BLUETOOTH Multi Servo motor Control Android APP
Geregistreerd: 12 Mei 2016, 01:43
Berichtdoor arduinosensorsNL » 21 Okt 2016, 01:05
Een app & code voor multi servo control via bluetooth.
Bekijk de video hier: https://youtu.be/UxBuROjlHE4
Download de app hier: https://play.google.com/store/apps/details?id=appinventor.ai_addmefaster1.BlueCore_Tech_Multi_Servo_Control
De app is ook open source verkrijgbaar stuur een mailtje naar contact@arduinosensors.nl!
Schema:
Afbeelding
Onderdelenlijst.
Arduino uno, (Use a mega if you want to use more then 6 Servos!) i used the RobotDyn Uno.
HC-06 Bluetooth module, or any other.
6 x Servo motor. (Can test with one to of course)
Jumper wires set MM/FF/MF
Android phone.
Code:
Author: Danny van den Brande.
With this code you can control multiple servo motors by using a android app.
You can add as many as you like untill your pins run out. You can add more Servos in the code.
If you want the source of the app just contact me.
#include <Servo.h>
Servo myservo1, myservo2, myservo3, myservo4, myservo5, myservo6, myservo7, myservo8, myservo9, myservo10;
byte serialA;
  myservo1.attach(9);
  myservo2.attach(10);
  myservo3.attach(11);
  myservo4.attach(3);
  myservo5.attach(5);
  myservo6.attach(6);
//  myservo7.attach(); fill in pin numbers if you use more then 6 servos i left them blank
//  myservo8.attach();
//  myservo9.attach();
//  myservo10.attach();
  Serial.begin(9600);//change your baudrate to your Bluetooth modules baudrate if needed.
  if (Serial.available() > 2) {serialA = Serial.read();Serial.println(serialA);}
    unsigned int servopos = Serial.read();
    unsigned int servopos1 = Serial.read();
    unsigned int realservo = (servopos1 *256) + servopos;
    Serial.println(realservo);
    if (realservo >= 1000 && realservo <1180){
    int servo1 = realservo;
    servo1 = map(servo1, 1000,1180,0,180);
    myservo1.write(servo1);
    Serial.println("servo 1 ON");
    delay(10);
    if (realservo >=2000 && realservo <2180){
      int servo2 = realservo;
      servo2 = map(servo2,2000,2180,0,180);
      myservo2.write(servo2);
      Serial.println("servo 2 On");
      delay(10);
    if (realservo >=3000 && realservo < 3180){
      int servo3 = realservo;
      servo3 = map(servo3, 3000, 3180,0,180);
      myservo3.write(servo3);
      Serial.println("servo 3 On");
      delay(10);
    if (realservo >=4000 && realservo < 4180){
      int servo4 = realservo;
      servo4 = map(servo4, 4000, 4180,0,180);
      myservo4.write(servo4);
      Serial.println("servo 4 On");
      delay(10);
    if (realservo >=5000 && realservo < 5180){
      int servo5 = realservo;
      servo5 = map(servo5, 5000, 5180,0,180);
      myservo5.write(servo5);
      Serial.println("servo 5 On");
      delay(10);
    if (realservo >=6000 && realservo < 6180){
      int servo6 = realservo;
      servo6 = map(servo6, 6000, 6180,0,180);
      myservo6.write(servo6);
      Serial.println("servo 6 On");
      delay(10);
//    if (realservo >=7000 && realservo < 7180){ //UNCOMMENT if using more then 6 Servos.
//      int servo7 = realservo;
//      servo7 = map(servo7, 7000, 7180,0,180);
//      myservo7.write(servo7);
//      Serial.println("servo 7 On");
//      delay(10);
//    if (realservo >=8000 && realservo < 8180){
//      int servo8 = realservo;
//      servo8 = map(servo8, 8000, 8180,0,180);
//      myservo8.write(servo8);
//      Serial.println("servo 8 On");
//      delay(10);
//    if (realservo >=9000 && realservo < 9180){
//      servo8 = map(servo9, 9000, 9180,0,180);
//      Serial.println("servo 9 On");
//      delay(10);
//    if (realservo >=10000 && realservo < 10180){
//      int servo10 = realservo;
//      servo10 = map(servo10, 10000, 10180,0,180);
//      myservo10.write(servo10);
//      Serial.println("servo 10 On");
//      delay(10);
Zie de instructable hier: http://www.instructables.com/id/ArduinoAndroid-BLUETOOTH-Multi-Servo-Motor-Control/
Sensors voor arduino! http://arduinosensors.nl
Re: BLUETOOTH Multi Servo motor Control Android APP
Berichtdoor nicoverduin » 21 Okt 2016, 16:17
Danny, je zou eens kunnen overwegen wat meer commentaar in jouw code te zetten. Of je hier reclame mag maken voor jouw eigen site laat ik aan de hoofd moderator over.
Berichtdoor shooter » 21 Okt 2016, 20:17
je kunt beter schrijven servo1 =map (realservo...... want nu gebruik je de variabele servox voor 2 verschillende waardes.
verder is een array een goed idee voor al die waardes, want nu staan ze in de broncode wat lastig zoeken is.
kijk eens naar functie zodat de loop wat kleiner wordt.
dan kun je bijvoorbeeld die delay in de loop zetten en heb je hem maar 1 keer nodig.
de website ziet er prima uit hoor,
de software bij de sensoren wel behoorlijk nazien (er wordt bijvoorbeeld een boolean naar een INTeger geschreven , dat werkt wel maar is niet netjes,
Ga lekker door en als je denkt dat je een partner zoekt, dan mag je altijd contact opnemen.
