Attiny85(RF,Sleep,Interrupt,Timer,Battery Level(3xAAA)
2 berichten
- degiel1982
- Geregistreerd: 07 Nov 2020, 06:27
Hi everybody,
I am creating a battery powered magnetic door sensor based on rf433.
My goal is battery life and best performance with the most options
I want to share my project so if anybody sees some improvements or can use it for their own it would be wonderfull.
I see a lot of info scattered and i wanted to slab this in as whole
#include <avr/io.h>
#include <avr/interrupt.h>
#include <avr/sleep.h>
#include <avr/wdt.h>
#include <RCSwitch.h>
#define adc_disable() (ADCSRA &= ~(1<<ADEN))
#define INTERRUPT_PIN PCINT3
#define INT_PIN PB3
#define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
#define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
RCSwitch mySwitch = RCSwitch();
int timerhigh = 0;
int timerlow = 0;
boolean wdt = 0;
int wdtcounter = 0;
void initADC()
ADMUX = (1 << ADLAR) | (0 << REFS1) | (0 << REFS0) | (0 << MUX3) | (0 << MUX2) | (1 << MUX1) | (0 << MUX0);
ADCSRA = (1 << ADEN) | (1 << ADPS2) | (1 << ADPS1) | (0 << ADPS0);
mySwitch.enableTransmit(1);
mySwitch.setProtocol(1);
mySwitch.setPulseLength(320);
mySwitch.setRepeatTransmit(5);
pinMode(INT_PIN, INPUT_PULLUP);
external_interrupt();
ISR (PCINT0_vect){
MCUCR&=~(1<<SE);
ISR(WDT_vect)
MCUCR&=~(1<<SE);
wdt = 1;
wdtcounter++;
void external_interrupt()
sei(); //enabling global interrupt
GIMSK|= (1<<PCIE); //Pin change interrupt enable
PCMSK|=(1<<INTERRUPT_PIN);
void enters_sleep()
adc_disable();
setup_watchdog(9);
MCUCR|=(1<<SM1); // enabling sleep mode and powerdown sleep mode
MCUCR|= (1<<SE); //Enabling sleep enable bit
__asm__ __volatile__ ( "sleep" "\n\t" :: ); //Sleep instruction to put controller to sleep
//controller stops executing instruction after entering sleep mode
void setup_watchdog(int ii)
// 0=16ms, 1=32ms,2=64ms,3=128ms,4=250ms,5=500ms
// 6=1 sec,7=2 sec, 8=4 sec, 9= 8sec
uint8_t bb;
if (ii > 9 ) ii=9;
bb=ii & 7;
if (ii > 7) bb|= (1<<5);
bb|= (1<<WDCE);
MCUSR &= ~(1<<WDRF);
// start timed sequence
WDTCR |= (1<<WDCE) | (1<<WDE);
// set new watchdog timeout value
WDTCR = bb;
WDTCR |= _BV(WDIE);
//this will loop the watchdog 225 times 8 seconds
if(wdt == 1 && wdtcounter < 225){
wdt = 0;
enters_sleep();
else if (wdt == 1 && wdtcounter == 225){
initADC();
wdtcounter = 0;
ADCSRA |= (1 << ADSC);
while (ADCSRA & (1 << ADSC) );
if (ADCH > 250){
mySwitch.send(10109100, 24);
wdt = 0;
enters_sleep();
else{
mySwitch.send(10109005, 24);
wdt = 0;
enters_sleep();
else{
if( digitalRead(INT_PIN) == HIGH && timerhigh < 5 ) {
timerlow = 0;
mySwitch.send(10107000, 24);
timerhigh++;
else if( digitalRead(INT_PIN) == LOW && timerlow < 5 ){
timerhigh = 0;
mySwitch.send(10108000, 24);
timerlow++;
else{
timerhigh = 0;
timerlow = 0;
enters_sleep();
Re: Attiny85(RF,Sleep,Interrupt,Timer,Battery Level(3xAAA)
En wordt het nu wakker als je hard met de deur gooit?
geintje want er staat geen vraag meer bij.
2 berichten
Gebruikers in dit forum: Bing [Bot] en 14 gasten
