WiFiSDCard
WiFiSDCard
Beste dames heren,
ik wil dit voorbeeld laten draaien op een nodemcu
ik heb alles geinsatelleerd zoals aangegeven toch krijg ik dit niet aan de gang..
wie kan mij helpen
Dit zijn de fouten bij het compileren
In file included from C:\Users\Peter\Desktop\kalf\files\WiFiSDCard\WiFiSDCard\wificard\wificard.ino:8:0:
C:\Users\Peter\Documents\Arduino\libraries\ESPWebDAV-master/ESPWebDAV.h:39:43: error: 'FatFile' has not been declared
void sendPropResponse(boolean recursing, FatFile *curFile);
C:\Users\Peter\Documents\Arduino\libraries\ESPWebDAV-master/ESPWebDAV.h:42:40: error: 'FatFile' has not been declared
void handleWriteError(String message, FatFile *wFile);
C:\Users\Peter\Documents\Arduino\libraries\ESPWebDAV-master/ESPWebDAV.h:64:2: error: 'SdFat' does not name a type
SdFat sd;
exit status 1
Fout bij het compileren voor board NodeMCU 0.9 (ESP-12 Module)
// Using the WebDAV server with Rigidbot 3D printer.
// Printer controller is a RUMBA running Marlin firmware
#include <ESP8266WiFi.h> //https://github.com/esp8266/Arduino
#include <DNSServer.h> //Local DNS Server used for redirecting all requests to the configuration portal
#include <ESP8266WebServer.h> //Local WebServer used to serve the configuration portal
#include <WiFiManager.h> //https://github.com/tzapu/WiFiManager WiFi Configuration Magic
#include <ESPWebDAV.h> // https://github.com/ardyesp/ESPWebDAV
// LED is connected to GPIO2 on this board
#define INIT_LED {pinMode(2, OUTPUT);}
#define LED_ON {digitalWrite(2, LOW);}
#define LED_OFF {digitalWrite(2, HIGH);}
#define HOSTNAME "WiFiSDcard"
#define SERVER_PORT 80
#define SPI_BLOCKOUT_PERIOD 20000
#define SD_CS 4
#define MISO 12
#define MOSI 13
#define SCLK 14
#define CS_SENSE 5
#define SPI_SPEED SD_SCK_MHZ(50)
WiFiServer server(80); //Set web server port number to 80
int serverPort;
String header; // Variable to store the HTTP request
ESPWebDAV dav;
String statusMessage;
bool initFailed = false;
volatile long spiBlockoutTime = 0;
bool weHaveBus = false;
void ICACHE_RAM_ATTR testspi();
// Detect when other master uses SPI bus
pinMode(CS_SENSE, INPUT);
attachInterrupt(digitalPinToInterrupt(CS_SENSE), testspi, FALLING);
INIT_LED;
blink();
// wait for other master to assert SPI bus first
delay(SPI_BLOCKOUT_PERIOD);
// Log into access point
WiFiManager wifiManager; //Initialize library, in your setup function
//wifiManager.resetSettings(); // clears logon info for testing
WiFi.hostname("WiFiSDcard");
wifiManager.setDebugOutput(false);
wifiManager.setMinimumSignalQuality(7);
wifiManager.setRemoveDuplicateAPs(false);
// wifiManager.setConnectTimeout(60);
wifiManager.autoConnect("WiFiSDcard", "12345678"); // fallback AP name and password first parameter is name of access point, second is the password
wifiManager.setConfigPortalTimeout(180); // it will wait 3 minutes When the time passes, the autoConnect function will return
// ----- SD Card and Server -------
// Check to see if other master is using the SPI bus
while (millis() < spiBlockoutTime)
blink();
takeBusControl();
// start the SD DAV server
if (!dav.init(SD_CS, SPI_SPEED, SERVER_PORT)) {
// indicate error on LED
errorBlink();
initFailed = true;
blink();
relenquishBusControl();
if (millis() < spiBlockoutTime)
blink();
// do it only if there is a need to read FS
if (dav.isClientWaiting()) {
if (initFailed)
return dav.rejectClient(statusMessage);
// has other master been using the bus in last few seconds
return dav.rejectClient("Marlin is reading from SD card");
// a client is waiting and FS is ready and other SPI master is not using the bus
takeBusControl();
dav.handleClient();
void testspi() {
if (!weHaveBus)
spiBlockoutTime = millis() + SPI_BLOCKOUT_PERIOD;
void takeBusControl() {
weHaveBus = true;
LED_ON;
pinMode(MISO, SPECIAL);
pinMode(MOSI, SPECIAL);
pinMode(SCLK, SPECIAL);
pinMode(SD_CS, OUTPUT);
void relenquishBusControl() {
pinMode(MISO, INPUT);
pinMode(MOSI, INPUT);
pinMode(SCLK, INPUT);
pinMode(SD_CS, INPUT);
LED_OFF;
weHaveBus = false;
void blink() {
LED_ON;
delay(100);
LED_OFF;
delay(400);
void errorBlink() {
for (int i = 0; i < 100; i++) {
LED_ON;
delay(50);
LED_OFF;
delay(50);
wie kan mij helpen
SdFat sd;
exit status 1
#define SD_CS 4
#define MISO 12
#define MOSI 13
#define SCLK 14
#define CS_SENSE 5
int serverPort;
ESPWebDAV dav;
INIT_LED;
blink();
blink();
takeBusControl();
errorBlink();
initFailed = true;
blink();
blink();
if (initFailed)
takeBusControl();
dav.handleClient();
void testspi() {
if (!weHaveBus)
weHaveBus = true;
LED_ON;
LED_OFF;
weHaveBus = false;
void blink() {
LED_ON;
delay(100);
LED_OFF;
delay(400);
void errorBlink() {
LED_ON;
delay(50);
LED_OFF;
delay(50);
Re: WiFiSDCard
zoals je zelf ook wel snapt doe je een hoop includes en ergens daarin staat de fatfile, maar dat kan komen omdat je de verkeerde library ophaalt of een andere versie van hetzelfde.
het staat alledrie in espwebdav
