SPFD5408 TFT LCD 2.4 TEMP and HUMIDiTY Monitor.
1 bericht
- arduinosensorsNL
- Geregistreerd: 12 Mei 2016, 01:43
Een project met de SPFD5408 TFT 2.4 LCD
Bekijk de video hier: https://youtu.be/p7b41EoFexM
Schema:
Monteer de TFT LCD boven op de arduino mega 2560
Onderdelenlijst:
Arduino Mega 2560
2.4 TFT LCD SPFD5408 (Aliexpress got them very cheap)
DHT11 Temperature sensor. KY-015
Jumper wires
De code:
Ga hier naar de instructable: http://www.instructables.com/id/ARDUINO-SPFD5408-TFT-LCD-2-4-TEMP-and-HUMIDiTY-Mon/
Schema:
Onderdelenlijst:
Arduino Mega 2560
Jumper wires
De code:
Author: Danny van den Brande, ArduinoSensors.nl. Bluecore Tech.
#include <SPFD5408_Adafruit_GFX.h> // Core graphics Adafruit library
#include <SPFD5408_Adafruit_TFTLCD.h> // Hardware-specific library
#include <SPFD5408_TouchScreen.h> // Touchscreen library
#include "DHT.h"
#define DHTPIN A8
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
// *** Define Touchscreen Pin
#define YP A3
#define XM A2
#define YM 9
#define XP 8
// *** Define Value of Touchscreen input
#define TS_MINX 150
#define TS_MINY 120
#define TS_MAXX 920
#define TS_MAXY 940
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
// *** Define Pin of LCD used
#define LCD_CS A3
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
#define LCD_RESET A4
// *** Define Name of Color
#define BLACK 0x0000
#define WHITE 0xFFFF
#define RED 0xF800
#define GREEN 0x07E0
#define BLUE 0x001F
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define GREY 0x2108
Adafruit_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
#define MINPRESSURE 10
#define MAXPRESSURE 1000
// Meter colour schemes
#define RED2RED 0
#define GREEN2GREEN 1
#define BLUE2BLUE 2
#define BLUE2RED 3
#define GREEN2RED 4
#define RED2GREEN 5
uint32_t runTime = -99999; // time for next update
int reading = 0; // Value to be displayed
int d = 0; // Variable used for the sinewave test waveform
boolean alert = 0;
int8_t ramp = 1;
int tesmod =0;
tft.reset(); //Reset LCD to begin
tft.begin(0x9341); //SDFP5408 Chipset ID on Library
tft.setRotation(3); // Set Rotation at 0 degress (default)
tft.fillScreen(BLACK); //Set Background Color with BLACK
tft.setCursor (7,208);
tft.setTextSize (3);
tft.setTextColor (WHITE,BLACK);
tft.print ("HUMIDITY");
tft.setCursor (75,78);
tft.setTextSize (1);
tft.print ("TEMPERATURE");
tft.setCursor (70,66);
tft.print ("BLUECORE TECH");
tft.setCursor (242,20);
tft.print ("FAHRENHEIT");
tft.setCursor (242,118);//heat index fahrenheit
tft.print ("HEAT INDEX");
tft.setCursor (238,205);//heat index fahrenheit
tft.print ("HEAT INDEX C");
tft.setCursor (265,220);//Small celcius text
tft.print ("CELSIUS");
//Design Interface (lines)
tft.fillRect(0,197,320,4,BLUE);
tft.fillRect(0,236,320,4,BLUE);
tft.fillRect(217,0,4,240,BLUE);
tft.fillRect(217,98,320,4,BLUE);
tft.drawCircle(xpos, 120, a, BLUE);}
float h = dht.readHumidity();
float t = dht.readTemperature();
float f = dht.readTemperature(true);
// Compute heat index in Fahrenheit (the default)
float hif = dht.computeHeatIndex(f, h);
// Compute heat index in Celsius (isFahreheit = false)
float hic = dht.computeHeatIndex(t, h, false);
if (millis() - runTime >= 500) { // Execute every 500ms
runTime = millis();
if(tesmod==0){reading=99; }
if(tesmod==1){reading = t;}
int xpos = 0, ypos = 5, gap = 4, radius = 52;
// Draw a large meter
xpos = 320/2 - 160, ypos = 0, gap = 100, radius = 105;
ringMeter(reading,0,100, xpos,ypos,radius,"Celsius",GREEN2RED); // Draw analogue meter
if(h>0){ //Humidity %
tft.setCursor (157,208);
tft.setTextColor (BLUE,BLACK);
tft.print (h,0); tft.print ('%');
tesmod=1;
if(f>0){ //Fahrenheit
tft.setCursor (237,38);
tft.setTextSize (4);
tft.print (f,0);
tesmod=1;
if(hif>0){ //Heat index Fahrenheit
tft.setCursor (237,138);
tft.print (hif,0);
tesmod=1;
if(hic>0){ //Heat index Celsius
tft.setCursor (238,217);
tft.setTextSize (2);
tft.print (hic,0);
tesmod=1;
// Draw the meter on the screen, returns x coord of righthand side
int ringMeter(int value, int vmin, int vmax, int x, int y, int r, char *units, byte scheme)
// Minimum value of r is about 52 before value text intrudes on ring
// drawing the text first is an option
x += r; y += r; // Calculate coords of centre of ring
int w = r / 3; // Width of outer ring is 1/4 of radius
int angle = 150; // Half the sweep angle of meter (300 degrees)
int v = map(value, vmin, vmax, -angle, angle); // Map the value to an angle v
byte seg = 3; // Segments are 3 degrees wide = 100 segments for 300 degrees
byte inc = 6; // Draw segments every 3 degrees, increase to 6 for segmented ring
// Variable to save "value" text colour from scheme and set default
int colour = BLUE;
// Draw colour blocks every inc degrees
for (int i = -angle+inc/2; i < angle-inc/2; i += inc) {
// Calculate pair of coordinates for segment start
float sx = cos((i - 90) * 0.0174532925);
float sy = sin((i - 90) * 0.0174532925);
uint16_t x0 = sx * (r - w) + x;
uint16_t y0 = sy * (r - w) + y;
uint16_t x1 = sx * r + x;
uint16_t y1 = sy * r + y;
// Calculate pair of coordinates for segment end
float sx2 = cos((i + seg - 90) * 0.0174532925);
float sy2 = sin((i + seg - 90) * 0.0174532925);
int x2 = sx2 * (r - w) + x;
int y2 = sy2 * (r - w) + y;
int x3 = sx2 * r + x;
int y3 = sy2 * r + y;
if (i < v) { // Fill in coloured segments with 2 triangles
switch (scheme) {
case 0: colour = RED; break; // Fixed colour
case 1: colour = GREEN; break; // Fixed colour
case 2: colour = BLUE; break; // Fixed colour
case 3: colour = rainbow(map(i, -angle, angle, 0, 127)); break; // Full spectrum blue to red
case 4: colour = rainbow(map(i, -angle, angle, 70, 127)); break; // Green to red (high temperature etc)
case 5: colour = rainbow(map(i, -angle, angle, 127, 63)); break; // Red to green (low battery etc)
default: colour = BLUE; break; // Fixed colour
tft.fillTriangle(x0, y0, x1, y1, x2, y2, colour);
tft.fillTriangle(x1, y1, x2, y2, x3, y3, colour);
//text_colour = colour; // Save the last colour drawn
else // Fill in blank segments
tft.fillTriangle(x0, y0, x1, y1, x2, y2, GREY);
tft.fillTriangle(x1, y1, x2, y2, x3, y3, GREY);
// Convert value to a string
char buf[10];
byte len = 2; if (value > 999) len = 4;
dtostrf(value, len, 0, buf);
buf[len] = ' '; buf[len] = 0; // Add blanking space and terminator, helps to centre text too!
// Set the text colour to default
tft.setTextSize(1);
if(value>9){
tft.setTextColor(colour,BLACK);
tft.setCursor(x-25,y-10);tft.setTextSize(5);
tft.print(buf);}
if(value<10){
tft.print(buf);}
tft.setTextColor(WHITE,BLACK);
tft.setCursor(x-39,y+75);tft.setTextSize(2);
tft.print(units); // Units display
// Calculate and return right hand side x coordinate
return x + r;
// Return a 16 bit rainbow colour
unsigned int rainbow(byte value)
// Value is expected to be in range 0-127
// The value is converted to a spectrum colour from 0 = blue through to 127 = red
byte red = 0; // Red is the top 5 bits of a 16 bit colour value
byte green = 0;// Green is the middle 6 bits
byte blue = 0; // Blue is the bottom 5 bits
byte quadrant = value / 32;
if (quadrant == 0) {
blue = 31;
green = 2 * (value % 32);
red = 0;
if (quadrant == 1) {
blue = 31 - (value % 32);
green = 63;
red = 0;
if (quadrant == 2) {
blue = 0;
green = 63;
red = value % 32;
if (quadrant == 3) {
blue = 0;
green = 63 - 2 * (value % 32);
red = 31;
return (red << 11) + (green << 5) + blue;
// Return a value in range -1 to +1 for a given phase angle in degrees
float sineWave(int phase) {
return sin(phase * 0.0174532925);
Sensors voor arduino! http://arduinosensors.nl
1 bericht
