lijnrobot freenove laten pauzeren
- Robbbbbert
- Geregistreerd: 30 Apr 2021, 16:04
Hoi,
Ik heb een lijnrobot die ik af en toe zou willen laten ´pauzeren´. Ik krijg dit niet voor elkaar met bv een delay. Maar misschien zet ik deze verkeerd.
Heeft iemand een idee?
Dit is de code:
#include "Freenove_4WD_Car_for_Arduino.h"
#define TK_STOP_SPEED 0
#define TK_FORWARD_SPEED (90 + tk_VoltageCompensationToSpeed )
//define different speed levels
#define TK_TURN_SPEED_LV4 (180 + tk_VoltageCompensationToSpeed )
#define TK_TURN_SPEED_LV3 (150 + tk_VoltageCompensationToSpeed )
#define TK_TURN_SPEED_LV2 (-140 + tk_VoltageCompensationToSpeed )
#define TK_TURN_SPEED_LV1 (-160 + tk_VoltageCompensationToSpeed )
int tk_VoltageCompensationToSpeed; //define Voltage Speed Compensation
pinsSetup(); //set up pins
getTrackingSensorVal();//Calculate Voltage speed Compensation
u8 trackingSensorVal = 0;
trackingSensorVal = getTrackingSensorVal(); //get sensor value
switch (trackingSensorVal)
case 0: //000
motorRun(TK_FORWARD_SPEED, TK_FORWARD_SPEED); //car move forward
case 7: //111
motorRun(TK_STOP_SPEED, TK_STOP_SPEED); //car stop
case 1: //001
motorRun(TK_TURN_SPEED_LV4, TK_TURN_SPEED_LV1); //car turn
case 3: //011
motorRun(TK_TURN_SPEED_LV3, TK_TURN_SPEED_LV2); //car turn right
case 2: //010
case 5: //101
case 6: //110
motorRun(TK_TURN_SPEED_LV2, TK_TURN_SPEED_LV3); //car turn left
case 4: //100
motorRun(TK_TURN_SPEED_LV1, TK_TURN_SPEED_LV4); //car turn right
default:
void tk_CalculateVoltageCompensation() {
getBatteryVoltage();
float voltageOffset = 7 - batteryVoltage;
tk_VoltageCompensationToSpeed = 30 * voltageOffset;
//when black line on one side is detected, the value of the side will be 0, or the value is 1
u8 getTrackingSensorVal() {
trackingSensorVal = (digitalRead(PIN_TRACKING_LEFT) == 1 ? 1 : 0) << 2 | (digitalRead(PIN_TRACKING_CENTER) == 1 ? 1 : 0) << 1 | (digitalRead(PIN_TRACKING_RIGHT) == 1 ? 1 : 0) << 0;
return trackingSensorVal;
Dit is de code:
case 0: //000
case 7: //111
case 1: //001
case 3: //011
case 2: //010
case 5: //101
case 6: //110
case 4: //100
default:
Re: lijnrobot freenove laten pauzeren
zet in de case 5 even een delay van bijvoorbeeld 5000 dus delay(5000) dan staat het stil, echter zul je merken dat als de sensor niet verandert de kar stil blijft staan, dus zet eronder even een seconde vooruit bijvoorbeeld.
later zul je dat op gaan lossen met een millis() timer
ik zie overal u8 voor staan dat werkt dus ook niet goed, eenmaal declareren is genoeg.en jouw trackingsensorval berekening is wel erg ingewikkeld lijkt alhoewel goed te werken.
Robbbbbert schreef:Hoi,
Waar, wanneer, en vooral, waarom?
(om het: "hoe en wat gepauzeerd dient te worden", nog even buiten beschouwing te laten)
