zomer wintertijd
2 berichten
zomer wintertijd
ik zie dat er nog al wat vragenzijn over de zomer en winterstand dus deze code past deze aan
ool de relais schakeling er bij gezet , een diplay kan er aan worden toegevoegd
veel plezier met de code
#include <EEPROM.h>
#include <RTClib.h>
RTC_DS3231 rtc;
int DST;
int Relay = 4;
// relay gaat aan om 22,48 en uit om 22,49
const int OnHour = 22; //het uur waneer er geschakelt word (24 uur FORMAT)
const int OnMin = 48;//de minuten
const int OffHour = 22; //uit tijd
const int OffMin = 49;
pinMode(Relay, OUTPUT);
digitalWrite(Relay, LOW);
DST = EEPROM.get(0, DST);
if(DST != 0 && DST != 1)
DST = 1;
EEPROM.put(0, DST);
// Uncomment the following 2 lines if you need to set the DST (if you miss the actual day etc). Change the +1 to -1 in the fall.
// DateTime t2 = rtc.now();
// rtc.adjust(DateTime(t2.year(), t2.month(), t2.day(), t2.hour()+1, t2.minute(), t2.second()));
DateTime now = rtc.now();
Serial.println("Current Date & Time: ");
Serial.print(now.year(), DEC);
Serial.print('/');
Serial.print(now.month(), DEC);
Serial.print('/');
Serial.print(now.day(), DEC);
Serial.print(" (");
Serial.print(now.dayOfTheWeek(), DEC);
Serial.print(") ");
Serial.print(now.hour(), DEC);
Serial.print(':');
Serial.print(now.minute(), DEC);
Serial.print(':');
Serial.print(now.second(), DEC);
Serial.println();
if (now.dayOfTheWeek() == 0 && now.month() == 3 && now.day() >= 8 && now.day() <= 16 && now.hour() == 2 && now.minute() == 0 && now.second() == 0 && DST == 0)
rtc.adjust(DateTime(now.year(), now.month(), now.day(), now.hour()+1, now.minute(), now.second()));
DST = 1;
EEPROM.put(0, DST);
else if(now.dayOfTheWeek() == 0 && now.month() == 11 && now.day() >= 1 && now.day() <= 8 && now.hour() == 2 && now.minute() == 0 && now.second() == 0 && DST == 1)
rtc.adjust(DateTime(now.year(), now.month(), now.day(), now.hour()-1, now.minute(), now.second()));
DST = 0;
EEPROM.put(0, DST);
if (now.hour() == OnHour && now.minute() == OnMin) // When the values are equivalent
digitalWrite(Relay, HIGH); // Pin 4 is HIGH
Serial.println("LIGHT ON"); // Print the Message
else if (now.hour() == OffHour && now.minute() == OffMin) // When the values are equivalent
digitalWrite(Relay, LOW); // Pin 4 is Low
Serial.println("LIGHT OFF"); // Print the Message
2 berichten
Gebruikers in dit forum: Google [Bot] en 20 gasten
