IR bediening voor LED
Ik heb de volgende code, zie onderstaande.
Hiermee doe ik 4 Led's schakelen.
Nu had ik gaarne dat de Led's met knop-5 met de waarde 255 allen uit gaan.
Wie kan me hier mee verder helpen??
Ik hoor het graag.
Mvg Bert
#include <IRremote.h> //including the remote library
#define knop_1 16575 // code gegeven door knop_1
#define knop_2 49215 // code gegeven door knop_2
#define knop_3 8415 // code gegeven door knop_3
#define knop_4 41055 // code gegeven door knop_4
#define knop_5 255 // code gegeven door knop_5
int receiver_pin = 2; //Aansluiting output pin van de IR receiver.
//initializing the pins for leds
int led_1 = 4;
int led_2 = 5;
int led_3 = 6;
int led_4 = 7;
int led_state[] = {0,0,0,0,0}; //The initial state of the led's will be high
IRrecv receiver(receiver_pin); //Arduino will take output of IR receiver from pin 2
decode_results output;
receiver.enableIRIn(); // Start to take the output from IR receiver
//initializing all the pins where we have connected the led's as output pins
pinMode(led_1, OUTPUT);
pinMode(led_2, OUTPUT);
pinMode(led_3, OUTPUT);
pinMode(led_4, OUTPUT);
if (receiver.decode(&output)) {
unsigned int value = output.value;
switch(value) {
case knop_1:
if(led_state[1] == 1) { // checking whether the previous state is on or not
digitalWrite(led_1, LOW); //zet eerste led UIT
led_state[1] = 0; //zet de status op LOW
} else { //Als de eerste LED uit is
digitalWrite(led_1, HIGH); //Zet hem AAN
led_state[1] = 1; //zet de status op HOOG
case knop_2:
if(led_state[2] == 1) {
digitalWrite(led_2, LOW); //zet tweede led UIT
led_state[2] = 0; //zet de status op LOW
} else { //Als de tweede LED uit is
digitalWrite(led_2, HIGH); //Zet hem AAN
led_state[2] = 1; //zet de status op HOOG
case knop_3:
if(led_state[3] == 1) {
digitalWrite(led_3, LOW);
led_state[3] = 0;
digitalWrite(led_3, HIGH);
led_state[3] = 1;
case knop_4:
if(led_state[4] == 1) {
digitalWrite(led_4, LOW);
led_state[4] = 0;
digitalWrite(led_4, HIGH);
led_state[4] = 1;
Serial.println(value);
receiver.resume();
Ik hoor het graag.
Mvg Bert
int led_1 = 4;
int led_2 = 5;
int led_3 = 6;
int led_4 = 7;
switch(value) {
case knop_1:
case knop_2:
case knop_3:
led_state[3] = 0;
led_state[3] = 1;
case knop_4:
led_state[4] = 0;
led_state[4] = 1;
receiver.resume();
Re: IR bediening voor LED
Zijn alle leds uit bij aanzetten ?
En de uitgang op HIGH is de led aan ?
Dan is het een kwestie van alles uit zetten.
Ik had zomaar zin om allerlei ideeën neer te zetten
Misschien zie je er iets tussen dat je aanspreekt.
Met een for-loop is leuker:
Je kunt ook de sizeof() gebruiken, dan gaat de compiler kijken hoe groot het array is in bytes.
Met "sizeof(led_state)" maakt de compiler daar "10" van.
Met "sizeof(int)" maakt de compiler daar "2" van (voor een Arduino Uno).
Die twee delen voor het aantal elementen van het array.
Dat is de ouderwetse manier. In de C++ taal zitten modernere dingen om met arrays om te gaan.
Je kunt het array "led_state" als integers gebruiken zoals nu, je kunt er ook booleans van maken (true of false), en je kunt er meteen HIGH of LOW in zetten. Met HIGH en LOW is het minder abstract en misschien te direct, maar in een Arduino sketch is dat vaak het duidelijkste.
Dat kan korter:
Je kunt ook een variabele nemen en die 0, 1, 2, 3 maken voor de ingedrukte knop. Dan kun je dat meteen als index van een array gebruiken.
Bijvoorbeeld:
En daar knop 5 aan toevoegen is die aparte knop apart in code zetten:
Heb je zo genoeg om op te kauwen
case knop_5:
led_state[0] = 0;
led_state[1] = 0;
led_state[2] = 0;
led_state[3] = 0;
led_state[4] = 0;
case knop_5:
for( int i=0; i<5; i++)
led_state[i] = 0;
for( int i=0; i<sizeof(led_state)/sizeof(int); i++)
led_state[i] = 0;
int led_state[] = {LOW, LOW, LOW, LOW, LOW};
if( led_state[1] == LOW)
led_state[1] = HIGH;
led_state[1] = LOW;
digitalWrite(led_1, led_state[1];
Dat kan korter:
led_state[1] = LOW ? HIGH : LOW; // toggle de state
Bijvoorbeeld:
int led_pin[] = { 4, 5, 6, 7);
int led_state[] = { LOW, LOW, LOW, LOW};
// knop waarde -1 betekend niet ingedrukt, 0 tot en met 3 is de index, overeenkomend met knop 1 tot en met 4.
int index = -1; // -1 is default, geen knop ingedrukt.
switch( value)
case knop_1:
index = 0;
case knop_2:
index = 1;
case knop_3:
index = 2;
case knop_4:
index = 3;
if( index > -1)
led_state[index] = LOW ? HIGH : LOW; // toggle de state
digitalWrite( led_pin[index], led_state[index]);
int indexToggle = -1; // -1 is default, geen knop ingedrukt.
switch( value)
case knop_1:
indexToggle = 0;
case knop_2:
indexToggle = 1;
case knop_3:
indexToggle = 2;
case knop_4:
indexToggle = 3;
case knop_5:
for( int i=0; i<4; i++)
led_state[i] = LOW;
digitalWrite( led_pin[i], LOW);
if( indexToggle > -1 && indexToggle < 4)
led_state[indexToggle] = LOW ? HIGH : LOW; // toggle de state
digitalWrite( led_pin[indexToggle], led_state[indexToggle]);
Hallo Koepel.
Bedankt voor je reactie.
Ik heb gelijk het eerste advies in mijn code gezet en getest.
Het werkt zoals ik het wilde
Bedankt voor deze.
Bedankt voor deze.
Gebruikers in dit forum: KeithGam en 56 gasten
