ALARM MELDING STUREN VIA GSM SHIELD
Kan iemand mij helpen aan de code om een vast bericht (vb : alarm ) 1x naar een vast gsm - nr. te zenden zonder gebruik te maken van de seriële monitor maar wel via een 1 op een digitale ingang vb nr 2 ? Ik probeer de code in arduino - exampels - gsm - sending sms aan te passen maar die werkt volledig met de seriële monitor.Dit is de originele code :
SMS sender
This sketch, for the Arduino GSM shield,sends an SMS message
you enter in the serial monitor. Connect your Arduino with the
GSM shield and SIM card, open the serial monitor, and wait for
the "READY" message to appear in the monitor. Next, type a
message to send and press "return". Make sure the serial
monitor is set to send a newline when you press return.
Circuit:
* GSM shield
* SIM card that can send SMS
created 25 Feb 2012
by Tom Igoe
This example is in the public domain.
http://arduino.cc/en/Tutorial/GSMExamplesSendSMS
// Include the GSM library
#include <GSM.h>
#define PINNUMBER ""
// initialize the library instance
GSM gsmAccess;
GSM_SMS sms;
// initialize serial communications and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
Serial.println("SMS Messages Sender");
// connection state
boolean notConnected = true;
// Start GSM shield
// If your SIM has PIN, pass it as a parameter of begin() in quotes
while(notConnected)
if(gsmAccess.begin(PINNUMBER)==GSM_READY)
notConnected = false;
Serial.println("Not connected");
Serial.println("GSM initialized");
Serial.print("Enter a mobile number: ");
char remoteNum[20]; // telephone number to send sms
readSerial(remoteNum);
Serial.println(remoteNum);
// sms text
Serial.print("Now, enter SMS content: ");
char txtMsg[200];
readSerial(txtMsg);
Serial.println("SENDING");
Serial.println("Message:");
Serial.println(txtMsg);
// send the message
sms.beginSMS(remoteNum);
sms.print(txtMsg);
sms.endSMS();
Serial.println("\nCOMPLETE!\n");
Read input serial
int readSerial(char result[])
int i = 0;
while(1)
while (Serial.available() > 0)
char inChar = Serial.read();
if (inChar == '\n')
result[i] = '\0';
Serial.flush();
return 0;
if(inChar!='\r')
result[i] = inChar;
i++;
SMS sender
Circuit:
* GSM shield
created 25 Feb 2012
by Tom Igoe
#include <GSM.h>
GSM gsmAccess;
GSM_SMS sms;
while (!Serial) {
// connection state
// Start GSM shield
while(notConnected)
// sms text
char txtMsg[200];
readSerial(txtMsg);
// send the message
sms.print(txtMsg);
sms.endSMS();
Read input serial
int i = 0;
while(1)
if (inChar == '\n')
result[i] = '\0';
Serial.flush();
return 0;
if(inChar!='\r')
result[i] = inChar;
i++;
Re: ALARM MELDING STUREN VIA GSM SHIELD
Ik denk dat het ongeveer zo moet zijn maar ik heb niet de goede library's om te testen:
Als je in de loop de triggersms naar 1 zet wordt er 1x een sms gestuur en daarna staat de waarde weer op 0.
Ik heb de Serial prints voor debugging even laten staan, dan kun je zien wat er mis gaat.
Daarna kun je natuurlijk alles wat begint met Serial weghalen.
ps. een verzoek om in het forum de code tags te gebruiken zodat de code leesbaar in een apart veld komt.
#include <GSM.h>
GSM gsmAccess;
GSM_SMS sms;
int triggersms = 0;
// connection state
// Start GSM shield
while(notConnected) {
void sendsms() {
if (triggersms == 1) {
// sms text
// send the message
sms.beginSMS(0655555555);
sms.print("ALARM");
sms.endSMS();
triggersms =0;
