servo verplaatsen van a naar b
12 berichten
Re: servo verplaatsen van a naar b
dat komt door de plaatsing van die haken, de laatste keer werd de delay elke graad uitgevoerd, en de eerste was alleen maar aan het einde van de for loop.
Probleem opgelost.
/* LDR_drives_servo 60819
* Created: 16-08-2019
* Software version: 1.8.9
* Board: arduino mega
ldr connected to 5v to a0 and 10k resistor to ground
write ldr a0 analog value to arduino ide serial terminal
turn onboard leds on or off depending off ldr value
Open or close door depending off LDR value.
// define variables for servo use
#include <Servo.h>
int pos = 0; // punt a van de servo
// define variables for led's and LDR
#define LDRpin A0 // pin where we connected the LDR and the resistor
int LDRValue = 0; // variable to store the value coming from the sensor
boolean x = true;
int ledGPin=8; // Red Led
int ledRPin=9; // Green led
// the setup routine runs once when you press reset:
myservo.attach(11); // attaches the servo on pin 11 to the servo object
pinMode(ledGPin, OUTPUT);// initialize the digital pin as an output.
pinMode(ledRPin, OUTPUT);
Serial.begin(9600); //sets serial port for communication
// the loop routine runs over and over again forever:
LDRValue = analogRead(A0);
Serial.println(LDRValue);
delay(50);
if ( LDRValue < 300 && x == true){
digitalWrite(ledGPin,LOW);
digitalWrite(ledRPin,HIGH);
x = false;
delay(50);
OpenDoor();
else if ( LDRValue >300 && x == false){
x = true;
digitalWrite(ledGPin,HIGH);
digitalWrite(ledRPin,LOW);
delay(50);
CloseDoor();
void CloseDoor()
for ( pos = 0; pos <= 180; pos += 1) // goes from 0 degrees to 180 degrees in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(15); // waits 15ms for the servo to reach the position
void OpenDoor()
for (pos = 180; pos >= 0; pos -= 1) // goes from 180 degrees to 0 degrees
12 berichten
