Is er iemand die weet hoe je een Sirus IX30 aansluit
Is er iemand die weet hoe je een Sirus IX30 aansluit op een Arduino?
Het is een kaartlezer.
Re: Is er iemand die weet hoe je een Sirus IX30 aansluit
Dino schreef:Is er iemand die weet hoe je een Sirus IX30 aansluit op een Arduino?
#define MAX_BITS 100 // max number of bits
#define WEIGAND_WAIT_TIME 3000 // time to wait for another weigand pulse.
unsigned char databits[MAX_BITS]; // stores all of the data bits
unsigned char bitCount; // number of bits currently captured
unsigned char flagDone; // goes low when data is currently being captured
unsigned int weigand_counter; // countdown until we assume there are no more bits
unsigned long facilityCode=0; // decoded facility code
unsigned long cardCode=0; // decoded card code
int LED_GREEN = 11;
int LED_RED = 12;
int BEEP_BEEP = 10;
// interrupt that happens when INTO goes low (0 bit)
void ISR_INT0() {
//Serial.print("0"); // uncomment this line to display raw binary
bitCount++;
flagDone = 0;
weigand_counter = WEIGAND_WAIT_TIME;
// interrupt that happens when INT1 goes low (1 bit)
void ISR_INT1() {
Serial.print("1"); // uncomment this line to display raw binary
databits[bitCount] = 1;
bitCount++;
flagDone = 0;
pinMode(LED_RED, OUTPUT);
pinMode(LED_GREEN, OUTPUT);
pinMode(BEEP_BEEP, OUTPUT);
digitalWrite(LED_RED, HIGH); // High = Off
digitalWrite(BEEP_BEEP, HIGH); // High = off
digitalWrite(LED_GREEN, LOW); // Low = On
pinMode(2, INPUT); // DATA0 (INT0)
pinMode(3, INPUT); // DATA1 (INT1)
Serial.println("RFID Readers");
// binds the ISR functions to the falling edge of INTO and INT1
attachInterrupt(0, ISR_INT0, FALLING);
attachInterrupt(1, ISR_INT1, FALLING);
// This waits to make sure that there have been no more data pulses before processing data
if (!flagDone) {
if (--weigand_counter == 0)
flagDone = 1;
// if we have bits and we the weigand counter went out
if (bitCount > 0 && flagDone) {
unsigned char i;
Serial.print("Read ");
Serial.print(bitCount);
Serial.print(" bits. ");
if (bitCount == 35) {
// 35 bit HID Corporate 1000 format
// facility code = bits 2 to 14
for (i=2; i<14; i++) {
facilityCode <<=1;
facilityCode |= databits[i];
// card code = bits 15 to 34
for (i=14; i<34; i++) {
cardCode <<=1;
cardCode |= databits[i];
printBits();
else if (bitCount == 26) {
// standard 26 bit format
// facility code = bits 2 to 9
for (i=1; i<9; i++) {
facilityCode <<=1;
// card code = bits 10 to 23
for (i=9; i<25; i++) {
cardCode <<=1;
printBits();
// you can add other formats if you want!
Serial.println("Unable to decode.");
// cleanup and get ready for the next card
bitCount = 0;
facilityCode = 0;
cardCode = 0;
for (i=0; i<MAX_BITS; i++)
databits[i] = 0;
void printBits() {
Serial.print("FC = ");
Serial.print(facilityCode);
Serial.print(", CC = ");
Serial.println(cardCode);
// Now lets play with some LED's for fun:
digitalWrite(LED_RED, LOW); // Red
if(cardCode == 12345){
// If this one "bad" card, turn off green
// so it's just red. Otherwise you get orange-ish
digitalWrite(LED_GREEN, HIGH);
delay(500);
digitalWrite(LED_RED, HIGH); // Red Off
digitalWrite(LED_GREEN, LOW); // Green back on
// Lets be annoying and beep more
digitalWrite(BEEP_BEEP, LOW);
delay(500);
delay(500);
delay(500);
Dino schreef:Dino schreef:Is er iemand die weet hoe je een Sirus IX30 aansluit op een Arduino?
Het is een kaartlezer. Deze software gebruik ik nu maar werkt niet zoals hoort led is netjes groen hij leest maar neemt gegevens kaart niet over
int LED_GREEN = 11;
int LED_RED = 12;
int BEEP_BEEP = 10;
void ISR_INT0() {
bitCount++;
flagDone = 0;
void ISR_INT1() {
bitCount++;
flagDone = 0;
if (!flagDone) {
flagDone = 1;
unsigned char i;
facilityCode <<=1;
cardCode <<=1;
printBits();
facilityCode <<=1;
cardCode <<=1;
printBits();
bitCount = 0;
facilityCode = 0;
cardCode = 0;
databits[i] = 0;
void printBits() {
delay(500);
delay(500);
delay(500);
delay(500);
ik zou zeggen om de serial print in de isr aan te zetten en kijken of dat werkt, dan kun je dus zien of er data ontvangen wordt.
en dan zien of je wat fout doet zoals een andere bordje bijv. 3.3 volt etc.
Gebruikers in dit forum: Bing [Bot] en 12 gasten
