc.getTimeStr());
lcd.setCursor(0,0);
lcd.print("Date: ");
lcd.print(rtc.getDateStr());
if(t.hour == OnHour && t.min == OnMin){
digitalWrite(Relay,HIGH);
Serial.println("LIGHT ON");
else if(t.hour == OffHour && t.min == OffMin){
digitalWrite(Relay,LOW);
Serial.println("LIGHT OFF");
if (dow == 7 && mo == 10 && d >= 25 && h == 3 && DST==1)
setclockto 2 am;
DST=0;//store this in your NVRAM
Re: zomer en winterstand
die DST moet je dan wel gebruiken dat vind ik nergens terug, staat ergens denk ik in timezone, en die DST moet dan 1 zijn natuurlijk boven in de loop of zo
dat ligt aan de libraries die je gebruikt.
Hoi Paul, ik denk dat ik een fout maak , de DST is een flag bestand en deze heb ik nog niet toegevoegd zie ik nu
ben opnieuw begonnen en had iets gevonden
heb er veel op zitten studeren, maar gaat iets fout ergens zit iets niet goed.
kan het zijn dat lcd.print(rtc.getTimeStr()); vervangen moet worden in DateTime t2 = rtc.now(); ?
#include <EEPROM.h>
#include <RTClib.h>
#include <DS3231.h>
#include <LiquidCrystal.h> // includes the LiquidCrystal Library
//DS3231 rtc(SDA, SCL);
LiquidCrystal lcd(1, 2, 4, 5, 6, 7); // Creates an LC object. Parameters: (rs, enable, d4,
RTC_DS3231 rtc;
int DST;
DST = EEPROM.get(0, DST);
if(DST != 0 && DST != 1)
lcd.begin(16,2); //
DST = 1;
EEPROM.put(0, DST);
// Uncomment the following 2 lines if you need to set the DST (if you miss the actual day etc). Change the +1 to -1 in the fall.
// DateTime t2 = rtc.now();
// rtc.adjust(DateTime(t2.year(), t2.month(), t2.day(), t2.hour()+1, t2.minute(), t2.second()));
DateTime now = rtc.now();
if (now.dayOfTheWeek() == 0 && now.month() == 3 && now.day() >= 8 && now.day() <= 16 && now.hour() == 2 && now.minute() == 0 && now.second() == 0 && DST == 0)
rtc.adjust(DateTime(now.year(), now.month(), now.day(), now.hour()+1, now.minute(), now.second()));
DST = 1;
EEPROM.put(0, DST);
else if(now.dayOfTheWeek() == 0 && now.month() == 11 && now.day() >= 1 && now.day() <= 8 && now.hour() == 2 && now.minute() == 0 && now.second() == 0 && DST == 1)
rtc.adjust(DateTime(now.year(), now.month(), now.day(), now.hour()-1, now.minute(), now.second()));
DST = 0;
EEPROM.put(0, DST);
lcd.setCursor(0,0);
lcd.setCursor(0,1);
