No forward link or gateway feature activated
Loop te stoeien met deze foutmelding
In onderstaand script waar ik mee bezig ben
Volgens de inleiding van de fout moet het in MySensors.h zitten.
Script is nog niet klaar, dus zullen er nog wel een paar fouten in zitten maar die wil ik er zelf uit halen.
Het gaat mij om de fout melding van MySensors.
error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
#include <MySensors.h>
#include <ESP8266WiFi.h>
#include <WiFiServer.h>
#include <ShiftPWM.h>
#include <SPI.h>
boolean sensor;
boolean MysenSor;
#define SHIFTPWM_NOSPI
const int ShiftPWM_dataPin = D7; // Shift-data ZO LATEN!!!
const int ShiftPWM_clockPin = D5; // Shift-clock ZO LATEN!!!
const int ShiftPWM_latchPin = D6; // Shift-latch ZO LATEN!!!
const bool ShiftPWM_invertOutputs = false;
const bool ShiftPWM_balanceLoad = false;
#define Licht_sensor_PIN A0 // Licht sensor ZO LATEN!!!
#define Ultra_trigger_PIN D1 // Trigger voor ultrasonor sensor ZO LATEN!!!
#define Ultra_echo_PIN D2 // Echo voor ultrasonor sensor ZO LATEN!!!
#define PIR_onder_PIN D3 // Bottom sensor Do not change!!!
#define PIR_boven_PIN D0 // Upper sensor Do not change!!!
unsigned char maxBrightness = 100; // Here you set the number of brightness levels. Adjust(0-255)!!
unsigned char pwmFrequency = 75; // These values affect the load of ShiftPWM
unsigned int numRegisters = 2; // Number of shift registers Do not change!!!
unsigned int numOutputs = numRegisters * 8;
//unsigned int numRGBLeds = numRegisters * 8 / 3;
unsigned int fadingMode = 0; // start with all LED's off.
boolean sensorUpperActive;
boolean sensorBottomActive;
int numberOfstairs=16; // Setup Number of Your stairs. Adjust up to 24 !!!!
int pause=30000; // Setup delay ON/OFF Adjust!!!
byte faidoutSpeed=5; // How fast to fadeout Adjust!!!
byte faidinSpeed=5; // How fast to fadein Adjust!!!
void before() {
MysenSor=loadState(sensor); // Set relay to last known state (using eeprom storage)
void presentation() {
present(sensor, S_LIGHT);
void receive(const MyMessage &message) { // We only expect one type of message from controller. But we better check anyway.
if (message.type==V_LIGHT) {
MysenSor=message.getBool();
// Store state in eeprom
saveState(message.sensor, message.getBool());
ShiftPWM.SetAmountOfRegisters(numRegisters);
ShiftPWM.Start(pwmFrequency, maxBrightness);
pinMode(PIR_onder_PIN, INPUT);
pinMode(PIR_boven_PIN, INPUT);
pinMode(Licht_sensor_PIN, INPUT);
if ( MysenSor!=0) { // Adjust photocell cencivity. (val<10 dark.....val>800 bright..) !!!!!!!!
BottomTriggerFire(); //Checking bottom sensor
UpperTrigerFire(); //Checking upper sensor
switchONOFFfromdown(); //Stairs on/off from down to up
switchONOFFfromUp(); //Stairs on/off from up to down
void BottomTriggerFire() {
if (analogRead (PIR_onder_PIN) >= 550 ) { //Depend of the sensor type, if 0 when triggered ,than change the comparison to opposite value.
sensorBottomActive = true;
void UpperTrigerFire() {
if (analogRead(PIR_boven_PIN) >= 550) { //Depend of the sensor type, if 0 when triggered ,than change the comparison to opposite value.
sensorUpperActive = true;
void switchONOFFfromdown() {
if (sensorBottomActive==true && sensorUpperActive==false){
for(int i=0; i<numberOfstairs; i++){
for(int a=0; a<maxBrightness; a++){
ShiftPWM.SetOne(i,a);
delay(faidoutSpeed);
delay(pause);
for(int a=maxBrightness;a>=0;a--){
if(a==0){
ShiftPWM.SetOne(i,0);
delay(faidinSpeed);
sensorBottomActive = false ;
void switchONOFFfromUp () {
if ( sensorUpperActive==true && sensorBottomActive==false) {
for(int i=numberOfstairs; i>=0; i--){
Serial.print(i);
delay(pause);
//Serial.print(i);
if(a==0){
delay(faidinSpeed);
sensorUpperActive= false ;
\Arduino\libraries\MySensors-development/MySensors.h:389:2: error:
Andreas
Andreas
Re: No forward link or gateway feature activated
Die foutmelding komt hier vandaan: https://github.com/mysensors/MySensors/blob/development/MySensors.h#L389
Blijkbaar verwacht MySensors dat er een draadloze verbinding is of dat allerlei defines zijn gedefinieerd.
Kijk maar naar de examples van MySensors, er is iets nodig zoals: #define MY_GATEWAY_ESP8266
Misschien is het ook beter om de #include <MySensors.h> niet als eerste te zetten, maar onder die andere.
De meer basis-dingen zou ik eerst zetten, zoals de #define <SPI.h>. Waar heb je SPI voor nodig ? Voor de ShiftPWM ? En is die ShiftPWM geschikt voor de ESP8266 ?
Hallo Koepel,
Ik wil voor mijn zoon een LED trap verlichting maken de print is al klaar, deze is gemaakt zoals op deze foto alleen gebruik ik 2 x 74HC595 ipv. 3
En ik gebruik een NodeMCU ipv een NANO, dus ja nu loop ik te stoeien met het script.
NodeMCU heeft een ESP8266 aan boord deze wil ik gebruiken om de instellingen via HTML en een bv tablet te kunnen wijzigen verder niets.
Dus de ShiftPWM gaat niet over de ESP8266 heen, stuurt alleen maar de uitgangen op de print.
De SPI word volgens mij gebruikt door de ShiftPWM maar daar ben ik nog niet helemaal achter.
Hier ga ik eens naar kijken #define MY_GATEWAY_ESP8266 en dan zien of ik er iets mee kan.
Andreas
Andreas
Gebruikers in dit forum: Geen geregistreerde gebruikers en 56 gasten
