arduino sketch wilt niet meer save
- roygie1991
- Geregistreerd: 22 Sep 2015, 18:19
ik heb sinds vanmorgen het probleem dat ik me sketches niet meer kan save als ik hem veranderd heb hij geeft aan toegang geweigerd
Arduino: 1.6.5 (Windows 8.1), Board:"Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
java.io.IOException: Toegang geweigerd
at java.io.WinNTFileSystem.createFileExclusively(Native Method)
at java.io.File.createTempFile(File.java:2024)
at processing.app.BaseNoGui.saveFile(BaseNoGui.java:1078)
at processing.app.SketchCode.save(SketchCode.java:222)
at processing.app.SketchData.save(SketchData.java:157)
at processing.app.Sketch.save(Sketch.java:609)
at processing.app.Editor.handleSave2(Editor.java:2246)
at processing.app.Editor.access$2900(Editor.java:71)
at processing.app.Editor$58.run(Editor.java:2231)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:756)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:75)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:726)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
Toegang geweigerd
Toegang geweigerd
Toegang geweigerd
Toegang geweigerd
Re: arduino sketch wilt niet meer save
`java opnieuw installeren, lijkt mij.
ook de IDE opnieuw ophalen helpt vaak.
