Wie kan mij helpen met probleem bluetooth en keypad ?
mijn probleem is dat ik dit programma wil kunnen starten met drukken op keypad A maar ook via bluetooth dit wil kunnen .
heb al wat dingen geprobeerd maar werkt niet .
al vast dank.
al vast dank.
#include <Keypad_I2C.h>
#include <Password.h>
int passwd_pos = 7;
Password password = Password("1958");
char BluetoothData = 0;
int adress = 0x38;
const byte ROWS = 4;
const byte COLS = 4;
char keys[ROWS][COLS] = {
{'1', '2', '3', 'A'},
{'4', '5', '6', 'B'},
{'7', '8', '9', 'C'},
{'*', '0', '#', 'D'}
byte rowPins[ROWS] = {0, 1, 2, 3};
byte colPins[COLS] = {4, 5, 6, 7};
Keypad_I2C keypad = Keypad_I2C( makeKeymap(keys), rowPins, colPins, ROWS, COLS, adress );
const int kamerPin = 2;
const int keukenPin = 3;
const int slaapkamerPin = 4;
const int gangPin = 5;
const int TrPin = 6;
const int RelayPin = 11;
const int bleuPin = 8;
const int redPin = 9;
const int greenPin = 10;
const int ledError = 50;
const int timeDelay = 10000;
int alarmStatus = 0;
int alarmActive = 0;
lcd.begin();
lcd.backlight();
keypad.begin();
pinMode(RelayPin, OUTPUT);
pinMode(kamerPin, INPUT);
pinMode(keukenPin, INPUT);
pinMode(slaapkamerPin, INPUT);
pinMode(gangPin, INPUT);
pinMode(TrPin, OUTPUT);
pinMode(redPin, OUTPUT);
pinMode(bleuPin, OUTPUT);
pinMode(greenPin, OUTPUT);
keypad.addEventListener(keypadEvent);
digitalWrite(greenPin, HIGH);
digitalWrite(RelayPin, HIGH);
displayCodeBlock();
keypad.getKey();
if (alarmActive == 1) {
int val1 = digitalRead(kamerPin);
int val2 = digitalRead(slaapkamerPin);
int val3 = digitalRead(gangPin);
int val4 = digitalRead(keukenPin);
if (val1 == HIGH || val2 == HIGH || val3 == HIGH || val4 == HIGH) {
alarmTriggered();
void keypadEvent(KeypadEvent eKey) {
switch (keypad.getState()) {
case PRESSED:
if (passwd_pos - 15 >= 5) {
return ;
lcd.setCursor((passwd_pos++), 0);
switch (eKey) {
case'A':
activate();
case'C':
deactivate();
case '#':
passwd_pos = 7;
checkPassword();
delay (1000);
case '*':
password.reset();
passwd_pos = 7;
default:
password.append(eKey);
lcd.print("*");
if (Serial.available())
BluetoothData = Serial.read();
if ( BluetoothData == 'A' )
{ activate();
if (BluetoothData == 'a')
deactivate();
void alarmTriggered() {
password.reset();
alarmStatus = 0;
digitalWrite(redPin, HIGH);
digitalWrite(bleuPin, HIGH);
digitalWrite(TrPin, HIGH);
lcd.clear();
displayCodeUnBlock();
StrokeLight(); {
void StrokeLight() {
for (int i = 0; i <= 10; i++) {
if (i % 2) {
digitalWrite(redPin, LOW);
delay(ledError);
if (i % 2) {
digitalWrite(bleuPin, LOW);
delay(ledError);
delay(100);
void checkPassword() {
if (password.evaluate()) {
if (alarmActive == 0 && alarmStatus == 0) {
activate();
else if ( alarmActive == 1 || alarmStatus == 1) {
deactivate();
invalidCode();
void invalidCode() {
password.reset();
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Toegang geweigerd");
ledInvalid();
void ledInvalid() {
if (i % 2) {
delay(ledError);
delay(200);
displayCodeBlock();
delay(200);
void activate() {
alarmActive = 1;
password.reset();
lcd.clear();
lcd.print("Systeem actief");
delay(timeDelay);
void deactivate() {
alarmStatus = 0;
alarmActive = 0;
password.reset();
digitalWrite(RelayPin, LOW);
digitalWrite(TrPin, LOW);
lcd.clear();
lcd.print("Gedeactiveerd");
displayCodeBlock();
void displayCodeUnBlock() {
lcd.clear();
lcd.print("Code:");
lcd.setCursor(0, 1);
lcd.print("Deactiveren");
deactivate();
void displayCodeBlock() {
lcd.clear();
lcd.print("A om te ");
lcd.print("Activeren");
Re: Wie kan mij helpen met probleem bluetooth en keypad ?
Werkt het display ?
Dan kun je de binnenkomende Bluetooth tekens op het scherm zetten om te kijken of de Bluetooth werkt. Het beste kun je daarvoor een aparte test-sketch maken.
Zit de Bluetooth aan de "Serial" ? Op welk Arduino board is dat ?
Normaal gesproken worden in de loop() alle belangrijke dingen gedaan. Bijvoorbeeld kijken of iemand een knop indrukt, en kijken of er iets binnenkomt via Bluetooth.
Je hebt het inlezen van Bluetooth verstopt ergens in een functie in een dubbele switch-case-statement. Het zijn geen paaseieren. Mijn voorkeur zou zijn om altijd de Bluetooth tekens in te lezen in de loop() en dan met code alle gegevens verwerken.
kijk of iemand op het keypad drukt
kijk of er iets via bluetooth binnen komt
doe iets
de manier die ik gebruik met bluetooth werkt, perfect.
alleen in dit progje nog niet .
het moet zo zijn dat als ik buiten sta het alarm af kan zetten met bluetooth.
Het schema dat je nu ziet is een porbeersel om dit zo te krijgen en heb al veel dingen geprobeerd.
Volgens mij moet het stukje voor het afvragen van de blue-tooth verhuizen naar de loop.
Om je systeem in en uit te schakelen is dit misschien wel leuk maar normaliter moet je voorzien
in een inloop en uitloop tijd voor de exit zone met eventueel een volgzone.
Je kunt dan pas inschakelen als alle andere zones in rust zijn en heb je de tijd om de perimeter te verlaten.
In sommige gevallen wordt zelfs een zone tijdelijk overbrugt om dan al of niet automatisch in te schakelen.
