Error on Connecting Python code to SQL Server
- satineeraj
- Geregistreerd: 26 Mei 2021, 19:50
- Woonplaats: GB
Hello , I am trying to connect to SQL through python to run some queries on some SQL databases on Microsoft SQL server. From my research online and on this forum the most promising library seems to be pyodbc. So I have made the following code
import pyodbc
conn = pyodbc.connect(init_string="driver={SQLOLEDB}; server=+ServerName+;
database=+MSQLDatabase+; trusted_connection=true")
cursor = conn.cursor()
and i am getting the following error
Traceback (most recent call last):
File "C:\Users...\scrap.py", line 3, in <module>
conn = pyodbc.connect(init_string="driver={SQLOLEDB}; server=+ServerName+; database=+MSQLDatabase+; trusted_connection=true")
pyodbc.Error: ('IM002', '[IM002] [Microsoft][ODBC Driver Manager] Data source name not found and no default driver specified (0) (SQLDriverConnect)')
Please Help
import pyodbc
Please Help
Re: Error on Connecting Python code to SQL Server
put this question in a python forum as this is specialised in arduino
satineeraj schreef:Data source name not found and no default driver specified
Please Help
In this case help is unavailable.
You have not defined your helpsource.
