expected constructor error
Als ik onderstaande code compileer krijg ik volgende error:
expected constructor, destructor, or type conversion before ';' token
wie kan mij helpen?
wie kan mij helpen?
#include <Arduino.h>
//Declare all the variables being used here:
int centerIR;
int leftIR;
int rightIR;
int leftFlag;
int centerFlag;
int rightFlag;
//Declare all the functions being used here:
voiddeviateRight();
voiddeviateLeft();
voidforward();
voidreverse();
voidsetup();
pinMode(6, OUTPUT);
pinMode(9, OUTPUT);
pinMode(10, OUTPUT);
pinMode(11, OUTPUT);
pinMode(7, OUTPUT);
pinMode(8, OUTPUT);
digitalWrite(7, HIGH);
digitalWrite(8, HIGH);
Serial.begin(115200);
voidloop()
centerIR = analogRead(A0);
leftIR = analogRead(A1);
rightIR = analogRead(A2);
if (leftIR < 200)
leftFlag = 1;
leftFlag = 0;
if (rightIR < 200)
rightFlag = 1;
rightFlag = 0;
if (centerIR < 200)
centerFlag = 1;
centerFlag = 0;
if ((leftFlag == 1) || (rightFlag == 1) || (centerFlag == 1))
if (centerFlag == 1)
if (leftFlag == 1)
deviateRight();
elseif (rightFlag == 1)
deviateLeft();
deviateLeft();
elseif (leftFlag == 1)
deviateRight();
deviateLeft();
deviateLeft();
forward();
//Function definitions go here:
voidreverse();
Serial.println("Backing up");
digitalWrite(9, LOW);
analogWrite(6, 75);
analogWrite(11, 75);
digitalWrite(10, LOW);
voiddeviateRight();
Serial.println("Right");
reverse();
digitalWrite(6, LOW);
digitalWrite(11, LOW);
analogWrite(10, 350);
delay(300);
voiddeviateLeft();
Serial.println("Left");
reverse();
analogWrite(9, 350);
delay(300);
voidforward();
Serial.println("Forward");
analogWrite(9, 75);
analogWrite(10, 75);
Re: expected constructor error
Een paar ; teveel vanaf voidreverse();
dus void reverse()
void forward
void deviate
enz
en spatie gebruiken in void setup() en loop ,ook de else if constructies nazien op spelling.
Ook eens kijken om een switch case te maken ipv al die if else constructies.
dus void reverse()
void forward
void deviate
enz
