ESP8266 Wifi statisch ip adres
12 berichten
Re: ESP8266 Wifi statisch ip adres
Zou toch fijn zijn als je iets duidelijker kunt formuleren wat je bedoeld.
Ik heb de code aangepast en hieronder gepaatst, ik krijg nu de volgende melding: redefinition of 'const char* ssid'
SDWebServer - Example WebServer with SD Card backend for esp8266
Copyright (c) 2015 Hristo Gochkov. All rights reserved.
This file is part of the ESP8266WebServer library for Arduino environment.
This library is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public
License along with this library; if not, write to the Free Software
Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
Have a FAT Formatted SD Card connected to the SPI port of the ESP8266
The web root is the SD Card root folder
File extensions with more than 3 charecters are not supported by the SD Library
File Names longer than 8 charecters will be truncated by the SD library, so keep filenames shorter
index.htm is the default index (works on subfolders as well)
upload the contents of SdRoot to the root of the SDcard and access the editor by going to http://esp8266sd.local/edit
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
#include <SPI.h>
#include <SD.h>
const char *ssid = "YourSSID";
const char *pass = "YourPassword";
// Update these with values suitable for your network.
IPAddress ip(192,168,0,128); //Node static IP
IPAddress gateway(192,168,0,1);
IPAddress subnet(255,255,255,0);
#define DBG_OUTPUT_PORT Serial
const char* ssid = "**********";
const char* password = "**********";
const char* host = "esp8266sd";
ESP8266WebServer server(80);
static bool hasSD = false;
File uploadFile;
void returnOK() {
server.send(200, "text/plain", "");
void returnFail(String msg) {
server.send(500, "text/plain", msg + "\r\n");
bool loadFromSdCard(String path){
String dataType = "text/plain";
if(path.endsWith("/")) path += "index.htm";
if(path.endsWith(".src")) path = path.substring(0, path.lastIndexOf("."));
else if(path.endsWith(".htm")) dataType = "text/html";
else if(path.endsWith(".css")) dataType = "text/css";
else if(path.endsWith(".js")) dataType = "application/javascript";
else if(path.endsWith(".png")) dataType = "image/png";
else if(path.endsWith(".gif")) dataType = "image/gif";
else if(path.endsWith(".jpg")) dataType = "image/jpeg";
else if(path.endsWith(".ico")) dataType = "image/x-icon";
else if(path.endsWith(".xml")) dataType = "text/xml";
else if(path.endsWith(".pdf")) dataType = "application/pdf";
else if(path.endsWith(".zip")) dataType = "application/zip";
File dataFile = SD.open(path.c_str());
if(dataFile.isDirectory()){
path += "/index.htm";
if (!dataFile)
return false;
if (server.hasArg("download")) dataType = "application/octet-stream";
if (server.streamFile(dataFile, dataType) != dataFile.size()) {
DBG_OUTPUT_PORT.println("Sent less data than expected!");
dataFile.close();
return true;
void handleFileUpload(){
if(server.uri() != "/edit") return;
HTTPUpload& upload = server.upload();
if(upload.status == UPLOAD_FILE_START){
if(SD.exists((char *)upload.filename.c_str())) SD.remove((char *)upload.filename.c_str());
uploadFile = SD.open(upload.filename.c_str(), FILE_WRITE);
DBG_OUTPUT_PORT.print("Upload: START, filename: "); DBG_OUTPUT_PORT.println(upload.filename);
} else if(upload.status == UPLOAD_FILE_WRITE){
if(uploadFile) uploadFile.write(upload.buf, upload.currentSize);
DBG_OUTPUT_PORT.print("Upload: WRITE, Bytes: "); DBG_OUTPUT_PORT.println(upload.currentSize);
} else if(upload.status == UPLOAD_FILE_END){
if(uploadFile) uploadFile.close();
DBG_OUTPUT_PORT.print("Upload: END, Size: "); DBG_OUTPUT_PORT.println(upload.totalSize);
void deleteRecursive(String path){
File file = SD.open((char *)path.c_str());
if(!file.isDirectory()){
file.close();
SD.remove((char *)path.c_str());
return;
file.rewindDirectory();
while(true) {
File entry = file.openNextFile();
if (!entry) break;
String entryPath = path + "/" +entry.name();
if(entry.isDirectory()){
entry.close();
deleteRecursive(entryPath);
entry.close();
SD.remove((char *)entryPath.c_str());
yield();
SD.rmdir((char *)path.c_str());
file.close();
void handleDelete(){
if(server.args() == 0) return returnFail("BAD ARGS");
String path = server.arg(0);
if(path == "/" || !SD.exists((char *)path.c_str())) {
returnFail("BAD PATH");
return;
deleteRecursive(path);
returnOK();
void handleCreate(){
if(path == "/" || SD.exists((char *)path.c_str())) {
return;
if(path.indexOf('.') > 0){
File file = SD.open((char *)path.c_str(), FILE_WRITE);
if(file){
file.write((const char *)0);
file.close();
SD.mkdir((char *)path.c_str());
returnOK();
void printDirectory() {
if(!server.hasArg("dir")) return returnFail("BAD ARGS");
String path = server.arg("dir");
if(path != "/" && !SD.exists((char *)path.c_str())) return returnFail("BAD PATH");
File dir = SD.open((char *)path.c_str());
path = String();
if(!dir.isDirectory()){
dir.close();
return returnFail("NOT DIR");
dir.rewindDirectory();
server.setContentLength(CONTENT_LENGTH_UNKNOWN);
server.send(200, "text/json", "");
WiFiClient client = server.client();
server.sendContent("[");
for (int cnt = 0; true; ++cnt) {
File entry = dir.openNextFile();
if (!entry)
String output;
if (cnt > 0)
output = ',';
output += "{\"type\":\"";
output += (entry.isDirectory()) ? "dir" : "file";
output += "\",\"name\":\"";
output += entry.name();
output += "\"";
output += "}";
server.sendContent(output);
entry.close();
server.sendContent("]");
dir.close();
void handleNotFound(){
if(hasSD && loadFromSdCard(server.uri())) return;
String message = "SDCARD Not Detected\n\n";
message += "URI: ";
message += server.uri();
message += "\nMethod: ";
message += (server.method() == HTTP_GET)?"GET":"POST";
message += "\nArguments: ";
message += server.args();
message += "\n";
for (uint8_t i=0; i<server.args(); i++){
message += " NAME:"+server.argName(i) + "\n VALUE:" + server.arg(i) + "\n";
server.send(404, "text/plain", message);
DBG_OUTPUT_PORT.print(message);
void setup(void){
DBG_OUTPUT_PORT.begin(115200);
DBG_OUTPUT_PORT.setDebugOutput(true);
DBG_OUTPUT_PORT.print("\n");
WiFi.begin(ssid, password);
WiFi.config(ip, gateway, subnet);
DBG_OUTPUT_PORT.print("Connecting to ");
DBG_OUTPUT_PORT.println(ssid);
// Wait for connection
uint8_t i = 0;
while (WiFi.status() != WL_CONNECTED && i++ < 20) {//wait 10 seconds
delay(500);
if(i == 21){
DBG_OUTPUT_PORT.print("Could not connect to");
while(1) delay(500);
DBG_OUTPUT_PORT.print("Connected! IP address: ");
DBG_OUTPUT_PORT.println(WiFi.localIP());
if (MDNS.begin(host)) {
MDNS.addService("http", "tcp", 80);
DBG_OUTPUT_PORT.println("MDNS responder started");
DBG_OUTPUT_PORT.print("You can now connect to http://");
DBG_OUTPUT_PORT.print(host);
DBG_OUTPUT_PORT.println(".local");
server.on("/list", HTTP_GET, printDirectory);
server.on("/edit", HTTP_DELETE, handleDelete);
server.on("/edit", HTTP_PUT, handleCreate);
server.on("/edit", HTTP_POST, [](){ returnOK(); }, handleFileUpload);
server.onNotFound(handleNotFound);
server.begin();
DBG_OUTPUT_PORT.println("HTTP server started");
if (SD.begin(SS)){
DBG_OUTPUT_PORT.println("SD Card initialized.");
hasSD = true;
void loop(void){
server.handleClient();
Dat is meestal als je hem 2x definieert.....
12 berichten
Gebruikers in dit forum: Google [Bot] en 41 gasten
