s-meter
Geregistreerd: 02 Sep 2014, 20:04
s-meter
Berichtdoor pd0nad » 02 Sep 2014, 20:08
kan iemand mijn hierbij helpen krijg steeds een fout melding
bij void writeMeter( int level, char label )
VrGr Cees
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 7, 6);
// set up the LCD's number of columns and rows:
const int numRows = 2;
const int numCols = 16;
byte meter_s1[8] = {
B00000,
B00000,
B00000,
B00000,
B00000,
B00000,
B11000,
B11000
byte meter_s3[8] = {
B00000,
B00000,
B00000,
B00000,
B00000,
B00011,
B11011,
B11011
byte meter_s5[8] = {
B00000,
B00000,
B00000,
B00000,
B11000,
B11000,
B11000,
B11000,
byte meter_s7[8] = {
B00000,
B00000,
B00000,
B00011,
B11011,
B11011,
B11011,
B11011,
byte meter_s9[8] = {
B00000,
B00000,
B11000,
B11000,
B11000,
B11000,
B11000,
B11000,
byte meter_s10[8] = {
B00000,
B00011,
B11011,
B11011,
B11011,
B11011,
B11011,
B11011,
byte meter_s20[8] = {
B11000,
B11000,
B11000,
B11000,
B11000,
B11000,
B11000,
B11000,
byte meter_s30[8] = {
B11011,
B11011,
B11011,
B11011,
B11011,
B11011,
B11011,
B11011,
lcd.setCursor(0,0);
lcd.write( label );
lcd.setCursor(1,0);
lcd.write( ' ' );
lcd.setCursor(2,0);
lcd.write( ' ' );
lcd.setCursor(3,0);
lcd.write( ' ' );
lcd.setCursor(4,0);
lcd.write( ' ' );
lcd.setCursor(5,0);
lcd.write( ' ' ); switch( level ){
case 40: lcd.createChar(4, meter_s30); lcd.setCursor(5,0); lcd.write( 4 );
case 30: lcd.createChar(4, meter_s30);
case 20: if( level == 20 ) lcd.createChar(4, meter_s20); lcd.setCursor(4,0); lcd.write( 4 );
case 10: lcd.createChar(3, meter_s10);
case 9: if( level == 9 ) lcd.createChar(3, meter_s9); lcd.setCursor(3,0); lcd.write( 3 );
case 7: lcd.createChar(2, meter_s7);
case 5: if( level == 5 ) lcd.createChar(2, meter_s5); lcd.setCursor(2,0); lcd.write( 2 );
case 3: lcd.createChar(1, meter_s3);
case 1: if( level == 1 ) lcd.createChar(1, meter_s1); lcd.setCursor(1,0); lcd.write( 1 );
case 0:
default: break;
Re: s-meter
Berichtdoor shooter » 02 Sep 2014, 20:35
B00000,
B00000,
B00000,
B00000,
B00000,
B00000,
B11000,
B11000
B00000,
B00000,
B00000,
B00000,
B00000,
B00011,
B11011,
B11011
B00000,
B00000,
B00000,
B00000,
B11000,
B11000,
B11000,
B11000,
B00000,
B00000,
B00000,
B00011,
B11011,
B11011,
B11011,
B11011,
B00000,
B00000,
B11000,
B11000,
B11000,
B11000,
B11000,
B11000,
B00000,
B00011,
B11011,
B11011,
B11011,
B11011,
B11011,
B11011,
B11000,
B11000,
B11000,
B11000,
B11000,
B11000,
B11000,
B11000,
B11011,
B11011,
B11011,
B11011,
B11011,
B11011,
B11011,
B11011,
} // en hier ook om setup te eindigen
{ // hier miste een haakje
lcd.setCursor(0,0);
lcd.write( label );
lcd.setCursor(1,0);
lcd.write( ' ' );
lcd.setCursor(2,0);
lcd.write( ' ' );
lcd.setCursor(3,0);
lcd.write( ' ' );
lcd.setCursor(4,0);
lcd.write( ' ' );
lcd.setCursor(5,0);
lcd.write( ' ' );
switch( level ){
break; // horen hier geen breaks tussen?
case 0:
default: break;
void loop() // en ik miste de loop
writeMeter.....
}probeer ook eens auto format die waarschuwt je voor dit soort fouten, en het levert ook nog een mooie file met inspriningen op.
Re: s-meter
Berichtdoor shooter » 03 Sep 2014, 19:00
B00000,
B00000,
B00000,
B00000,
B00000,
B00000,
B11000,
B11000
B00000,
B00000,
B00000,
B00000,
B00000,
B00011,
B11011,
B11011
B00000,
B00000,
B00000,
B00000,
B11000,
B11000,
B11000,
B11000,
B00000,
B00000,
B00000,
B00011,
B11011,
B11011,
B11011,
B11011,
B00000,
B00000,
B11000,
B11000,
B11000,
B11000,
B11000,
B11000,
B00000,
B00011,
B11011,
B11011,
B11011,
B11011,
B11011,
B11011,
B11000,
B11000,
B11000,
B11000,
B11000,
B11000,
B11000,
B11000,
B11011,
B11011,
B11011,
B11011,
B11011,
B11011,
B11011,
B11011,
lcd.setCursor(0,0);
lcd.write( label );
lcd.setCursor(1,0);
lcd.write( ' ' );
lcd.setCursor(2,0);
lcd.write( ' ' );
lcd.setCursor(3,0);
lcd.write( ' ' );
lcd.setCursor(4,0);
lcd.write( ' ' );
lcd.setCursor(5,0);
lcd.write( ' ' );
switch( level ){
case 0:
default: break;
{Writemeter (1,"A"}
je programma is dus nog niet af je zult die writemeter ergens aan moeten roepen.
zo ik heb de declaraties van de bytes uit de setup gehaald, en nu kun je ze overal gebruiken.
als je ze ergens declareert dan werken ze alleen maar in die subroutine.
Terug naar Overige projecten
