Problemen met code
- Jeroentjevrij
Problemen met code
Ik heb een 8x8x8 kubus gemaakt en daar een code bij gekregen.
Alleen krijg ik een aantal fout meldingen.
Use of undeclared identifier'effect_planbowing'
Enz Enz. Bij allen met effect in de naam.
Weet iemand hoe dit op te lossen.
#include <avr/interrupt.h>
#include <string.h>
#define AXIS_X 1
#define AXIS_Y 2
#define AXIS_Z 3
volatile unsigned char cube[8][8];
volatile int current_layer = 0;
int i;
for(i=0; i<14; i++)
pinMode(i, OUTPUT);
// pinMode(A0, OUTPUT) as specified in the arduino reference didn't work. So I accessed the registers directly.
DDRC = 0xff;
PORTC = 0x00;
// Reset any PWM configuration that the arduino may have set up automagically!
TCCR2A = 0x00;
TCCR2B = 0x00;
TCCR2A |= (0x01 << WGM21); // CTC mode. clear counter on TCNT2 == OCR2A
OCR2A = 10; // Interrupt every 25600th cpu cycle (256*100)
TCNT2 = 0x00; // start counting at 0
TCCR2B |= (0x01 << CS22) | (0x01 << CS21); // Start the clock with a 256 prescaler
TIMSK2 |= (0x01 << OCIE2A);
ISR (TIMER2_COMPA_vect)
int i;
// all layer selects off
PORTC = 0x00;
PORTB &= 0x0f;
PORTB |= 0x08; // output enable off.
for (i=0; i<8; i++)
PORTD = cube[current_layer][i];
PORTB = (PORTB & 0xF8) | (0x07 & (i+1));
PORTB &= 0b00110111; // Output enable on.
if (current_layer < 6)
PORTC = (0x01 << current_layer);
} else if (current_layer == 6)
digitalWrite(12, HIGH);
} else
digitalWrite(13, HIGH);
current_layer++;
if (current_layer == 8)
current_layer = 0;
int i,x,y,z;
while (true)
effect_planboing(AXIS_Z, 400);
effect_planboing(AXIS_Y, 400);
effect_planboing(AXIS_X, 400);
effect_blinky2();
effect_random_filler(75,1);
effect_random_filler(75,0);
effect_rain(100);
effect_boxside_randsend_parallel (AXIS_X, 0, 150, 1);
effect_boxside_randsend_parallel (AXIS_X, 1, 150, 1);
effect_boxside_randsend_parallel (AXIS_Y, 0, 150, 1);
effect_boxside_randsend_parallel (AXIS_Y, 1, 150, 1);
effect_boxside_randsend_parallel (AXIS_Z, 0, 150, 1);
effect_boxside_randsend_parallel (AXIS_Z, 1, 150, 1);
// Effect functions
void draw_positions_axis (char axis, unsigned char positions[64], int invert)
int x, y, p;
fill(0x00);
for (x=0; x<8; x++)
for (y=0; y<8; y++)
if (invert)
p = (7-positions[(x*8)+y]);
} else
p = positions[(x*8)+y];
if (axis == AXIS_Z)
setvoxel(x,y,p);
if (axis == AXIS_Y)
setvoxel(x,p,y);
if (axis == AXIS_X)
setvoxel(p,y,x);
void effect_boxside_randsend_parallel (char axis, int origin, int delay, int mode)
int i;
int done;
unsigned char cubepos[64];
unsigned char pos[64];
int notdone = 1;
int notdone2 = 1;
int sent = 0;
for (i=0;i<64;i++)
pos[i] = 0;
while (notdone)
if (mode == 1)
notdone2 = 1;
while (notdone2 && sent<64)
i = rand()%64;
if (pos[i] == 0)
sent++;
pos[i] += 1;
notdone2 = 0;
} else if (mode == 2)
if (sent<64)
pos[sent] += 1;
sent++;
done = 0;
for (i=0;i<64;i++)
if (pos[i] > 0 && pos[i] <7)
pos[i] += 1;
if (pos[i] == 7)
done++;
if (done == 64)
notdone = 0;
for (i=0;i<64;i++)
if (origin == 0)
cubepos[i] = pos[i];
} else
cubepos[i] = (7-pos[i]);
delay_ms(delay);
draw_positions_axis(axis,cubepos,0);
void effect_rain (int iterations)
int i, ii;
int rnd_x;
int rnd_y;
int rnd_num;
for (ii=0;ii<iterations;ii++)
rnd_num = rand()%4;
for (i=0; i < rnd_num;i++)
rnd_x = rand()%8;
rnd_y = rand()%8;
setvoxel(rnd_x,rnd_y,7);
delay_ms(1000);
shift(AXIS_Z,-1);
// Set or clear exactly 512 voxels in a random order.
void effect_random_filler (int delay, int state)
int x,y,z;
int loop = 0;
if (state == 1)
fill(0x00);
} else
fill(0xff);
while (loop<511)
x = rand()%8;
y = rand()%8;
z = rand()%8;
if ((state == 0 && getvoxel(x,y,z) == 0x01) || (state == 1 && getvoxel(x,y,z) == 0x00))
altervoxel(x,y,z,state);
delay_ms(delay);
loop++;
void effect_blinky2()
int i,r;
fill(0x00);
for (r=0;r<2;r++)
i = 750;
while (i>0)
fill(0x00);
delay_ms(i);
fill(0xff);
delay_ms(100);
i = i - (15+(1000/(i/10)));
delay_ms(1000);
i = 750;
while (i>0)
fill(0x00);
delay_ms(751-i);
fill(0xff);
delay_ms(100);
// Draw a plane on one axis and send it back and forth once.
void effect_planboing (int plane, int speed)
int i;
for (i=0;i<8;i++)
fill(0x00);
setplane(plane, i);
delay_ms(speed);
for (i=7;i>=0;i--)
fill(0x00);
setplane(plane,i);
delay_ms(speed);
// Draw functions
// Set a single voxel to ON
void setvoxel(int x, int y, int z)
if (inrange(x,y,z))
cube[z][y] |= (1 << x);
void clrvoxel(int x, int y, int z)
if (inrange(x,y,z))
cube[z][y] &= ~(1 << x);
// This function validates that we are drawing inside the cube.
unsigned char inrange(int x, int y, int z)
if (x >= 0 && x < 8 && y >= 0 && y < 8 && z >= 0 && z < 8)
return 0x01;
} else
// One of the coordinates was outside the cube.
return 0x00;
// Get the current status of a voxel
unsigned char getvoxel(int x, int y, int z)
if (inrange(x,y,z))
if (cube[z][y] & (1 << x))
return 0x01;
} else
return 0x00;
} else
return 0x00;
// In some effect we want to just take bool and write it to a voxel
// this function calls the apropriate voxel manipulation function.
void altervoxel(int x, int y, int z, int state)
if (state == 1)
setvoxel(x,y,z);
} else
clrvoxel(x,y,z);
// Flip the state of a voxel.
// If the voxel is 1, its turned into a 0, and vice versa.
void flpvoxel(int x, int y, int z)
if (inrange(x, y, z))
cube[z][y] ^= (1 << x);
// Makes sure x1 is alwas smaller than x2
// This is usefull for functions that uses for loops,
// to avoid infinite loops
void argorder(int ix1, int ix2, int *ox1, int *ox2)
if (ix1>ix2)
int tmp;
tmp = ix1;
ix1= ix2;
ix2 = tmp;
*ox1 = ix1;
*ox2 = ix2;
// Sets all voxels along a X/Y plane at a given point
// on axis Z
void setplane_z (int z)
int i;
if (z>=0 && z<8)
for (i=0;i<8;i++)
cube[z][i] = 0xff;
// Clears voxels in the same manner as above
void clrplane_z (int z)
int i;
if (z>=0 && z<8)
for (i=0;i<8;i++)
cube[z][i] = 0x00;
void setplane_x (int x)
int z;
int y;
if (x>=0 && x<8)
for (z=0;z<8;z++)
for (y=0;y<8;y++)
void clrplane_x (int x)
int z;
int y;
if (x>=0 && x<8)
for (z=0;z<8;z++)
for (y=0;y<8;y++)
void setplane_y (int y)
int z;
if (y>=0 && y<8)
for (z=0;z<8;z++)
cube[z][y] = 0xff;
void clrplane_y (int y)
int z;
if (y>=0 && y<8)
for (z=0;z<8;z++)
cube[z][y] = 0x00;
void setplane (char axis, unsigned char i)
switch (axis)
case AXIS_X:
setplane_x(i);
case AXIS_Y:
setplane_y(i);
case AXIS_Z:
setplane_z(i);
void clrplane (char axis, unsigned char i)
switch (axis)
case AXIS_X:
clrplane_x(i);
case AXIS_Y:
clrplane_y(i);
case AXIS_Z:
clrplane_z(i);
// Fill a value into all 64 byts of the cube buffer
// Mostly used for clearing. fill(0x00)
// or setting all on. fill(0xff)
void fill (unsigned char pattern)
int z;
int y;
for (z=0;z<8;z++)
for (y=0;y<8;y++)
cube[z][y] = pattern;
// Draw a box with all walls drawn and all voxels inside set
void box_filled(int x1, int y1, int z1, int x2, int y2, int z2)
int iy;
int iz;
argorder(x1, x2, &x1, &x2);
argorder(y1, y2, &y1, &y2);
argorder(z1, z2, &z1, &z2);
for (iz=z1;iz<=z2;iz++)
for (iy=y1;iy<=y2;iy++)
cube[iz][iy] |= byteline(x1,x2);
// Darw a hollow box with side walls.
void box_walls(int x1, int y1, int z1, int x2, int y2, int z2)
int iy;
int iz;
if (iy == y1 || iy == y2 || iz == z1 || iz == z2)
cube[iz][iy] = byteline(x1,x2);
} else
cube[iz][iy] |= ((0x01 << x1) | (0x01 << x2));
// Draw a wireframe box. This only draws the corners and edges,
// no walls.
void box_wireframe(int x1, int y1, int z1, int x2, int y2, int z2)
int iy;
int iz;
// Lines along X axis
cube[z1][y1] = byteline(x1,x2);
cube[z1][y2] = byteline(x1,x2);
cube[z2][y1] = byteline(x1,x2);
cube[z2][y2] = byteline(x1,x2);
// Lines along Y axis
setvoxel(x1,iy,z1);
setvoxel(x1,iy,z2);
setvoxel(x2,iy,z1);
setvoxel(x2,iy,z2);
// Lines along Z axis
setvoxel(x1,y1,iz);
setvoxel(x1,y2,iz);
setvoxel(x2,y1,iz);
setvoxel(x2,y2,iz);
// Returns a byte with a row of 1's drawn in it.
// byteline(2,5) gives 0b00111100
char byteline (int start, int end)
return ((0xff<<start) & ~(0xff<<(end+1)));
// Flips a byte 180 degrees.
// MSB becomes LSB, LSB becomes MSB.
char flipbyte (char byte)
char flop = 0x00;
flop = (flop & 0b11111110) | (0b00000001 & (byte >> 7));
flop = (flop & 0b11111101) | (0b00000010 & (byte >> 5));
flop = (flop & 0b11111011) | (0b00000100 & (byte >> 3));
flop = (flop & 0b11110111) | (0b00001000 & (byte >> 1));
flop = (flop & 0b11101111) | (0b00010000 & (byte << 1));
flop = (flop & 0b11011111) | (0b00100000 & (byte << 3));
flop = (flop & 0b10111111) | (0b01000000 & (byte << 5));
flop = (flop & 0b01111111) | (0b10000000 & (byte << 7));
return flop;
// Draw a line between any coordinates in 3d space.
// Uses integer values for input, so dont expect smooth animations.
void line(int x1, int y1, int z1, int x2, int y2, int z2)
float xy; // how many voxels do we move on the y axis for each step on the x axis
float xz; // how many voxels do we move on the y axis for each step on the x axis
unsigned char x,y,z;
unsigned char lasty,lastz;
// We always want to draw the line from x=0 to x=7.
// If x1 is bigget than x2, we need to flip all the values.
if (x1>x2)
int tmp;
tmp = x2; x2 = x1; x1 = tmp;
tmp = y2; y2 = y1; y1 = tmp;
tmp = z2; z2 = z1; z1 = tmp;
if (y1>y2)
xy = (float)(y1-y2)/(float)(x2-x1);
lasty = y2;
} else
xy = (float)(y2-y1)/(float)(x2-x1);
lasty = y1;
if (z1>z2)
xz = (float)(z1-z2)/(float)(x2-x1);
lastz = z2;
} else
xz = (float)(z2-z1)/(float)(x2-x1);
lastz = z1;
// For each step of x, y increments by:
for (x = x1; x<=x2;x++)
y = (xy*(x-x1))+y1;
z = (xz*(x-x1))+z1;
setvoxel(x,y,z);
// Delay loop.
// This is not calibrated to milliseconds,
// but we had allready made to many effects using this
// calibration when we figured it might be a good idea
// to calibrate it.
void delay_ms(uint16_t x)
uint8_t y, z;
for ( ; x > 0 ; x--){
for ( y = 0 ; y < 90 ; y++){
for ( z = 0 ; z < 6 ; z++){
asm volatile ("nop");
// Shift the entire contents of the cube along an axis
// This is great for effects where you want to draw something
// on one side of the cube and have it flow towards the other
// side. Like rain flowing down the Z axiz.
void shift (char axis, int direction)
int i, x ,y;
int ii, iii;
int state;
for (i = 0; i < 8; i++)
if (direction == -1)
ii = i;
} else
ii = (7-i);
for (x = 0; x < 8; x++)
for (y = 0; y < 8; y++)
iii = ii+1;
} else
iii = ii-1;
if (axis == AXIS_Z)
state = getvoxel(x,y,iii);
altervoxel(x,y,ii,state);
if (axis == AXIS_Y)
state = getvoxel(x,iii,y);
altervoxel(x,ii,y,state);
if (axis == AXIS_X)
state = getvoxel(iii,y,x);
altervoxel(ii,y,x,state);
i = 7;
} else
i = 0;
if (axis == AXIS_Z)
clrvoxel(x,y,i);
if (axis == AXIS_Y)
clrvoxel(x,i,y);
if (axis == AXIS_X)
clrvoxel(i,y,x);
Re: Problemen met code
Heb de sketch gecopy-pastet en die compileert hier toch zonder foutmeldingen.
Sketch uses 3152 bytes (10%) of program storage space. Maximum is 30720 bytes.
Global variables use 79 bytes (3%) of dynamic memory, leaving 1969 bytes for local variables. Maximum is 2048 bytes.
Arduinows!
Ja dat kan rudi, echter zijn er 2 libraries die jij wel hebt, maar jeroen niet of andere. Dus jeroen ga op zoek naar de includes die boven aan staan.
