SetTime probleem
SetTime probleem
heb hier een code maar wil niet lopen zit vast op setTime wat doe ik hier verkeerd .
#include <Keypad.h>
#include <Keypad_I2C.h>
#include <Tone.h>
#include <Timer.h>
#define pound 14
Timer counter;
LiquidCrystal_I2C lcd(0x27,16,2);
int DefuseTimer = 0;
Tone tone1;
int oldS = 0;
int nbBoucle = 0;
const int pinWriteDefused = 2;
const int pinWriteBoom = 3;
const int pinReadDefused = 4;
const int pinReadBoom = 5;
char password[5];
int currentLength = 0;
int i = 0;
char entered[5];
int passwordLength;
int nbtry = 3;
int currentTry = nbtry;
const int Buzzer = 6;
const byte ROWS = 4; //four rows
const byte COLS = 3; //three columns
char keys[ROWS][COLS] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}
byte rowPins[ROWS] = {0,1,2,3};
byte colPins[COLS] = {4,5,6};
int adress = 0x38;
Keypad_I2C keypad = Keypad_I2C( makeKeymap(keys), rowPins, colPins, ROWS, COLS, adress );
boolean b600s = true;
boolean b300s = true;
boolean b120s = true;
boolean b60s = true;
boolean b30s = true;
boolean b10s = true;
lcd.init();
lcd.backlight();
lcd.begin(16,2);
int hours, minutes, seconds;
lcd.begin(16, 2);
tone1.begin(Buzzer);
//pinMode(Buzzer, OUTPUT);
//digitalWrite(Buzzer, LOW);
char key;
boolean cancel;
do
cancel = false;
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Time ?");
lcd.setCursor(4,1);
//Heures
hours = readHours();
if (hours == -1)
cancel = true;
lcd.print(":");
//Minutes
if (cancel == false)
minutes = readMinutes();
if (minutes == -1)
cancel = true;
lcd.print(":");
//Secondes
seconds = readSeconds();
if (seconds == -1)
cancel = true;
do
key = keypad.waitForKey();
while (key != '#' && key != '*');
buttonBip(100);
if (key == '*')
cancel = true;
while (cancel == true);
delay (500);
counter.setTime(hours, minutes, seconds);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Enter Code: ");
while ((currentLength < 1 || key != '#'))
lcd.setCursor(currentLength, 1);
lcd.cursor();
key = keypad.getKey();
if (key != NO_KEY)
buttonBip(100);
if (key != '#' && key != '*' && currentLength < 10)
lcd.print(key);
password[currentLength] = key;
++currentLength;
passwordLength = currentLength;
else if (key == '*')
lcd.clear();
lcd.setCursor(0,0);
currentLength = 0;
Serial.print("rad:bomb:planted");
delay(500);
lcd.clear();
currentLength = 0;
timer();
currentLength = 0;
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Code: ");
boolean lec_code = true;
char code[10];
int i = 0;
char key2;
while (lec_code == true)
timer();
key2 = keypad.getKey();
if (key2 != NO_KEY)
buttonBip(100);
if (key2 == '#' || i >= 10)
lec_code = false;
else if (key2 == '*')
currentLength = 0;
lcd.clear();
lcd.setCursor(0,0);
if (key2 != NO_KEY && currentLength < 10)
entered[currentLength] = key2;
currentLength++;
delay(100);
lcd.noCursor();
lcd.setCursor(currentLength + 4, 0);
lcd.print(key2);
lcd.setCursor(currentLength + 5, 0);
lcd.cursor();
boolean correct = true;
for (int j = 0; j < currentLength; ++j)
if (entered[j] != password[j])
correct = false;
if (correct == true && passwordLength == currentLength)
Defused();
else if (currentLength >= 1)
lcd.noCursor();
lcd.clear();
lcd.home();
lcd.print("Wrong Password!");
buttonBip(100);
delay(200);
buttonBip(100);
--currentTry;
if (currentTry == 0)
Boom();
lcd.setCursor(0, 1);
lcd.print("Try : ");
lcd.print(currentTry);
delay(1500);
currentLength = 0;
//--------------------------------- Timer --------------------------------
void timer()
if (counter.seconds == 0 && counter.minutes == 10 && counter.hours == 0 && b600s == true) {Serial.print("rad:bomb:600s"); b600s = false;}
if (counter.seconds == 0 && counter.minutes == 5 && counter.hours == 0 && b300s == true) {Serial.print("rad:bomb:300s"); b300s = false;}
if (counter.seconds == 0 && counter.minutes == 2 && counter.hours == 0 && b120s == true) {Serial.print("rad:bomb:120s"); b120s = false;}
if (counter.seconds == 0 && counter.minutes == 1 && counter.hours == 0 && b60s == true) {Serial.print("rad:bomb:60s"); b60s = false;}
if (counter.seconds == 30 && counter.minutes == 0 && counter.hours == 0 && b30s == true) {Serial.print("rad:bomb:30s"); b30s = false;}
if (counter.seconds == 10 && counter.minutes == 0 && counter.hours == 0 && b10s == true) {Serial.print("rad:bomb:10s"); b10s = false;}
++nbBoucle;
if (((counter.seconds > 10 && counter.minutes < 1 && counter.hours < 1) || (counter.minutes >= 1 || counter.hours >= 1)) && oldS != counter.seconds)
oldS = counter.seconds;
timeBip(100);
else if (counter.seconds <= 10 && counter.seconds > 5 && counter.minutes < 1 && counter.hours < 1 && nbBoucle >= 15)
nbBoucle = 0;
timeBip(100);
else if (counter.seconds <= 5 && counter.seconds > 3 && counter.minutes < 1 && counter.hours < 1 && nbBoucle >= 10)
nbBoucle = 0;
timeBip(100);
else if (counter.seconds <= 3 && counter.minutes < 1 && counter.hours < 1 && nbBoucle >= 5)
nbBoucle = 0;
timeBip(100);
refreshTimeLcd();
if (counter.decrement(millis()))
Boom ();
readPort();
lcd.noCursor();
delay(10); // waits for a second
//--------------------------------- LCD --------------------------------
void refreshTimeLcd()
lcd.setCursor (0,1); // sets cursor to 2nd line
lcd.print ("Timer:");
if (counter.hours >= 10)
lcd.setCursor (7,1);
lcd.print (counter.hours);
if (counter.hours < 10)
lcd.print ("0");
lcd.setCursor (8,1);
lcd.print (":");
if (counter.minutes >= 10)
lcd.setCursor (10,1);
lcd.print (counter.minutes);
if (counter.minutes < 10)
lcd.print ("0");
lcd.setCursor (11,1);
lcd.print (":");
if (counter.seconds >= 10)
lcd.setCursor (13,1);
lcd.print (counter.seconds);
if (counter.seconds < 10)
lcd.print ("0");
lcd.setCursor (14,1);
//--------------------------------- Heures --------------------------------
int readHours ()
char key;
char hour[3];
int hours;
for (int i=0; i<2; ++i)
do
if (key != NO_KEY)
buttonBip(100);
while (key == NO_KEY || key == '#');
if (key == '*')
return -1;
hour[i] = key;
lcd.print(key);
hour[2] = '\0';
hours = atoi(hour);
return hours;
//--------------------------------- Minutes --------------------------------
int readMinutes ()
char stTemp[2];
char key;
char minute[3];
int minutes;
do
if (key != NO_KEY)
buttonBip(100);
if (key == '*')
return -1;
sprintf(stTemp,"%c",key);
while (key == NO_KEY || key == '*' || key == '#' || ((atoi(stTemp)) >= 6 && i == 0));
minute[i] = key;
lcd.print(key);
minute[2] = '\0';
minutes = atoi(minute);
return minutes;
//--------------------------------- Secondes --------------------------------
int readSeconds ()
char stTemp[2];
char key;
char second[3];
int seconds;
do
if (key != NO_KEY)
buttonBip(100);
if (key == '*')
return -1;
while (key == NO_KEY || key == '*' || key == '#' || (atoi(stTemp) >= 6 && i == 0));
second[i] = key;
lcd.print(key);
second[2] = '\0';
seconds = atoi(second);
return seconds;
//--------------------------------- Boom -------------------------------------
void Boom ()
Serial.print("rad:bomb:explosed");
pinMode(pinWriteBoom, OUTPUT);
digitalWrite(pinWriteBoom, HIGH);
lcd.noCursor();
lcd.clear();
lcd.home();
lcd.print("The Bomb Has ");
lcd.print("Exploded!");
tone1.play(NOTE_F2, 3000);
delay(8000);
digitalWrite(3, LOW);
while (1)
delay(100000);
//--------------------------------- Defused ----------------------------------
void Defused ()
Serial.print("rad:bomb:defused");
pinMode(pinWriteDefused, OUTPUT);
digitalWrite(pinWriteDefused, HIGH);
lcd.noCursor();
lcd.clear();
lcd.home();
lcd.print("Bomb Defused");
refreshTimeLcd();
buttonBip(200);
delay(300);
buttonBip(200);
delay(300);
buttonBip(200);
currentLength = 0;
while (1)
delay(1000000);
//--------------------------------- readPort ----------------------------------
void readPort()
pinMode(pinReadDefused, INPUT);
pinMode(pinReadBoom, INPUT);
byte defused = digitalRead(pinReadDefused);
byte boom = digitalRead(pinReadBoom);
if (defused == HIGH)
Defused();
if (boom == HIGH)
Boom();
//---------------------------------- timeBip ---------------------------------
void timeBip (int mills)
tone1.play(NOTE_F7, mills);
//---------------------------------- buttonBip ---------------------------------
void buttonBip (int mills)
tone1.play(NOTE_A7, mills);
Re: SetTime probleem
Onduidelijk zijn waar je het over hebt......
deze regel geeft fout
exit status 1
'class Timer' has no member named 'setTime'
exit status 1
Kennelijk heeft de xlass timer deze method() of funxtie() ( hoe je het ook noemen wilt). Oorzaak is of deze method staat niet in timer.h en timer.cpp. Of je hebt een type fout gemaakt of (als je dit ergens vandaan hebt gekopieerd) de auteur heeft een andere library gebruikt
Gebruikers in dit forum: KeithGam en 21 gasten
