CW-decoder ATMEGA 328P
Geregistreerd: 25 Aug 2016, 17:21
Berichtdoor adval40 » 24 Sep 2016, 23:05
Ik heb afgelopen weken een cw decoder gemaakt met aangepaste software
CW Decoder made by Hjalmar Skovholm Hansen OZ1JHM VER 1.01
Deze detecteert automatisch de seinsnelheid.
// CW Decoder made by Hjalmar Skovholm Hansen OZ1JHM  VER 1.01       //
// Feel free to change, copy or what ever you like but respect       //
// that license is http://www.gnu.org/copyleft/gpl.html              //
// Discuss and give great ideas on                                   //
// https://groups.yahoo.com/neo/groups/oz1jhm/conversations/messages //
// Modifications by PE1DGW. Bumped to VER 1.2:                       //
// Changed to work with the Arduino ATMEGA 328P.                     //
// Added selection of "Target Frequency" and "Bandwith" at power up. //
// Read more here http://en.wikipedia.org/wiki/Goertzel_algorithm        //
// if you want to know about FFT the http://www.dspguide.com/pdfbook.htm //
#include <LiquidCrystal.h>
// select the pins used on the LCD panel      /
//  LiquidCrystal lcd(RS, E, D4, D5, D6, D7) //
LiquidCrystal lcd(2, 3, 4, 5, 6, 7);
const int colums = 20; /// have to be 16 or 20
const int rows = 4;  /// have to be 2 or 4
int lcdindex = 0;
int line1[colums];
int line2[colums];
// Define 8 specials letters  //
byte U_umlaut[8] =   {B01010,B00000,B10001,B10001,B10001,B10001,B01110,B00000}; // 'Ü'
byte O_umlaut[8] =   {B01010,B00000,B01110,B10001,B10001,B10001,B01110,B00000}; // 'Ö'
byte A_umlaut[8] =   {B01010,B00000,B01110,B10001,B11111,B10001,B10001,B00000}; // 'Ä'
byte AE_capital[8] = {B01111,B10100,B10100,B11110,B10100,B10100,B10111,B00000}; // 'Æ'
byte OE_capital[8] = {B00001,B01110,B10011,B10101,B11001,B01110,B10000,B00000}; // 'Ø'
byte fullblock[8] =  {B11111,B11111,B11111,B11111,B11111,B11111,B11111,B11111};
byte AA_capital[8] = {B00100,B00000,B01110,B10001,B11111,B10001,B10001,B00000}; // 'Å'
byte emtyblock[8] =  {B00000,B00000,B00000,B00000,B00000,B00000,B00000,B00000};
int audioInPin  = A1 ;
int audioOutPin = 10 ;
int ledPin      = 13 ;
float magnitude ;
int magnitudelimit = 100;
int magnitudelimit_low = 100;
int realstate = LOW;
int realstatebefore = LOW;
int filteredstate = LOW;
int filteredstatebefore = LOW;
// The sampling frq will be 8928 on a 16 mhz             //
// without any prescaler etc                             //
// because we need the tone in the center of the bins    //
// you can set the tone to 496, 558, 744 or 992          //
// then n the number of samples which give the bandwidth //
// can be (8928 / tone) * 1 or 2 or 3 or 4 etc           //
// init is 8928/558 = 16 *4 = 64 samples                 //
// try to take n = 96 or 128 ;o)                         //
// 48 will give you a bandwidth around 186 hz            //
// 64 will give you a bandwidth around 140 hz            //
// 96 will give you a bandwidth around 94 hz             //
// 128 will give you a bandwidth around 70 hz            //
// BUT remember that high n take a lot of time           //
// so you have to find the compromice - i use 48         //
float coeff;
float Q1 = 0;
float Q2 = 0;
float sine;
float cosine;
float sampling_freq=8928.0;
float target_freq=0.0; /// adjust for your needs see above
int n=0;  //// if you change  her please change next line also
int testData[96];
float bw;
// Noise Blanker time which //
// shall be computed so     //
// this is initial          //
int nbtime = 6;  /// ms noise blanker
long starttimehigh;
long highduration;
long lasthighduration;
long hightimesavg;
long lowtimesavg;
long startttimelow;
long lowduration;
long laststarttime = 0;
char code[20];
int stop = LOW;
int wpm;
// init setup //
// The basic goertzel calculation //
// Modifications by KC2UEZ                                 //
// This code lets you select BW and Frequency at power up. //
 pinMode(A0, INPUT_PULLUP);
 pinMode(A1, INPUT_PULLUP);
 pinMode(A2, INPUT_PULLUP);
 pinMode(9,  INPUT_PULLUP);
  if (!digitalRead(A0) && !digitalRead(A1))
   n=32;
 else if (!digitalRead(A0) && digitalRead(A1))
   n=96;
 else if (digitalRead(A0) && !digitalRead(A1))
   n=64;
   n=48;
 if (!digitalRead(A2) && !digitalRead(9))
   target_freq=496.0;
 else if (!digitalRead(A2) && digitalRead(9))
   target_freq=992.0;
 else if (digitalRead(A2) && !digitalRead(9))
   target_freq=744.0;
   target_freq=558.0;
// End of modifications //
 bw = (sampling_freq/n);
  int  k;
  float omega;
  k = (int) (0.5 + ((n * target_freq) / sampling_freq));
  omega = (2.0 * PI * k) / n;
  sine = sin(omega);
  cosine = cos(omega);
  coeff = 2.0 * cosine;
// define special characters //
 lcd.createChar(0, U_umlaut); //     German
 lcd.createChar(1, O_umlaut); //     German, Swedish
 lcd.createChar(2, A_umlaut); //     German, Swedish
 lcd.createChar(3, AE_capital); //   Danish, Norwegian
 lcd.createChar(4, OE_capital); //   Danish, Norwegian
 lcd.createChar(5, fullblock);
 lcd.createChar(6, AA_capital); //   Danish, Norwegian, Swedish
 lcd.createChar(7, emtyblock);
 lcd.clear();
// Serial.begin(115200);
 pinMode(ledPin, OUTPUT);
 lcd.begin(colums, rows);
 for (int index = 0; index < colums; index++){
    line1[index] = 32;
  line2[index] = 32;
// main loop //
  // The basic where we get the tone //
  for (char index = 0; index < n; index++)
    testData[index] = analogRead(audioInPin);
  for (char index = 0; index < n; index++){
    float Q0;
    Q0 = coeff * Q1 - Q2 + (float) testData[index];
    Q2 = Q1;
    Q1 = Q0;
  float magnitudeSquared = (Q1*Q1)+(Q2*Q2)-Q1*Q2*coeff;  // we do only need the real part //
  magnitude = sqrt(magnitudeSquared);
  Q2 = 0;
  Q1 = 0;
  //Serial.print(magnitude); Serial.println();  //// here you can measure magnitude for setup..
  // here we will try to set the magnitude limit automatic //
  if (magnitude > magnitudelimit_low){
    magnitudelimit = (magnitudelimit +((magnitude - magnitudelimit)/6));  /// moving average filter
  if (magnitudelimit < magnitudelimit_low)
  magnitudelimit = magnitudelimit_low;
  // now we check for the magnitude //
  if(magnitude > magnitudelimit*0.6) // just to have some space up
     realstate = HIGH;
    realstate = LOW;
  // here we clean up the state with a noise blanker //
  if (realstate != realstatebefore){
  laststarttime = millis();
  if ((millis()-laststarttime)> nbtime){
  if (realstate != filteredstate){
    filteredstate = realstate;
 // Then we do want to have some durations on high and low //
 if (filteredstate != filteredstatebefore){
  if (filteredstate == HIGH){
    starttimehigh = millis();
    lowduration = (millis() - startttimelow);
  if (filteredstate == LOW){
    startttimelow = millis();
    highduration = (millis() - starttimehigh);
        if (highduration < (2*hightimesavg) || hightimesavg == 0){
      hightimesavg = (highduration+hightimesavg+hightimesavg)/3;     // now we know avg dit time ( rolling 3 avg)
    if (highduration > (5*hightimesavg) ){
      hightimesavg = highduration+hightimesavg;     // if speed decrease fast ..
 // now we will check which kind of baud we have - dit or dah //
 // and what kind of pause we do have 1 - 3 or 7 pause        //
 // we think that hightimeavg = 1 bit                         //
  stop = LOW;
  if (filteredstate == LOW){  //// we did end a HIGH
   if (highduration < (hightimesavg*2) && highduration > (hightimesavg*0.6)){ /// 0.6 filter out false dits
  strcat(code,".");
  Serial.print(".");
   if (highduration > (hightimesavg*2) && highduration < (hightimesavg*6)){
  strcat(code,"-");
  Serial.print("-");
  wpm = (wpm + (1200/((highduration)/3)))/2;  //// the most precise we can do ;o)
   if (filteredstate == HIGH){  //// we did end a LOW
   float lacktime = 1;
   if(wpm > 25)lacktime=1.0; ///  when high speeds we have to have a little more pause before new letter or new word
   if(wpm > 30)lacktime=1.2;
   if(wpm > 35)lacktime=1.5;
   if (lowduration > (hightimesavg*(2*lacktime)) && lowduration < hightimesavg*(5*lacktime)){ // letter space
    docode();
  code[0] = '\0';
  Serial.print("/");
   if (lowduration >= hightimesavg*(5*lacktime)){ // word space
    docode();
  code[0] = '\0';
  printascii(32);
 // write if no more letters //
  if ((millis() - startttimelow) > (highduration * 6) && stop == LOW){
   docode();
   code[0] = '\0';
   stop = HIGH;
 // we will turn on and off the LED //
 // and the speaker                 //
   if(filteredstate == HIGH){
     digitalWrite(ledPin, HIGH);
   tone(audioOutPin,target_freq);
   else{
     digitalWrite(ledPin, LOW);
   noTone(audioOutPin);
 // the end of main loop clean up//
 updateinfolinelcd();
 realstatebefore = realstate;
 lasthighduration = highduration;
 filteredstatebefore = filteredstate;
// translate cw code to ascii //
void docode(){
    if (strcmp(code,".-") == 0) printascii(65);
  if (strcmp(code,"-...") == 0) printascii(66);
  if (strcmp(code,"-.-.") == 0) printascii(67);
  if (strcmp(code,"-..") == 0) printascii(68);
  if (strcmp(code,".") == 0) printascii(69);
  if (strcmp(code,"..-.") == 0) printascii(70);
  if (strcmp(code,"--.") == 0) printascii(71);
  if (strcmp(code,"....") == 0) printascii(72);
  if (strcmp(code,"..") == 0) printascii(73);
  if (strcmp(code,".---") == 0) printascii(74);
  if (strcmp(code,"-.-") == 0) printascii(75);
  if (strcmp(code,".-..") == 0) printascii(76);
  if (strcmp(code,"--") == 0) printascii(77);
  if (strcmp(code,"-.") == 0) printascii(78);
  if (strcmp(code,"---") == 0) printascii(79);
  if (strcmp(code,".--.") == 0) printascii(80);
  if (strcmp(code,"--.-") == 0) printascii(81);
  if (strcmp(code,".-.") == 0) printascii(82);
  if (strcmp(code,"...") == 0) printascii(83);
  if (strcmp(code,"-") == 0) printascii(84);
  if (strcmp(code,"..-") == 0) printascii(85);
  if (strcmp(code,"...-") == 0) printascii(86);
  if (strcmp(code,".--") == 0) printascii(87);
  if (strcmp(code,"-..-") == 0) printascii(88);
  if (strcmp(code,"-.--") == 0) printascii(89);
  if (strcmp(code,"--..") == 0) printascii(90);
  if (strcmp(code,".----") == 0) printascii(49);
  if (strcmp(code,"..---") == 0) printascii(50);
  if (strcmp(code,"...--") == 0) printascii(51);
  if (strcmp(code,"....-") == 0) printascii(52);
  if (strcmp(code,".....") == 0) printascii(53);
  if (strcmp(code,"-....") == 0) printascii(54);
  if (strcmp(code,"--...") == 0) printascii(55);
  if (strcmp(code,"---..") == 0) printascii(56);
  if (strcmp(code,"----.") == 0) printascii(57);
  if (strcmp(code,"-----") == 0) printascii(48);
  if (strcmp(code,"..--..") == 0) printascii(63);
  if (strcmp(code,".-.-.-") == 0) printascii(46);
  if (strcmp(code,"--..--") == 0) printascii(44);
  if (strcmp(code,"-.-.--") == 0) printascii(33);
  if (strcmp(code,".--.-.") == 0) printascii(64);
  if (strcmp(code,"---...") == 0) printascii(58);
  if (strcmp(code,"-....-") == 0) printascii(45);
  if (strcmp(code,"-..-.") == 0) printascii(47);
  if (strcmp(code,"-.--.") == 0) printascii(40);
  if (strcmp(code,"-.--.-") == 0) printascii(41);
  if (strcmp(code,".-...") == 0) printascii(95);
  if (strcmp(code,"...-..-") == 0) printascii(36);
  if (strcmp(code,"...-.-") == 0) printascii(62);
  if (strcmp(code,".-.-.") == 0) printascii(60);
  if (strcmp(code,"...-.") == 0) printascii(126);
  // The specials //
  if (strcmp(code,".-.-") == 0) printascii(3);
  if (strcmp(code,"---.") == 0) printascii(4);
  if (strcmp(code,".--.-") == 0) printascii(6);
// print the ascii code to the lcd //
// one a time so we can generate   //
// special letters                 //
void printascii(int asciinumber){
int fail = 0;
if (rows == 4 and colums == 16)fail = -4; /// to fix the library problem with 4*16 display http://forum.arduino.cc/index.php/topic,14604.0.html
 if (lcdindex > colums-1){
  lcdindex = 0;
  if (rows==4){
    for (int i = 0; i <= colums-1 ; i++){
    lcd.setCursor(i,rows-3);
    lcd.write(line2[i]);
    line2[i]=line1[i];
    lcd.setCursor(i+fail,rows-2);
    lcd.write(line1[i]);
  lcd.setCursor(i+fail,rows-1);
    lcd.write(32);
 line1[lcdindex]=asciinumber;
 lcd.setCursor(lcdindex+fail,rows-1);
 lcd.write(asciinumber);
 lcdindex += 1;
void updateinfolinelcd(){
// here we update the upper line   //
// with the speed.                 //
// Modify to work with Frequency and BW selection. By KC2UEZ
  int place;
  if (rows == 4){
   place = 0;}
  else{
   place = 2;
        lcd.setCursor(0,0);
        if (wpm < 10)
            lcd.print("0");
           lcd.setCursor(0,0);
    lcd.print(wpm);
        lcd.setCursor(2,0);
    lcd.print(" WPM ");
        lcd.setCursor(7,0);
    lcd.print((int)target_freq);
        lcd.setCursor(10,0);
    lcd.print(" TF ");
        lcd.setCursor(14,0);
        if (bw < 100)
           lcd.print(" ");
    lcd.print((int)bw);
    lcd.print(" BW");
Re: CW-decoder ATMEGA 328P
Berichtdoor Koepel » 25 Sep 2016, 03:47
Heb je er ook een schema bij ? Is het anders dan een Arduino Uno ? Zet je het ook op Github ?
Het komt zo rommelig over. Er is Yahoo Groups, mypetarduino.com, skovholm.com. Misschien ligt het aan mij dat ik Yahoo Groups niet begrijp. Github heeft de nieuwste code en forks, en de wijzigingen zijn gemakkelijk te bekijken.
Ik zie nog wel een paar mogelijkheden om de software netter te maken.
Het belangrijkste is consequent gebruikt van haakjes en inspringen. Ik zie nu verschillende stijlen waarin de code is geschreven.
De variabelen waarin millis() wordt gebruikt moeten "unsigned long" zijn, anders ontstaat er een rollover probleem.
Ik denk dat je ook de 'duration' en de 'avg' van "long" naar "unsigned long" kunt omzetten.
Het vertalen van morse naar een teken zou iedere programmeur in een tabel zetten. Maar ach, als het zo werkt kun je het net zo goed zo laten.
De custom definities van de tekens kun je een 'const' maken. Je kunt die dingen custom characters noemen of zo iets.
Een 'letter' is een brief. Denk maar aan de Dear John Letter (https://nl.wikipedia.org/wiki/Dear_John_Letter).
Is er geen test wanneer er meer tekens in het array 'code' wordt geschreven dan de grootte van 20 ?
