Fout in Sketch
Fout in Sketch
Ik heb een sketch die ik graag wil draaien, maar er zit een fout in.
Heb zelf al een hoop geprobeerd, maar kom er niet uit.
De fout is "Arduino: 1.8.2 (Windows 10), Board:"Arduino/Genuino Uno"
Morse_beacon:122: error: two or more data types in declaration of 'setup'
exit status 1
Ik hoop dat iemend de fout kan ontdekken!
Het gebeurd met dit programma:
exit status 1
// Simple Arduino Morse Beacon
// Written by Mark VandeWettering K6HX
// Email: k6hx@arrl.net
// This code is so trivial that I'm releasing it completely without
// restrictions. If you find it useful, it would be nice if you dropped
// me an email, maybe plugged my blog @ https://brainwagon.org or included
// a brief acknowledgement in whatever derivative you create, but that's
// just a courtesy. Feel free to do whatever.
struct t_mtab { char c, pat; } ;
struct t_mtab morsetab[] = {
{'.', 106},
{',', 115},
{'?', 76},
{'/', 41},
{'A', 6},
{'B', 17},
{'C', 21},
{'D', 9},
{'E', 2},
{'F', 20},
{'G', 11},
{'H', 16},
{'I', 4},
{'J', 30},
{'K', 13},
{'L', 18},
{'M', 7},
{'N', 5},
{'O', 15},
{'P', 22},
{'Q', 27},
{'R', 10},
{'S', 8},
{'T', 3},
{'U', 12},
{'V', 24},
{'W', 14},
{'X', 25},
{'Y', 29},
{'Z', 19},
{'1', 62},
{'2', 60},
{'3', 56},
{'4', 48},
{'5', 32},
{'6', 33},
{'7', 35},
{'8', 39},
{'9', 47},
{'0', 63}
#define N_MORSE (sizeof(morsetab)/sizeof(morsetab[0]))
#define SPEED (12)
#define DOTLEN (1200/SPEED)
#define DASHLEN (3*(1200/SPEED))
int LEDpin = 13 ;
void
dash()
digitalWrite(LEDpin, HIGH) ;
delay(DASHLEN);
digitalWrite(LEDpin, LOW) ;
delay(DOTLEN) ;
void
dit()
delay(DOTLEN);
delay(DOTLEN);
void
send(char c)
int i ;
if (c == ' ') {
Serial.print(c) ;
delay(7*DOTLEN) ;
return ;
for (i=0; i<N_MORSE; i++) {
if (morsetab[i].c == c) {
unsigned char p = morsetab[i].pat ;
Serial.print(morsetab[i].c) ;
while (p != 1) {
if (p & 1)
dash() ;
dit() ;
p = p / 2 ;
delay(2*DOTLEN) ;
return ;
/* if we drop off the end, then we send a space */
Serial.print("?") ;
void
sendmsg(char *str)
while (*str)
send(*str++) ;
Serial.println("");
pinMode(LEDpin, OUTPUT) ;
Serial.begin(9600) ;
Serial.println("Simple Arduino Morse Beacon v0.0") ;
Serial.println("") ;
sendmsg("PA3XXX") ;// hier de tekst om te zenden.
delay(3000) ;
Re: Fout in Sketch
Selecteer met je muis je eigen sketch van hierboven, en plak die in een nieuwe sketch. Compileert het dan wel ?
Als dat niet werkt, update dan naar de nieuwste versie, dat is nu Arduino IDE 1.8.5.
Lukt het dan nog niet, dan zijn er misschien nog oude Arduino of Java bestanden op je computer die de boel in de war sturen.
Re: Fout in Sketch
Zelfde error melding met 1.8.5
Void setup() bovenaan plaatsen zoals het hoort en de boel compileert zonder probleem.
{'.', 106},
{',', 115},
{'?', 76},
{'/', 41},
{'A', 6},
{'B', 17},
{'C', 21},
{'D', 9},
{'E', 2},
{'F', 20},
{'G', 11},
{'H', 16},
{'I', 4},
{'J', 30},
{'K', 13},
{'L', 18},
{'M', 7},
{'N', 5},
{'O', 15},
{'P', 22},
{'Q', 27},
{'R', 10},
{'S', 8},
{'T', 3},
{'U', 12},
{'V', 24},
{'W', 14},
{'X', 25},
{'Y', 29},
{'Z', 19},
{'1', 62},
{'2', 60},
{'3', 56},
{'4', 48},
{'5', 32},
{'6', 33},
{'7', 35},
{'8', 39},
{'9', 47},
{'0', 63}
#define SPEED (12)
int LEDpin = 13 ;
void dash()
delay(DASHLEN);
delay(DOTLEN) ;
void dit()
delay(DOTLEN);
delay(DOTLEN);
void send(char c)
int i ;
if (c == ' ') {
Serial.print(c) ;
delay(7*DOTLEN) ;
return ;
while (p != 1) {
if (p & 1)
dash() ;
dit() ;
p = p / 2 ;
delay(2*DOTLEN) ;
return ;
Serial.print("?") ;
void sendmsg(char *str)
while (*str)
send(*str++) ;
Serial.println("");
delay(3000) ;
Arduinows!
Re: Fout in Sketch
Yes!!!
Dat was het. Nu ben ik nog een newbie, maar vreemd dat de auteur het op die manier gemaakt heeft.
Maar inderdaad, de VOID naar het begin, en het werkt.
BEDANKT,
Ruud.
BEDANKT,
Ruud.
