Deze code wil ik invoegen in mijn alarm instalatie
9 berichten
Heb deze sirene gevonden en wil deze in mijn script voor de alarminstallatie voegen maar krijg deze melding, wat te doen.
Tone.cpp.o (symbol from plugin): In function `timer0_pin_port':
(.text+0x0): multiple definition of `__vector_7'
libraries\NewPing\NewPing.cpp.o (symbol from plugin):(.text+0x0): first defined here
deze werkt wel als die dus niet wordt geïmporteerd
code zoals ik hem er nu in heb gezet .
const int pitchLow = 200;
const int pitchHigh = 1000;
int pitchStep = 10;
int currentPitch;
int delayTime;
const int speakerPin = 8;
currentPitch = pitchLow;
delayTime = 10;
Sound();
void Sound() {
tone(speakerPin, currentPitch, 10);
currentPitch += pitchStep;
if(currentPitch >= pitchHigh) {
pitchStep = -pitchStep;
else if(currentPitch <= pitchLow) {
delay(delayTime);
#include <Keypad_I2C.h>
#include <Keypad.h>
#include <NewPing.h>
#include "NewTone.h"
int pitchStep = 10;
int currentPitch;
int delayTime;
const byte numRows = 4;
const byte numCols = 4;
char keypressed;
char keymap[numRows][numCols] =
{'1', '2', '3', 'A'},
{'4', '5', '6', 'B'},
{'7', '8', '9', 'C'},
{'*', '0', '#', 'D'}
int adress = 0x38;
byte rowPins[numRows] = {0, 1, 2, 3};
byte colPins[numCols] = {4, 5, 6, 7};
Keypad_I2C myKeypad = Keypad_I2C(makeKeymap(keymap), rowPins, colPins, numRows, numCols, adress);
const int buzzer = A1;
const int Slaapkamer = 2;
const int Woonkamer = 3;
const int Keuken = 4;
//const int Led = 5;//reserver
const int RedLed = 6;
const int BleuLed = 7;
const int GreenLed = 8;
const int speakerPin = 9;
const int Relay = 12;
NewPing sonar(A0, A0, 2000);
String password = "1958";
String tempPassword = "";
int doublecheck;
boolean armed = false;
boolean input_pass;
boolean storedPassword = true;
boolean changedPassword = false;
boolean checkPassword = false;
int distance;
int i = 1;
lcd.begin();
lcd.backlight();
myKeypad.begin();
pinMode(Woonkamer, INPUT);
pinMode(Slaapkamer, INPUT);
pinMode(Keuken , INPUT);
pinMode(Relay, OUTPUT);
pinMode(RedLed , OUTPUT);
pinMode(GreenLed , OUTPUT);
pinMode(BleuLed , OUTPUT);
delayTime = 10;
digitalWrite(GreenLed, HIGH);
if (armed) {
digitalWrite(RedLed, HIGH);
systemIsArmed();
else if (!armed) {
digitalWrite(RedLed, LOW);
systemIsUnarmed();
void systemIsUnarmed() {
int screenMsg = 0;
lcd.clear();
const long interval = 5000;
while (!armed) {
if (screenMsg == 0) {
lcd.setCursor(0, 0);
lcd.print("SYSTEM ALARM OFF");
lcd.setCursor(0, 1);
lcd.print("----------------");
digitalWrite(Relay, LOW);
screenMsg = 1;
lcd.print("A to arm ");
lcd.print("B to change pass");
screenMsg = 0;
keypressed = myKeypad.getKey();
if (keypressed == 'A') {
NewTone(buzzer, 500, 200);
systemIsArmed();
else if (keypressed == 'B') {
doublecheck = 0;
digitalWrite(BleuLed, HIGH);
storedPassword = false;
if (!changedPassword) {
changePassword();
digitalWrite(BleuLed , LOW);
//While system is armed
void systemIsArmed() {
lcd.clear();
int count = 10;
const long interval = 1000;
while (!armed) {
distance = sonar.ping_cm();
lcd.print(" SYSTEM WILL BE ");
lcd.print(" ARMED IN ");
if (count > 1) {
count--;
armed = true;
lcd.setCursor(12, 1);
lcd.print(count);
while (armed) {
lcd.print("SYSTEM IS ARMED!");
int Kamer = digitalRead(Woonkamer);
int SLKamer = digitalRead(Slaapkamer);
int keuken = digitalRead(Keuken);
int curr_distanse = sonar.ping_cm();
if (SLKamer == HIGH) {
lcd.clear();
lcd.print("Slaapkamer");
alarmFunction();
if (Kamer == HIGH) {
lcd.clear();
lcd.print("Kamer");
alarmFunction();
// unlockPassword();
if (keuken == HIGH) {
lcd.clear();
lcd.print("Keuken");
alarmFunction();
if (curr_distanse < (distance - 5)) {
alarmFunction();
//unlockPassword();
void unlockPassword() {
int count = 21;
retry:
tempPassword = "";
lcd.clear();
i = 6;
boolean buzzerState = false;
while (!checkPassword) {
if (!buzzerState) {
NewTone(buzzer, 700);
buzzerState = true;
noNewTone(buzzer);
if (count > 0) {
count--;
alarmFunction();
lcd.print("ALARM IN: ");
if (count >= 10) {
lcd.setCursor(14, 0);
lcd.print(count);
lcd.print(" ");
lcd.print(count);
lcd.print("PASS>");
if (keypressed != NO_KEY) {
if (keypressed == '0' || keypressed == '1' || keypressed == '2' || keypressed == '3' ||
keypressed == '4' || keypressed == '5' || keypressed == '6' || keypressed == '7' ||
keypressed == '8' || keypressed == '9' ) {
tempPassword += keypressed;
lcd.setCursor(i, 1);
lcd.print("*");
i++;
else if (keypressed == '*') {
if (password == tempPassword) {
armed = false;
NewTone(buzzer, 700, 500);
tempPassword = "";
NewTone(buzzer, 200, 200);
delay(300);
delay(300);
goto retry;
//Alarm
void alarmFunction() {
for (int i = 0; i < 10; i++) {
digitalWrite(Relay, HIGH);
retry:
tempPassword = "";
lcd.clear();
i = 6;
const long interval = 500;
if (!buzzerState) {
buzzerState = true;
noNewTone(buzzer);
lcd.print(" !!! ALARM !!! ");
lcd.print("PASS>");
if (keypressed != NO_KEY) { //Accept only numbers and *
lcd.print("*");
i++;
armed = false;
tempPassword = "";
delay(300);
delay(300);
goto retry;
void changePassword() {
retry:
tempPassword = "";
lcd.clear();
i = 1;
while (!changedPassword) {
lcd.print("CURRENT PASSWORD");
lcd.print(">");
lcd.print("*");
i++;
NewTone(buzzer, 800, 200);
else if (keypressed == '#') {
i = 1;
newPassword();
tempPassword = "";
delay(300);
delay(300);
goto retry;
String firstpass;
void Sound() {
if (currentPitch >= pitchHigh) {
else if (currentPitch <= pitchLow) {
delay(delayTime);
//Setup new password
void newPassword() {
tempPassword = "";
lcd.clear();
i = 1;
while (!storedPassword) {
if (doublecheck == 0) {
lcd.print("SET NEW PASSWORD");
lcd.print(">");
lcd.print("One more time...");
lcd.print(">");
lcd.print("*");
i++;
firstpass = tempPassword;
doublecheck = 1;
newPassword();
if (doublecheck == 1) {
doublecheck = 0;
if (firstpass == tempPassword) {
i = 1;
firstpass = "";
password = tempPassword;
tempPassword = "";
lcd.print("PASSWORD CHANGED");
NewTone(buzzer, 500, 400);
delay(2000);
lcd.clear();
firstpass = "";
newPassword();
Re: Deze code wil ik invoegen in mijn alarm instalatie
Dat is een goede oplossing.
De NewPing gebruikt Timer2.
De NewTone gebruikt Timer1. Dat gaat dus samen, zoals hier beschreven is: https://bitbucket.org/teckel12/arduino-new-ping/wiki/Home#!timer-2-conflict.
Ik heb veel vertrouwen in de code van Tim Eckel, ik gebruik zijn libraries in meerdere projecten.
Je sketch heb ik niet bekeken, maar ik zag labels "retry:" en een "goto" daar naar toe.
Dat is volstrekt legaal in de 'c' taal, maar onder programmeurs betekent dat een tekortkoming in de manier waarom de code is geschreven. De logische indeling van de code wordt doorbroken door een "goto". Daarom zal iedere programmeur tot het uiterste toe proberen om een "goto" te vermijden.
Heb newping geinstaleerd en oude verwijderd maar nog steeds een conflict met
Archiving built core (caching) in: C:\Users\Benny\AppData\Local\Temp\arduino_cache_727401\core\core_arduino_avr_uno_034037dd6c8b635230ff161f53a473d9.a
je gebruikt iets dubbel in de functie vector_7 bijvoorbeeld, maar die zit in een lib, dus niet zichtbaar voor ons.
Gebruik je overal NewTone ? of toch nog ergens een tone() ?
Dank alle heb hem gevonden mijn fout heb 1 keer Tone gebruikte en de rest NewTone
opegelsot
opegelsot
Geachte
kom er niet meer uit gebruik de script nergens fout melding alleen de afstand sensor draait niet in systeem mee.
van alles geprobeerd qua script het zou moeten werken .
het gaat om de regel
if (curr_distanse < (MAX_DISTANCE)) {
alarmFunction();
hier zeg ik als de meting kleiner is dan 2000 moet je alarm slaan .
maar gebeurd niks .
alarmFunction();
maar gebeurd niks .
#include <Keypad.h>
#define PING_PIN 10
#define MAX_DISTANCE 2000
int pitchStep = 10;
int currentPitch;
int delayTime;
char keypressed;
int adress = 0x38;
NewPing sonar(PING_PIN, PING_PIN, MAX_DISTANCE);
int doublecheck;
boolean input_pass;
int distance;
int i = 1;
Serial.begin(115200);
lcd.begin();
lcd.backlight();
myKeypad.begin();
delayTime = 10;
if (armed) {
systemIsArmed();
else if (!armed) {
systemIsUnarmed();
int screenMsg = 0;
lcd.clear();
while (!armed) {
screenMsg = 1;
screenMsg = 0;
systemIsArmed();
doublecheck = 0;
changePassword();
lcd.clear();
int count = 10;
while (!armed) {
if (count > 1) {
count--;
armed = true;
lcd.print(count);
while (armed) {
alarmFuncunction();
lcd.clear();
alarmFunction();
lcd.clear();
lcd.print("Kamer");
alarmFunction();
lcd.clear();
alarmFunction();
int count = 21;
retry:
tempPassword = "";
lcd.clear();
i = 6;
if (!buzzerState) {
buzzerState = true;
noNewTone(buzzer);
if (count > 0) {
count--;
alarmFunction();
if (count >= 10) {
lcd.print(count);
lcd.print(" ");
lcd.print(count);
lcd.print("PASS>");
lcd.print("*");
i++;
armed = false;
tempPassword = "";
delay(300);
delay(300);
goto retry;
//Alarm
retry:
tempPassword = "";
lcd.clear();
i = 6;
if (!buzzerState) {
buzzerState = true;
noNewTone(buzzer);
lcd.print("PASS>");
lcd.print("*");
i++;
armed = false;
tempPassword = "";
delay(300);
delay(300);
goto retry;
retry:
tempPassword = "";
lcd.clear();
i = 1;
lcd.print(">");
lcd.print("*");
i++;
i = 1;
newPassword();
tempPassword = "";
delay(300);
delay(300);
goto retry;
String firstpass;
void Sound() {
NewTone(speakerPin, currentPitch, 10);
delay(delayTime);
tempPassword = "";
lcd.clear();
i = 1;
lcd.print(">");
lcd.print(">");
lcd.print("*");
i++;
doublecheck = 1;
newPassword();
doublecheck = 0;
i = 1;
firstpass = "";
tempPassword = "";
delay(2000);
lcd.clear();
firstpass = "";
newPassword();
Sorry, maar ik kan er niet veel mee. De structuur van de code is moeilijk te doorgronden. Misschien dat iemand anders er meer mee kan.
In de loop() zijn er twee functies, die zelf ook while-loops hebben waar ze in kunnen blijven hangen.
Ik zie verder allerlei code waarvan ik niet weet wat je er mee wilt. Eigenlijk begrijp ik alleen de code in de setup() functie.
Dit gebeurt er als je geen vast plan volgt. Daarom is het belangrijk om een diagram te maken met de logica van wat je wilt.
Een paar println toevoegen aan de code (Debug)
bijvoorbeeld na, int curr_distanse
en zie wat er uit komt.
9 berichten
Gebruikers in dit forum: reindu en 7 gasten
