Error messages during compiling
- maartentukker
- Geregistreerd: 07 Okt 2016, 10:33
Hello all,
I'm having some issues with my last code. I'm getting error messages, but i cannot see where the problem is. Can somebody help me in the right direction?
Code is:
Error messages are:
In file included from C:\Users\silek\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino/Arduino.h:32:0,
from C:\Users\silek\AppData\Local\Temp\arduino\sketches\36B34EAFC95DD53DFA4E5AA12D7B14E0\sketch\blok_stroomdetectie_spoor_onder_2.ino.cpp:1:
C:\Users\silek\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino/binary.h:39:13: error: expected unqualified-id before numeric constant
#define B10 2
C:\Users\silek\Documents\Maarten\Arduino\SPOOR NIEUW 2023\blok_stroomdetectie_spoor_onder_2\blok_stroomdetectie_spoor_onder_2.ino:28:11: note: in expansion of macro 'B10'
const int B10 = 17;
C:\Users\silek\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino/binary.h:46:13: error: expected unqualified-id before numeric constant
#define B11 3
C:\Users\silek\Documents\Maarten\Arduino\SPOOR NIEUW 2023\blok_stroomdetectie_spoor_onder_2\blok_stroomdetectie_spoor_onder_2.ino:29:11: note: in expansion of macro 'B11'
const int B11 = 18;
exit status 1
Compilation error: exit status 1
Code is:
```cpp
-------------- SPOOR ONDER ----------------
Block detection, Activated Block -1 is isolated, -2 is set free
Blokdetection by current sensor OKKIE
Blok_0 is for reference and correct switching of power (without flickering)
// Current sensors (Input from OKKIE)
const int Blok_0 = 3; // reference block
const int Blok_9 = 5;
const int Blok_10 = 6;
const int Blok_11 = 7;
const int Blok_12 = 8;
const int Blok_13 = 9;
const int Blok_14 = 10;
const int Blok_15 = 11;
const int Blok_16 = 12;
// Sections isolate (output to relais)
const int B7 = 14;
const int B8 = 15;
const int B9 = 16;
const int B10 = 17;
const int B11 = 18;
const int B12 = 19;
const int B13 = 20;
const int B14 = 21;
const int B15 = 22;
// Toggle switch for Track powerless for switching yard
const int S11 = 25;
const int S12 = 26;
const int S13 = 27;
const int S14 = 28;
int S11State = 0;
int S12State = 0;
int S13State = 0;
int S14State = 0;
// Pushbutton for resetting B10
const int Y10 = 29; // button to set B10 free after entry of switching yard
const int F10 = 30; // relais F10 to set free track next to B10 when there is a free track on switching yard acc to turnout position and toggleswitch
// Toggle switch input from Arduino 2 turnouts
const int W14 = 25;
const int W15 = 26;
const int W16 = 27;
const int W17 = 28;
const int W18 = 29;
const int W19 = 30;
// State change detection for switches
int W14State = 0;
int W15State = 0;
int W16State = 0;
int W17State = 0;
int W18State = 0;
int W19State = 0;
int lastW14State = 0;
int lastW15State = 0;
int lastW16State = 0;
int lastW17State = 0;
int lastW18State = 0;
int lastW19State = 0;
// State change for blocks NOT used by current detection method, because of continuous detecting instead of a pulse
// int lastHa1aState, lastHa1bState, lastHa2State, lastHa3State, lastHa4State, lastHa5State, lastHa6State, lastHa7State, lastHa8State, lastHa9State, lastHa10State, lastHa11State, lastHa12aState, lastHa12bState, lastHa13State;
// Timer to clear block after turnout has changed position (change millis and enabled name per switch)
const unsigned long interval = 3000; // Timer delay setting
unsigned long W_Millis; // Timer relais for S5 occupancy
bool enabled_W = false; // Software switch to start and stop timer
Serial.print("Sketch: ");
Serial.println(__FILE__);
Serial.print("Uploaded: ");
Serial.println(__DATE__);
Serial.println(" ");
// Sensors (OKKIE)
pinMode(Blok_9, INPUT_PULLUP);
pinMode(Blok_10, INPUT_PULLUP);
pinMode(Blok_11, INPUT_PULLUP);
pinMode(Blok_12, INPUT_PULLUP);
pinMode(Blok_13, INPUT_PULLUP);
pinMode(Blok_14, INPUT_PULLUP);
pinMode(Blok_15, INPUT_PULLUP);
pinMode(Blok_16, INPUT_PULLUP);
// Section isolate Power on all blocks at startup
pinMode(B7, OUTPUT);
digitalWrite(B7, HIGH);
pinMode(B8, OUTPUT);
digitalWrite(B8, HIGH);
pinMode(B9, OUTPUT);
digitalWrite(B9, HIGH);
pinMode(B10, OUTPUT);
digitalWrite(B10, HIGH);
pinMode(B11, OUTPUT);
digitalWrite(B11, HIGH);
pinMode(B12, OUTPUT);
digitalWrite(B12, HIGH);
pinMode(B14, OUTPUT);
digitalWrite(B14, HIGH);
pinMode(B15, OUTPUT);
digitalWrite(B15, HIGH);
pinMode(F10, OUTPUT);
// Input for toggle switch switching yard
pinMode(S11, INPUT_PULLUP);
pinMode(S12, INPUT_PULLUP);
pinMode(S13, INPUT_PULLUP);
pinMode(S14, INPUT_PULLUP);
// input of button Y10 to set B10 clear
pinMode(Y10, INPUT_PULLUP);
// W14 is toggle switch position for turnout 14, comes from arduino 2
pinMode(W14, INPUT_PULLUP);
pinMode(W15, INPUT_PULLUP);
pinMode(W16, INPUT_PULLUP);
pinMode(W17, INPUT_PULLUP);
pinMode(W18, INPUT_PULLUP);
pinMode(W19, INPUT_PULLUP);
// read the current sensor (Block) input pin:
int Blok_0_State = digitalRead(Blok_0);
int Blok_9_State = digitalRead(Blok_9);
int Blok_10_State = digitalRead(Blok_10);
int Blok_11_State = digitalRead(Blok_11);
int Blok_12_State = digitalRead(Blok_12);
int Blok_13_State = digitalRead(Blok_13);
int Blok_14_State = digitalRead(Blok_14);
int Blok_15_State = digitalRead(Blok_15);
int Blok_16_State = digitalRead(Blok_16);
// read the turnout (toggle switch) position)
int W14State = digitalRead(W14);
int W15State = digitalRead(W15);
int W16State = digitalRead(W16);
int W17State = digitalRead(W17);
int W18State = digitalRead(W18);
int W19State = digitalRead(W19);
// Timer reference
// Hall sensor LOW, means activated (set previous Block powerless), relay set to LOW (indicator led ON)
// Track Wires connected to relay in NC position
// Block 1 occupied
/*if (Blok_1_State == LOW && Blok_0_State == HIGH) {
digitalWrite(S4, HIGH); // 34
digitalWrite(S3, LOW); // 35
delay(10);
if (W1State != lastW1State) // Checks if turnout 1 has shifted since last position (which the train used to occupy track Ha1a or Ha1b)
W_Millis = currentMillis;
enabled_W = true; // turn on software timer
if (enabled_W) // software timer is active ?
if (currentMillis - W_Millis >= interval) {
digitalWrite(S3, HIGH); // Set block S5 free
enabled_W = false; // stop software timer
// Block 7 occupied
if (Blok_7_State == LOW && Blok_0_State == HIGH) {
digitalWrite(S6, HIGH); // 32
delay(10);
// Block 8 occupied
if (Blok_8_State == LOW && Blok_0_State == HIGH) {
delay(10);
// Block 9 occupied
if (Blok_9_State == LOW && Blok_0_State == HIGH) {
digitalWrite(B8, LOW); // Blok 8 powerless
digitalWrite(B7, HIGH); // Blok 7 free
delay(10);
// Block 10 occupied
if (Blok_10_State == LOW && Blok_0_State == HIGH) {
digitalWrite(B9, LOW); // 35
digitalWrite(B8, HIGH); // 30
delay(10);
// Block 11 occupied
if (Blok_11_State == LOW && Blok_0_State == HIGH) {
digitalWrite(B10, LOW); // 35
digitalWrite(B9, HIGH); // 30
delay(10);
// Block 12 occupied
if (Blok_12_State == LOW && Blok_0_State == HIGH) {
delay(10);
// Block 13 occupied
if (Blok_13_State == LOW && Blok_0_State == HIGH) {
delay(10);
// Block 14 occupied
if (Blok_14_State == LOW && Blok_0_State == HIGH) {
delay(10);
// Conditions for switching yard entry via F10
if (W14State == HIGH && S14State == HIGH) // W14 HIGH = straight S14 LOW = toggleswitch inactive, track 14 is free
digitalWrite(F10, HIGH); // train track F10 gets power, train may drive to blok 14
delay(10);
} else if (W14State == LOW && W15State == HIGH && S13State == HIGH) // W14 bend, W15 straight and S13 is inactive, track 13 is free
digitalWrite(F10, HIGH); // train may drive to blok 13
} else if (W14State == LOW && W15State == LOW && W16State == HIGH && S12State == HIGH) // W14 bend, W15 bend, W16 straight and S12 is inactive, track 12 is free
} else if (W14State == LOW && W15State == LOW && W16State == LOW && S11State == HIGH) // W14 bend, W15 bend, W16 bend and S11 is inactive, track 11 is free
digitalWrite(F10, LOW);
// ---------------------------------------- Write pushbutton code here to reset B10 ----------------------------------------------------
// Block 15 occupied
if (Blok_15_State == LOW && Blok_0_State == HIGH) {
digitalWrite(B11, LOW); // 32
digitalWrite(B12, LOW); // 33
digitalWrite(B13, LOW); // 32
digitalWrite(B14, LOW);
delay(10);
// Block 16 occupied
if (Blok_16_State == LOW && Blok_0_State == HIGH) {
digitalWrite(B11, HIGH); // 32
digitalWrite(B12, HIGH); // 33
digitalWrite(B13, HIGH); // 32
delay(10);
/* licht signaal Blok 1 na vrijgave door blok 3 afhankelijk van wissel 2
if (W2State == HIGH && L1aState == HIGH) // L1aState is de blok vrijgave, zolang deze er niet is blijft alles rood W2State is wisselsturing wissel 2 vanuit arduino Mega 2 pin ...
digitalWrite(relaisL1a, HIGH);
digitalWrite(relaisL1b, LOW);
delay(10);
else if (W2State == LOW && L1aState == HIGH)
digitalWrite(relaisL1a, LOW); // ene spoor rood andere groen door wisselstand
digitalWrite(relaisL1b, HIGH);
delay(10);
digitalWrite(relaisL1a, LOW); // Alles op rood, blok bezet
delay(10);
// licht signaal Blok 9 na vrijgave door blok 7, 8 of 11 (1 relais ivm licht signaal enkel spoor)
if (W5State == HIGH && L9State == HIGH) // L9State is de blok vrijgave, zolang deze er niet is blijft alles rood W5State is wisselsturing vanuit arduino Mega 2 pin ...
digitalWrite(relaisL9, HIGH);
delay(10);
else if (W5State == LOW && L9State == HIGH)
digitalWrite(relaisL9, LOW); // enkel licht signaal op block 9
delay(10);
digitalWrite(relaisL9, LOW); // Alles op rood, blok bezet
delay(10);
// licht signaal Blok 12 na vrijgave door blok 10
if (W12State == HIGH && L12aState == HIGH) // L12State is de blok vrijgave, zolang deze er niet is blijft alles rood W12State is wisselsturing vanuit arduino Mega 2 pin ...
digitalWrite(relaisL12a, HIGH);
digitalWrite(relaisL12b, LOW);
delay(10);
else if (W12State == LOW && L12aState == HIGH)
digitalWrite(relaisL12a, LOW); // ene spoor rood andere groen door wisselstand
digitalWrite(relaisL12b, HIGH);
delay(10);
digitalWrite(relaisL12a, LOW); // Alles op rood, blok bezet
delay(10);
delay(10); //debounce
Error messages are:
#define B10 2
const int B10 = 17;
#define B11 3
const int B11 = 18;
exit status 1
Re: Error messages during compiling
Op regel 1 ( die niet in deze code staat) staat een # definie B10 2
En in het programma staat een const B10 = 17
Deze statements zijn strijdig met elkaar.
- maartentukker
Ah oke, I changed all B... to BL... , now it compiles good.
Tnx
Tnx
