arduino reset
arduino reset
//////SPELER 1////////////SPELER 1////////////SPELER 1////////////SPELER 1////////////SPELER 1////////////SPELER 1////////////SPELER 1////////////SPELER 1////////////SPELER 1/////
//SPELER 1 LED//
const int ledPin1 = 2;
int ledState1 = LOW;
//SPELER 1 KNOP//
const int buttonPin1 = 3;
int buttonState1;
int lastButtonState1 = LOW;
long lastDebounceTime1 = 0; // the last time the output pin was toggled
long debounceDelay1 = 50; // the debounce time; increase if the output flickers
int knipperVlag1;
//////SPELER 2////////////SPELER 2////////////SPELER 2////////////SPELER 2////////////SPELER 2////////////SPELER 2////////////SPELER 2////////////SPELER 2////////////SPELER 2/////
//SPELER 2 LED//
const int ledPin2 = 4;
int ledState2 = LOW;
//SPELER 2 KNOP//
const int buttonPin2 = 5;
int buttonState2;
int lastButtonState2 = LOW;
long lastDebounceTime2 = 0; // the last time the output pin was toggled
long debounceDelay2 = 50; // the debounce time; increase if the output flickers
int knipperVlag2;
//////SPELER 3////////////SPELER 3////////////SPELER 3////////////SPELER 3////////////SPELER 3////////////SPELER 3////////////SPELER 3////////////SPELER 3////////////SPELER 3/////
//SPELER 3 LED//
const int ledPin3 = 8;
int ledState3 = LOW;
//SPELER 3 KNOP//
const int buttonPin3 = 9;
int buttonState3;
int lastButtonState3 = LOW;
long lastDebounceTime3 = 0; // the last time the output pin was toggled
long debounceDelay3 = 50; // the debounce time; increase if the output flickers
int knipperVlag3;
//////SPELER 4////////////SPELER 4////////////SPELER 4////////////SPELER 4////////////SPELER 4////////////SPELER 4////////////SPELER 4////////////SPELER 4////////////SPELER 4/////
//SPELER 4 LED//
const int ledPin4 = 10;
int ledState4 = LOW;
//SPELER 4 KNOP//
const int buttonPin4 = 13;
int buttonState4;
int lastButtonState4 = LOW;
long lastDebounceTime4 = 0; // the last time the output pin was toggled
long debounceDelay4 = 50; // the debounce time; increase if the output flickers
int knipperVlag4;
//////////VOOR HET SPEL////////////////////VOOR HET SPEL////////////////////VOOR HET SPEL////////////////////VOOR HET SPEL////////////////////VOOR HET SPEL////////////////////////
long previousMillis = 0;
long t0 = 0;
long vertraging = 500;
int y;
int randNumber;
int x = 1;
pinMode(buttonPin1, INPUT);
pinMode(ledPin1, OUTPUT);
pinMode(buttonPin2, INPUT);
pinMode(ledPin2, OUTPUT);
pinMode(buttonPin3, INPUT);
pinMode(ledPin3, OUTPUT);
pinMode(buttonPin4, INPUT);
pinMode(ledPin4, OUTPUT);
digitalWrite(ledPin1, ledState1);
digitalWrite(buttonPin1, buttonState1);
digitalWrite(ledPin2, ledState2);
digitalWrite(buttonPin2, buttonState2);
digitalWrite(ledPin3, ledState3);
digitalWrite(buttonPin3, buttonState3);
digitalWrite(ledPin4, ledState4);
digitalWrite(buttonPin4, buttonState4);
randomSeed(analogRead(0));
y = 1;
//////////KNOP UITLEZEN VAN SPELER 1////////////////////KNOP UITLEZEN VAN SPELER 1////////////////////KNOP UITLEZEN VAN SPELER 1////////////////////KNOP UITLEZEN VAN SPELER 1/////
int reading1 = digitalRead(buttonPin1);
if (reading1 != lastButtonState1)
lastDebounceTime1 = millis();
// ga na of de knop is ingedrukt als hij langere tijd dezelfde waarde heeft
if ((millis() - lastDebounceTime1) > debounceDelay1)
if (reading1 != buttonState1)
buttonState1 = reading1;
if (reading1 == HIGH)
if (knipperVlag1 == HIGH)
knipperVlag1 = LOW;
y = 22;
lastButtonState1 = reading1;
//////////KNOP UITLEZEN VAN SPELER 2////////////////////KNOP UITLEZEN VAN SPELER 2////////////////////KNOP UITLEZEN VAN SPELER 2////////////////////KNOP UITLEZEN VAN SPELER 2/////
int reading2 = digitalRead(buttonPin2);
if (reading2 != lastButtonState2)
lastDebounceTime2 = millis();
if ((millis() - lastDebounceTime2) > debounceDelay2)
if (reading2 != buttonState2)
buttonState2 = reading2;
if (reading2 == HIGH)
if (knipperVlag2 == HIGH)
knipperVlag2 = LOW;
y = 23;
lastButtonState2 = reading2;
//////////KNOP UITLEZEN VAN SPELER 3////////////////////KNOP UITLEZEN VAN SPELER 3////////////////////KNOP UITLEZEN VAN SPELER 3////////////////////KNOP UITLEZEN VAN SPELER 3/////
int reading3 = digitalRead(buttonPin3);
if (reading3 != lastButtonState3)
lastDebounceTime3 = millis();
if ((millis() - lastDebounceTime3) > debounceDelay3)
if (reading3 != buttonState3)
buttonState3 = reading3;
if (reading3 == HIGH)
if (knipperVlag3 == HIGH)
knipperVlag3 = LOW;
y = 24;
lastButtonState3 = reading3;
//////////KNOP UITLEZEN VAN SPELER 4////////////////////KNOP UITLEZEN VAN SPELER 4////////////////////KNOP UITLEZEN VAN SPELER 4////////////////////KNOP UITLEZEN VAN SPELER 4/////
int reading4 = digitalRead(buttonPin4);
if (reading4 != lastButtonState4)
lastDebounceTime4 = millis();
if ((millis() - lastDebounceTime4) > debounceDelay4)
if (reading4 != buttonState4)
buttonState4 = reading4;
if (reading4 == HIGH)
if (knipperVlag4 == HIGH)
knipperVlag4 = LOW;
y = 25;
lastButtonState4 = reading4;
//////////KNIPPERSPEL////////////////////KNIPPERSPEL////////////////////KNIPPERSPEL////////////////////KNIPPERSPEL////////////////////KNIPPERSPEL////////////////////KNIPPERSPEL///
if ((millis() - t0) > vertraging)
t0 = millis();
if (y==1)
ledState1 = HIGH;
vertraging = 200-x;
y = 2;
else if (y==2)
ledState1 = LOW;
vertraging = 200-x;
randNumber = random(10);
if (randNumber == 0)
knipperVlag1 = HIGH;
y = 9;
y = 3;
else if (y==3)
ledState2 = HIGH;
vertraging = 200-x;
y = 4;
else if (y==4)
ledState2 = LOW;
vertraging = 200-x;
knipperVlag2 = HIGH;
y = 11;
y = 5;
else if (y==5)
ledState3 = HIGH;
vertraging = 200-x;
y = 6;
else if (y==6)
ledState3 = LOW;
vertraging = 200-x;
knipperVlag3 = HIGH;
y = 13;
y = 7;
else if (y==7)
ledState4 = HIGH;
vertraging = 200-x;
y = 8;
else if (y==8)
ledState4 = LOW;
vertraging = 200-x;
knipperVlag4 = HIGH;
y = 15;
y = 1;
x = x + 5; // ELKE KEER ALS HIJ EEN RONDJE HEEFT GEDAAN ZONDER DAT IEMAND AF IS GEGAAN WORDT X GROTER WAARDOOR DE VERTRAGING KLEINER EN HET SPEL SNELLER WORDT//////
if (x>100) // ZOGRT ERVOOR DAT HET SPEL NIET DOOR BLIJFT VERSNELLEN MAAR BIJ EEN BEPAALDE WAARDE UITEINDELIJK BLIJFT//
x = 100;
Serial.println(x);
////////// ZORGT ERVOOR DAT LED 1 2X KNIPPERT//////////////////// ZORGT ERVOOR DAT LED 1 2X KNIPPERT//////////////////// ZORGT ERVOOR DAT LED 1 2X KNIPPERT////////////////////////
else if (y==9)
ledState1 = HIGH;
vertraging = 200;
y = 10;
else if (y==10)
ledState1 = LOW;
vertraging = 1000;
y = 17;
////////// ZORGT ERVOOR DAT LED 2 2X KNIPPERT//////////////////// ZORGT ERVOOR DAT LED 2 2X KNIPPERT//////////////////// ZORGT ERVOOR DAT LED 2 2X KNIPPERT////////////////////////
else if (y==11)
ledState2 = HIGH;
vertraging = 200;
y = 12;
else if (y==12)
ledState2 = LOW;
vertraging = 1000;
y = 18;
////////// ZORGT ERVOOR DAT LED 3 2X KNIPPERT//////////////////// ZORGT ERVOOR DAT LED 3 2X KNIPPERT//////////////////// ZORGT ERVOOR DAT LED 3 2X KNIPPERT////////////////////////
else if (y==13)
ledState3 = HIGH;
vertraging = 200;
y = 14;
else if (y==14)
ledState3 = LOW;
vertraging = 1000;
y = 19;
////////// ZORGT ERVOOR DAT LED 4 2X KNIPPERT//////////////////// ZORGT ERVOOR DAT LED 4 2X KNIPPERT//////////////////// ZORGT ERVOOR DAT LED 4 2X KNIPPERT////////////////////////
else if (y==15)
ledState4 = HIGH;
vertraging = 200;
y = 16;
else if (y==16)
ledState4 = LOW;
vertraging = 1000;
y = 20;
////////////////////////////////////////////////////////CONTROLEERT OF SPELER 1 OP ZIJN KNOP HEEFT GEDRUKT/////////////////////////////////////////////////////////////////////////
else if (y==17)
if (knipperVlag1 == LOW) //// SPELER 1 HEEFT WEL OP ZIJN KNOP GEDRUKT ////
y = 3;
else //// SPELER 1 HEEFT NIET OP ZIJN KNOP GEDRUKT ////
ledState2 = HIGH;
ledState3 = HIGH;
ledState4 = HIGH;
vertraging = 1000;
y = 21;
////////////////////////////////////////////////////////CONTROLEERT OF SPELER 2 OP ZIJN KNOP HEEFT GEDRUKT/////////////////////////////////////////////////////////////////////////
else if (y==18)
if (knipperVlag2 == LOW) //// SPELER 2 HEEFT WEL OP ZIJN KNOP GEDRUKT ////
y = 5;
else //// SPELER 2 HEEFT NIET OP ZIJN KNOP GEDRUKT ////
ledState1 = HIGH;
ledState3 = HIGH;
ledState4 = HIGH;
vertraging = 1000;
y = 21;
////////////////////////////////////////////////////////CONTROLEERT OF SPELER 3 OP ZIJN KNOP HEEFT GEDRUKT/////////////////////////////////////////////////////////////////////////
else if (y==19)
if (knipperVlag3 == LOW) //// SPELER 3 HEEFT WEL OP ZIJN KNOP GEDRUKT ////
y = 7;
else //// SPELER 3 HEEFT NIET OP ZIJN KNOP GEDRUKT ////
ledState1 = HIGH;
ledState2 = HIGH;
ledState4 = HIGH;
vertraging = 1000;
y = 21;
////////////////////////////////////////////////////////CONTROLEERT OF SPELER 4 OP ZIJN KNOP HEEFT GEDRUKT/////////////////////////////////////////////////////////////////////////
else if (y==20)
if (knipperVlag4 == LOW) //// SPELER 4 HEEFT WEL OP ZIJN KNOP GEDRUKT ////
y = 9;
else //// SPELER 4 HEEFT NIET OP ZIJN KNOP GEDRUKT ////
ledState1 = HIGH;
ledState2 = HIGH;
ledState3 = HIGH;
vertraging = 1000;
y = 21;
/////////////////////////////////////////////////////// ALS IEMAND AF IS BEGINT HET SPEL OPNIEUW (VERSNELLER OOK OPNIEUW)//////////////////////////////////////////////////////////
else if (y==21)
ledState1 = LOW;
ledState2 = LOW;
ledState3 = LOW;
ledState4 = LOW;
vertraging = 1000;
y = 26;
//////////////////////////////////////////////////////// ALS DE SPELER DE KNOP INDRUKT TERWIJL HET NIET ZIJN BEURT IS//////////////////////////////////////////////////////////////
/////////////////////////////////////////////////////////////////////SPELER 1 IS AF////////////////////////////////////////////////////////////////////////////////////////////////
else if (y==22)
ledState2 = HIGH;
ledState3 = HIGH;
ledState4 = HIGH;
vertraging = 1000;
y = 21;
//////////////////////////////////////////////////////////////////////SPELER 2 IS AF///////////////////////////////////////////////////////////////////////////////////////////////
else if (y==23)
ledState1 = HIGH;
ledState3 = HIGH;
ledState4 = HIGH;
vertraging = 1000;
y = 21;
//////////////////////////////////////////////////////////////////////SPELER 3 IS AF///////////////////////////////////////////////////////////////////////////////////////////////
else if (y==24)
ledState1 = HIGH;
ledState2 = HIGH;
ledState4 = HIGH;
vertraging = 1000;
y = 21;
//////////////////////////////////////////////////////////////////////SPELER 4 IS AF///////////////////////////////////////////////////////////////////////////////////////////////
else if (y==25)
ledState1 = HIGH;
ledState2 = HIGH;
ledState3 = HIGH;
vertraging = 1000;
y = 21;
else if (y==26)
if (buttonState1 == HIGH && buttonState2 == HIGH && buttonState3 == HIGH && buttonState4 == HIGH)
y = 1;
x = 1;
y = 26;
digitalWrite (ledPin1, ledState1);
digitalWrite (ledPin2, ledState2);
digitalWrite (ledPin3, ledState3);
digitalWrite (ledPin4, ledState4);
is het mogelijk om hierin een code te zetten bij y == 26 dat als je alle 4 de knoppen indrukt tegelijk het spel opnieuw begint???
groetjes,
Gijs en Fred
Re: arduino reset
programma is erg veel herhaling, simpeler is het door arrays te gebruiken voor toestanden. dan hoef je alle beslissingen maar 1 keer te schrijven.
gebruik functies waardoor je paginas krijgt die leesbaar blijven en foutloos zijn.
en ja natuurlijk je zet gewoon alles weer terug op nul.
Gebruikers in dit forum: Geen geregistreerde gebruikers en 82 gasten
