zero cross
zero cross
ik heb een code gevonden voor zerro cross.
echter zit hier een bibliotheek bij waar van ik de "hw timer "niet kan vinden .
kan iemand mij helpen
[code]#include "hw_timer.h"
const byte zcPin = 12;
const byte pwmPin = 13;
byte fade = 1;
byte state = 1;
byte tarBrightness = 255;
byte curBrightness = 0;
byte zcState = 0; // 0 = ready; 1 = processing;
Serial.begin(115200);
pinMode(zcPin, INPUT_PULLUP);
pinMode(pwmPin, OUTPUT);
attachInterrupt(zcPin, zcDetectISR, RISING); // Attach an Interupt to Pin 2 (interupt 0) for Zero Cross Detection
hw_timer_init(NMI_SOURCE, 0);
hw_timer_set_func(dimTimerISR);
if (Serial.available()){
int val = Serial.parseInt();
if (val>0){
tarBrightness =val;
Serial.println(tarBrightness);
void dimTimerISR() {
if (fade == 1) {
if (curBrightness > tarBrightness || (state == 0 && curBrightness > 0)) {
--curBrightness;
else if (curBrightness < tarBrightness && state == 1 && curBrightness < 255) {
++curBrightness;
if (state == 1) {
curBrightness = tarBrightness;
curBrightness = 0;
if (curBrightness == 0) {
state = 0;
digitalWrite(pwmPin, 0);
else if (curBrightness == 255) {
state = 1;
digitalWrite(pwmPin, 1);
zcState = 0;
void zcDetectISR() {
if (zcState == 0) {
zcState = 1;
if (curBrightness < 255 && curBrightness > 0) {
int dimDelay = 30 * (255 - curBrightness) + 400;//400
hw_timer_arm(dimDelay);
}[/code]
Re: zero cross
google? eerste hit is prijs....
Re: zero cross
jij schrijft eerst dat zcpin =12 echter de interupt zit op pin2
